gas gauge reads full
Discussion in 'The Hokey Ass Message Board' started by big-vin, Jul 7, 2010.
  1. big-vin
    big-vin
    i put in a new tank sending unit and fuel lines everything works but the gauge reads full when i turn the key on i ran a ground wire from one of the screws that hold the sending unit in to the frame any help would be great thanks vinny and i tried to do a search but didnt find to much
  2. garcoal
    garcoal
    check your ground on the top of the tank that will mess with your reading on the gauge
  3. garcoal
    garcoal
    ps did you reverse wires
  4. Slow55
    Slow55
    On my chevy a "full" means an open circuit between guage and sender.
  5. Harrison
    Harrison
    Is the tank full? :p
    JH
  6. badshifter
    badshifter
    What gauge? What sending unit? What voltage? Is it electronic or mechanical? How is it wired? You gotta give specific info to get a specific answer.
  7. stanlow69
    stanlow69
    Mine read full for 7 years until changed the gas cap. Now it works fine. Yes I drove it all the time.
  8. Mockie
    Mockie
    mine did same - 50 chevy, changed sending unit, top of old one had a short from sending unit wire to sending unit housing. Unit may have been good but after all the work of getting the tank drained and out was smart to put in new anyways.
  9. Vimtage Iron
    Vimtage Iron
    Different tests for different style/types/voltage, for guages and senders, standard old Stuart Warner is disconnect the sending wire from ga and then ground ga terminal, if it goes to full ga is good, sender is shot, Chevy on the other hand won't test like that, there is a total different way to test sender and ga.
    As Badshifter said need to know more.
  10. 510madmav
    510madmav
    bad voltage regulator. Its sticking.
  11. big-vin
    big-vin
    sorry about the info its a 54 chevy 6 volt system chevs of the 40s replacement tank and sending unit that was the same as the old one one wire runs from the gauge to the sending unit and i added a gound from sending unit mount scew to the frame
  12. Piewagn
    Piewagn
    Ding....ding....ding. Open in the circuit is my bet ( which will include a non exhistant ground ).
  13. 23 bucket-t
    23 bucket-t
    my gas gauge is broken, i have to use a stick to check how much gas i have.
  14. waldo53
    waldo53
    from ID
    Take the sender wire off at the tank (the one coming from the guage) and touch it to a good ground with ignition key on. The guage should read empty. Then, remove it from the ground and let it dangle in the breeze - guage should swing to full. If the guage works as described above, the guage and all wiring back to the tank is good and the problem is either a bad sender or a bad tank ground. If the guage doesn't work as it should, check the sender wire all the way back to the guage and make sure the guage case is grounded to the dash (you may have to sand some paint here and there to make it work)
  15. paintcan54
    paintcan54
    My T-Bucket doesn't have a gauge, 6 gallon tank, 50 miles buy gas, simple.
  16. Labold
    Labold
    My bet is on the ground (or lack of).
  17. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    With todays gas prices, I just wish mine read full :D
  18. 55 dude
    55 dude
    sounds like ground issue.
  19. big-vin
    big-vin
    thanks guys ill check it out
  20. red baron
    red baron
    from o'side
    Or maybe the float is stuck in the "up" position?
