I have a #1406 edelbrock carb on my Y-Block. It was given to me by my father-in-law and had been sitting on the shelf for a while. Since it had been running somewhat ****py I decided to do a rebuild. I rebuilt the carb this past weekend and noticed right away that it was running better. I do have some questions though as some other items have popped up. 1) I have the choke adjusted as per the kit, which is 2 notches on the lean side of the index mark on the housing. The problem is, I start the truck and before the truck has time to warm up the choke is already going wide open. Should I just adjust the choke to be leaner so that the choke won't open so soon? Is it possible for the spring inside the choke housing to go bad and open too soon? 2) There is a rod that goes through the airhorn ***embly, this is the rod that attaches to the linkage on both sides. After the rebuild I noticed that there is a little side-to-side play in this rod now. Is this play okay or should the whole ***embly be tight? I don't remember how it was before the rebuild. Thanks for your input.
1) Adjust it where it works best. Winter/Summer it will change on you. 2) No idea, I haven't rebuilt my 1406 yet.
Sorry, misspoke earlier. I have the choke set to 2 notches on the rich side of the index mark. I'll just try running it a little richer and see how that goes. Thanks everyone for your input.
