Technical BRAKES, Got Brakes??
Discussion in 'The Hokey Ass Message Board' started by C9, Jan 20, 2005.
  1. I would guess that most of you on here know that I write articles and stories for Mike Siewert's FSRA bi-monthly newsletter.
    Although I haven't done much for the last 6 months due to moving to Arizona and being busier than heck.
    What follows is a reprise of a disc brake article I did for the newsletter some time back.
    I thought perhaps it would be useful for some since there seem to be a lot of disc brake questions for solid axle cars lately.
    I am a big fan of disc brakes and make no apologies for using them.
    That said, I'd probably run drums if I built a particular style of car.
    A set of well detailed F100 drums on an A modified would do the trick.
    The right set of linings would give you all the brakes needed for such a lightweight car.
    Twisty mountain roads or not.... [​IMG]
    In a small way, a hot rod is like an airplane.
    You don't have to take off, but you always have to land.
    Which is . . . most times, very safe.
    Unless you're unlucky or incredibly dumb, then it becomes the riskiest part of the whole flight and can sometimes end in disaster.
    For the hot rod, if it's running you don't have to take off, but you always have to stop.
    Patently obvious, no doubt, but some of the things I've seen, back in the day as well as now leave me wondering.
    Darwinism at it's finest I suppose.
    So, the article will comprise 11 parts with photos et al and it's gonna take a while to get it all down.
    Hang in there a bit before posting if you would.
    Le start....
    Front Stoppers
    Here’s the rundown on two different disc brake installations for the solid front axle Fords.
    One for Camaro discs and one for Mustang discs.
    With a list of applicable ChryCo rotor part numbers as well.
    Hot rod parts suppliers for these projects are listed as well as the remaining front end parts and sources are noted. Stock parts are noted as well.
    Two cars are involved, a 31 A on 32 frame rails and a 32. Both cars highboy roadsters with the 31 being built for the dry lakes and the 32 an everyday street runner.
    Camaro Discs
    The Magnum brake kit used on the 31 is the #4475 Econo Disc Brake Kit.
    It allows GM rotors and calipers to be bolted onto 37-48 Ford spindles with a minimum of additional work. A small amount of grinding on the calipers is required and a small bit of machining or grinding may be required on the spindle nut.
    The kit includes:
    A pair of cast brackets to mount the calipers.
    Two bearing adapters.
    Two spacers that go between the outer bearings and the stock tabbed washer that fits the keyway and goes under the spindle nut. One spacer per side.
    Eight bolts and eight nuts to mount the caliper.
    Two grease seals.
    Two inner bearing cups/races.
    Two inner bearings.
    Note that the kit uses an earlier series of rotor than calipers.
    Rotors:
    GM part number EIS #D5214
    70-78 Camaro
    73-77 Chevelle
    73-77 Monte Carlo
    73-77 Malibu
    75-78 Nova
    73-77 Buick Regal
    73-77 Buick Century
    73-78 Buick Skylark
    73-77 Olds Cutl***
    70-78 Firebird
    73-77 Grand Prix
    73-77 Le Mans
    73-77 Tempest
    73-77 GTO
    Calipers:
    78-85 Buick Regal
    82-84 Camaro
    78-85 Chevelle
    78-85 Monte Carlo
    78-85 El Camino
    78-85 Malibu
    78-85 Cutl***
    78-85 F-85
    78-84 Grand Prix
    82-84 Bonneville
    82-84 Firebird
    78-81 GTO
    78-81 Le Mans
    78-81 Tempest
    Additional parts required are the spindle nut, tabbed washer and bearing dust cover.
    New rotors and rebuilt calipers were purchased at the parts house. The rotors come with 7/16" lug studs already pressed in.
    The lug stud boss cast into the back of the rotor has sufficient material to drill for larger ½" lug studs, but you will have to remain with the 4 3/4" Chevy wheel pattern.
    The larger studs are required by SCTA.
    For street use on a light car like the 31 roadster I wouldn’t worry about the larger stud. If GM considers the 7/16" stud big enough for the 3500# and up cars listed there shouldn’t be any problems using them on a 2200-2500# roadster.
    The reason the GM rotors - at least the Camaro ones I have - will not drill for the 4 ½" Ford bolt pattern is that the rotor casting is hollowed out between the Chevy pattern lug stud bosses. The area where you would drill for the Ford pattern is too thin to properly retain the ½" lug studs.
    Perhaps not a problem with other GM rotors in the series listed for use with this kit. If you can find a rotor that’s solid on the back you’re in business as far as drilling for a different bolt pattern. I would not be surprised to learn that there is a solid back GM rotor in the series listed.
    You’ll have to grind a relief on one corner of the caliper brake line mounting boss.
    Pretty self explanatory when you get there and it’s shown in the Magnum instruction blueprint below.
    (Front Stoppers was the original ***le.)
  2. Priest's Hat Dust Cover
    A lobe on the underside of the caliper casting will have to be ground off to clear the mounting bracket. That’s shown on the blueprint as well.
    Besides the grinding required on the caliper, there’s one other small trick that enters into it.
    Obtaining sufficient clearance between what I call the ‘Priests Hat’ bearing dust cover and the spindle nut.
    The spindle nut, tabbed washer and dust cover were purchased right out of the Dorman bolt supply drawers.
    They are an in-stock item at most parts houses.
    With the Dorman spindle nut there is insufficient clearance between the outer edge of the nut and the inside of the Priests Hat dust cover.
    You may be able to find a taller, more standard appearing dust cover that fits, but maybe not.
    I never did find a dust cover that would fit my stock 50 Plymouth coupe and ended up turning out the brake drums where the dust cover fit and using easily obtained utility trailer dust covers.
    I ended up turning a 45 degree chamfer on the outer edge of the spindle nut and rounding off the 45 degree corners.
    I note that parts illustrations for the GM spindle nut have the spindle nut shoulder cut sharply back so it will clear the inside of the dust cover.
    Purchasing the spindle nut at the Chevy parts counter may be a good idea.
    I’m guessing a genuine GM part would be cut to fit and ready to go.
    Said ‘Priests Hat’ dust cover in the photo so you can see what I’m talking about.
  3. The Mustang disc brake blueprint shows the later square faced spindles being used with the Mustang Super Bell cast caliper bracket with the notation that a little grinding is required on one of the corners.
    The round faced spindle is a bolt-on with the Mustang bracket and the Camaro bracket as well.
    Looking at the Mustang instructions leads me to believe that the same amount of grinding on the later square faced Ford spindles may work on the Magnum Camaro cast caliper bracket.
    Better check first though. See Mustang blueprint further down the page.
    Other than that, using the Camaro disc brake kit with Camaro parts has a couple of advantages over using the Mustang disc brake kit.
    For starters, the Camaro cast caliper bracket is more exposed than is the Mustang cast caliper bracket.
    Which means if you chrome plate the Camaro bracket a lot more of it shows than does the Mustang bracket.
    Camaro Caliper & Rotor pic
  4. The Mustang bracket was plated and for the most part it’s well hidden.
    Not so with the Camaro bracket and chrome plating it would be a worthwhile expenditure.
    The Camaro rotor is 10 ½" in diameter and it looks to have more than enough braking power on a light car.
    The Mustang rotor is 11" in diameter and has a considerable amount of braking power.
    Considering the flat-out venue the 31 is slated for, I don’t see any disadvantage in using the slightly smaller rotor.
    Overall the Camaro disc brake setup is better looking than the Mustang. Especially so on a highboy roadster. The Mustang disc brakes look ok, but to my eye the less bulky appearing Camaro caliper looks better.
    One big advantage is parts cost. I paid right around $300. back in 1985 for all new parts. New rotors, caliper, pads, bearings and miscellaneous small parts. That was with a fairly good discount.
    Note that the cost of the Mustang kit is not included in the $300. price.
    About the tail end of 1999 I bought roughly the same parts for the Camaro kit. New rotors, rebuilt calipers - loaded, meaning with pads - the outer bearing, spindle nuts, washers and dust covers as well as a few small parts. With the same approximate discount at the parts house as before, the Camaro stuff ran just a touch over $200.
    The only real disadvantages I can see with the Camaro disc brake kit is the 4 3/4" bolt pattern which may be less of a problem for some than it was for me. I’d prefer to have the 4 ½" pattern on both ends, but since a spare tire on a race car is generally not required that’s not really a problem.
    Some brands of wheels may rub against the top of the caliper. That easily cured by a little grinding and probably only a problem when using 14" wheels.
    I’m running 15" steelies on the 31 as you can see and there are no wheel/caliper conflicts.
  5. Mustang Discs
    The 32 runs 68-73 Mustang disc brakes. These are an 11" rotor as noted. Master cylinder for this installation is a 7/8" bore FoMoCo dual cylinder.
    These discs and calipers are also found on the 68-69 Comet, 68-69 Falcon, 68-73 Cougar, 68-71 Fairlane and 70-71 Montego.
    The Mustang disc brake install is made easy using SuperBell's disc brake kit which includes hub and shoulder collars (stepped bushing).
    The collars allow bolting the stock Mustang rotor to the SuperBell hub.
    The Mustang rotor has the standard 4 1/2" Ford wheel pattern.
    The kit installs on 39-48 Ford p***enger car spindles and 39-56 Ford pickup spindles.
    The blueprint shows the square spindle face, but I'm running the round face Super Bell 37-41 spindles.
    They do note that some spindles - the square ones I'm guessing - require a little grinding from the bottom of the spindle boss.
    The area to be ground is shown in the SuperBell blueprint.
  6. Mustang Caliper & Rotor
    Super Bell makes a nice kit and the whole thing pretty much fell together.
    As for the so-called safety feature of the through bolt kits, the ones that have the steering arms drilled all the way through so as to use nuts, they look to me to be not necessary.
    I used Loc***e - blue - as recommended and the steering arm bolts have never come loose.
    Loc***e makes excellent products and I recommend them highly. Even so, use the correct product for the application. Use the red Loc***e and you’re going to need a heat source to dis***emble them.
    Additional parts required for the Mustang kit:
    Inside bearing cup - p***. cars - Timken #15250
    48-56 truck - Timken #14276
    Inside bearing - p***. cars - Timken #15118
    48-56 truck - Timken #14130
    Grease seal - p***. cars - National #471316
    48-56 truck - National #472179
    Outside bearing cup - Timken #09196
    Outside bearing - Timnken #09074
    No difference noted for p***. cars or trucks.
    Listed below are the FoMoCo part numbers for the small pieces required to complete the package along with quan***ies noted in parenthetics.
    Rubber bushing - #C8AZ-2B299-A (4)
    Pad, retaining clip, anti-rattle - #7C8AZ-2B164-A (4)
    Grease cap - #A8AZ-1131-A (2)
    Caliper mount bolt w/washer - #C8AZ-2B296-A (4)
    There is one small Caveat you need to be aware of when you plate, powder coat or paint the disc brake components.
    Plating the cast caliper bracket doesn’t make the ID of the bracket proper small enough to create problems.
    Powder coating and paint on the spindle itself - at least on the exposed areas - can create an interference problem when the caliper bracket is ***embled to the spindle. Powder and paint will decrease the ID of the caliper bracket to a considerable degree as well as increase the OD of the spindle register about the same amount. Register defined as the step on the spindle that locates and centers the caliper bracket.
    The register is easy enough to mask off when painting and it’s also something the powder guy can do before the spindle or caliper bracket is powdered.
    I chrome plated the Mustang caliper bracket and powder coated the spindle. Which created a problem when it came time for the final ***embly. What I did and I don’t recommend it, was to hit the corners of the spindle register with a file. Very carefully as I didn’t want to cut into the powder on the face of the spindle and give rust a place to start. Then I used some grade eight bolts to pull the whole thing together evenly. Once that was done, the kit supplied bolts and steering arms were installed. It all came out square and it’s working well, but I fear the day I try to take it apart is the day I’m going to pay for my transgressions.
    I've read that some think this brake package is too much braking for a lightweight car such as a roadster and it was really designed for heavier cars like fat fendered coupes and sedans. I’m not sure where that idea came from. Seems to me the more brakes the better.
    The non-boosted pedal on the 32 with it’s 7/8" bore dual master cylinder along with the standard 11" Ford drum brakes in the back make for an excellent braking package. Pedal effort is entirely reasonable and stopping distances are very short regardless of speed.
    Little brother used to run the very same brake package on his - at the time - 2700-2800# stock framed drag racing Henry J when it was running 125 mph and he could make the first turn off at every drag strip we went to.
    I expect brake performance for the two roadsters to be very similar. Both cars have the very nice Deuce Factory pedal bracket and brake pedal arm.
    The 10 ½" Camaro rotor doesn’t look to have any particular performance disadvantage as compared to the Mustang 11" rotor. The 31 runs a 7/8" bore dual master cylinder as well.
    Aside from the 4 3/4" Chevy wheel pattern, the big difference is in appearance. The Camaro brakes are not as bulky appearing and make for a better appearance up front.
    One small point of interest and perhaps convenience is a better word, the FoMoCo dual reservoir master cylinders can be found with the outlets on either side. The great majority of the Ford products that use this style master cylinder will have the outlets pointing at the transmission when the master cylinder direction is reversed as it is for most hot rod installations. The Torino is the model to get for hot rod use if you want the outlets to point at the frame. This cylinder is available in a 7/8" bore and a similar model is available in a 1" bore.
    The 7/8" bore master cylinders running sans power booster - which is not needed on these lightweight cars - will have a pedal effort very similar to a non-boosted Pinto.
    I’m pretty sure most all hot rodders know this, but I’m gonna say it anyway. Power brakes do not give you a more powerful brake. All they do is lessen the pedal effort for a given situation. In fact, during a panic stop it takes longer for the power brake system to lock up the brakes than it does for a non-power brake system. Reason being, in an abrupt depression of the brake pedal you have to overcome the resistance of the power braking devices. Granted, locking up the wheels is not the way to go in almost all cases, but we all do it during those little surprises that happen when we’re running in traffic.
  7. ChryCo Discs
    I have no experience with this installation although I understand it works quite well.
    Magnum Axles #4450 kit is required to use the ChryCo discs.
    This kit uses Camaro calipers as listed above in the Camaro Discs listing.
    Mopar rotor parts number EIS #17032
    This particular rotor is found in the following cars:
    80-83 Cordoba
    78-83 Imperial
    78-80 Le Baron
    84-85 Fifth Avenue
    73-76 Challenger
    73-76 Charger
    73-76 Coronet
    73-76 Dart
    76-80 Aspen
    73-76 Demon
    77-84 Diplomat
    80-83 Magnum XE
    80-83 Mirada
    73-74 Roadrunner
    73-74 Satellite
    73-76 Duster
    73-76 Scamp
    73-76 Valiant
    82-85 Gran Fury
    76-80 Volare
    Please note that a great deal of care was used in listing the parts numbers and car models that would be good donors.
    Like always though, when you get the parts and small pieces to finish the job, it’s going to be up to you to make sure that what you get is what you want.
  8. Brake Pedal Return Spring
    As long as we’re talking about brakes, here’s a simple return spring setup that’s compact, easy to set up and out of the way.
    You definitely need an external brake return spring so as to push the brake pedal up far enough to obtain sufficient free-play. Without free-play the M/C port that allows make-up fluid into the cylinder chamber proper will remain closed off and not replenish the cylinder chamber proper.
    As the photos show, there’s not too much to building one of these. One thing to note is the spring end has been opened up a touch to wrap around the master cylinder mouth. Don’t open the spring end up too much, you want it to grip the master cylinder mouth casting fairly snug.
  9. Exploded view of the M/C return spring
    The M/C rod that usually comes with the M/C's will have to have the ring sawn off and the end threaded 3/8-NF so the Deuce Factory supplied Heim end will thread on. The threads don’t show too well in the photo, but they’re there. Note the shallow step in the aluminum seat that is retained by the nut on the end of the Heim joint.
    The spring used is a Century product #C-812. These are available at most any well equipped hardware store as well as Home Depot and similar places.
    You do require a stop for the small brake arm where the Heim bolts. Make it adjustable to allow dialing in the proper amount of brake pedal free-play.
    Without a stop and depending on how far the pedal comes up, you stand a chance of pulling the brake rod out of the M/C and then no brakes.
    The stop bracket was made from a piece of 1 1/2 x 1 1/2" x .120 angle, cut about 1 1/2" wide.
    The rounded piece you see is simply a threaded weld bung with a step in it and it's welded to the stop bracket on the brake arm side. A nut welded to the stop bracket would work just as well.
    Specially if you machine a step in it. Besides the convenience of a threaded receptacle for the stop bolt, the threaded weld bung or nut needs to go on the outside of the angle bracket due to lack of room on the inside as well as having the bracket well supported. Easily seen in the next photo.
  10. Return spring installed on the partially ***embled D.F. bracket
    A pair of 1/4-20 stainless allens hold the stop bracket to the Deuce Factory pedal bracket. The base of the stop bracket is threaded to accept them and the bolts just barely stick out of the stop
    bracket. Short bolts are required because the brake arm will drag on the mounting bolts if they're too tall.
    Some of the M/C's you get will have a triangular shaped flat spring that seats into a notch machined into the M/C end of the actuating rod. Once inserted, that's it. they get damaged if you try to remove the actuating rod.
    These do pretty well in the retainment dept., but I'd go for the positive stop bracket instead.
    Some of the FoMoCo M/C's come with a simple rounded end on the M/C end of the actuating rod. The stop bracket - as noted - prevents losing this style M/C rod out of the M/C.
  11. Stop bracket installed
  12. Brake Light Switch
    Here’s a photo of an easy to install brake light switch. This one installed on the 32 and a similar setup will be installed on the 31.
    The actuator is a 1/4-20 allen. The brake arm is tapped for the bolt and a plain nut is used for the locknut. The brake light switch is one of the Chevy underdash ones with the arm cut short.
    I realize you have much wetter weather in the Great North than we do here in Sunny California, but I get caught out in the rain now and then. So far no problems with the - originally destined for interior use - brake light switch. I’ve spent a couple of days in the rain with it and driven through a couple blocks of 3" or so deep water on a flooded street and from what I can see the switch never got wet. Granted, slow driving. A bit of a requisite for a fenderless hot rod now and then. Even so, you might need a protective cover for the switch as you guys seem to drive in tougher weather than I do. And for longer. Maybe a smear of silicon glue on the switch would help, but you’re on your own here.
    As far as hydraulic stoplight switches go, they seem to work fine when using regular brake fluid. Using silicon brake fluid will eventually fail the switch. What happens is that the silicon fluid gets past the stoplight seal and into the area where the electrical contacts are and insulates them. Eventually so much pressure on the brake pedal is required to light the stoplight’s that during normal use you will not have stoplight’s. At least not until a panic stop when you’re really laying on the brake pedal.
    Look close in the photo above and you’ll see a zerk for lubing the brake pivot. An important little piece I left out on the 32.
    I greased it when it went together and forgot to drill and tap for a zerk before final ***embly.
    Five-six years after the 32 was up and running, I got worried that the pivot or pedal bore was getting egg-shaped, tore it apart and did the zerk bit installation.
    Only trouble was, this time around it took about three hours to do it.......
    In case you’re wondering, the two different disc brake setups on the roadsters were due to the donation of a Magnum Axle Camaro disc brake adapter kit. This done when the 31 project was nothing more than fodder for a bench racing discussion.
    The Magnum Axle kit was donated by a friend to get the project started.
    Once I did a little thinking about it and looked around my garage at some of the leftover parts sitting in there, I realized that a lot of the parts needed for another 455 Buick powered roadster were already on hand.
    Now that I had a perfectly good disc brake kit I couldn’t not build another roadster.
    The disc brake kit was simply the boot in the backside to get it started.
    Too far down the line to turn back now.
    My excuse anyway.......
  13. Roothawg
    Roothawg
    I'm printing this............
  14. Here’s a photo of the 31. Next step, get the tubing, take it to the speed shop and get the roll cage bent up.
  15. Smokin Joe
    Smokin Joe
    Well done Jay. Instant tech-o-matic methinks.
  16. Then the fun stuff starts.
    Engine, trans buildup, safety equipment install, wiring, plumbing, get the right tires for the lakes, all the stuff you need to go fast.
    It’s taken a while so far and costs haven’t been too bad to get the 31 to the point where it’s just about a running street roadster.
    Hitting the dry lakes though, hitting the dry lakes is gonna take some of that green stuff.
    Green like in $$$.
    Like they say, “Speed costs money. How fast do you want to go?”
    The answer, as always, in any automotive speed contest is very simple.
    Faster........ That’s all......... just faster........
    That was the end of the original article.
    Written perhaps two years ago.
    Things change and sometimes the destination gets changed.
    True in this case, but like always, it's all about the journey.
    I got the 31 to a point where I had to decide whether I really wanted to run it on the lakes - which would entail a delay for more building and maybe another $3000. - $5000. for a car with a beginner lakes engine.
    I like the way the 31 turned out and aside from the $$ factor, decided to put it on the street.
    Albeit with a stronger engine than the 32 runs.
    The 32 has about 400 HP and is a lot of fun to drive.
    The 31 should end up around 460 HP - conservative numbers - and be even more fun to drive.
    Next stop for the 31 will be in my friends shop shown below.
    We've just about got his new shop up and running and the next steps for the 31 will be to bend up some different - a little bit - cycle type fender brackets for the front end.
    Not to mention take advantage of the new 4-post hoist to take care of some small details.
    After that, it comes home for the drive train rebuild, plumbing and wiring.
    When will it be running you ask?
    It's a hobby right?
    What will be will be....
  17. rockfish
    rockfish
    Thanks for the post C9. Perfect timing with the return spring set-up. I'll be installing one on my Model A this weekend.
  18. [ QUOTE ]
    [/ QUOTE ]
    ditto and please add to techomatic. Great info.
    Thanks [​IMG]
  19. Duster
    Duster
    Made my 12 page copy. did not need the switch part - Thanks.
  20. thank you. this is awesome, cleared up a lot for me.
  21. Tudor
    Tudor
    from GA
    excellent - I need to get my dust caps and MC cylinder return completed! perfect timing. I like that spring idear - thanks, Tudor
  22. Zodoff
    Zodoff
    BTT ,
    Wake up, tech'o matic gods! [​IMG]
  23. PetT
    PetT
    Absolutely fantastic brake tech. First, is it copywrited or can i use it on another hotrod site that gets alot of questions about what your talking about?
    And secondly, you mention the Magnum kit. Where can one get this kit?
    Thanx again.
  24. [ QUOTE ]
    [/ QUOTE ]
    The article is in print in a magazine, but you may post a link to the HAMB on the other site if you wish.
    [ QUOTE ]
    [/ QUOTE ]
    Magnum Axles.
    SuperBell sells a similar kit.
    Pete and Jakes carries SuperBell stuff and is an ok outfit to deal with.
    As is Magnum Axle.
  25. continentaljohn
    continentaljohn
    Great tech post!!! thanks C9
    I work on a spring shop so the spring is easy [​IMG] Need a spring give us a ring [​IMG]
