Projects 1920 T Roadster Build Thread
Discussion in 'The Hokey Ass Message Board' started by -Brent-, Apr 11, 2010.
  1. Great stuff Brent!
    Good detailed pictures of the work! :D
  2. -Brent-
    -Brent-
    Thanks fellas. Wendell is the man when it comes to welding, I couldn't have gotten anywhere without him.
    I admire good build-threads and often refer back for references. I try to emulate that since I've gotten so much from them. My photo skills could use some work since it seems like I get one of 3 photos I take to be useable. :D Maybe they'll get better with the next build? Thank god for digital cameras!
  3. -Brent-
    -Brent-
    Click on the photos to see them larger.
    This is the plate fabbed to mount the steering box. We decided to go with an A steering box with a RHD sector shaft and worm gear. The pitman will face up. I've never heard or seen of anyone to have ever do this, so, I'll let you know how it works out.
    Below are photos of the current state of the brake rods. The fronts were extended by about 8 inches.
    These bends were put in for several reasons. It keep the rods more straight and closer to the frame/body. These are NOT done. There will be steel rod (the same sized used) as gussets at the bends so that when brake pressure is applies the rod "thinks" it is straight.
    No steel to finish that today. We went on to some other projects. See some more details below of the rods.
  4. -Brent-
    -Brent-
    Next was the chopping and leaning back of the windshield. Or as Wendell put it, "Fabbing 101." I had a bunch of parts from a few different years to combine to make what I wanted.
    Those that aren't familiar with Model T differences wouldn't notice the changes, or that is, how things are mixed and matched. When it's all painted up it'll look like a chopped and leaned wind screen. Mission accomplished!
    Here's what we did.
    We took 23-25 stanchions and a great 23-25 lower frame (still has the channel for the gl***) and zipped off the stanchions at the top of the lower frame.
    Next, after some measuring. We cut off more than half of the upper frame from a late teens (to 20s?) frame. Inside this space a new threaded piece will be installed, rather than fumbling with the old pieces which were a little worse for wear.
    Although they could have been used, it'll be nice to be able to take the screws out at a later date to make repairs and such.
    Here it is, the new top windscreen frame. A little more than 3" of gl*** on the top.
    Once the upper frame was set we could figure how much to chop off the "other" stanchions. Once cut, we plopped them up there for a photo.
    The stanchions (both sets) taper toward the top. So some pie cuts needed to be made.
    Then another test.
  5. -Brent-
    -Brent-
    Both sides got the same treatment. Then, a bunch of eying and using the artistic thumb and such until we felt like things were where they should be. We did some measuring too but the "thumb" thing worked so well. :D
    Wendell tacked them up while I asked a ton of welding questions. Below are a some welded pics (before being ground down).
    Next came leaning the windscreen back. Which, to me, was the icing on the cake. It was a little tricky since the door side measure differently then the driver's on these T's. But that's where the "squinting" technique comes into play.
    After cuts and re-cuts we got the stanchions leaned back to where I wanted them. There's enough room between the gl*** and the wheel, if I were to have my hand up there.
    We took apart and ***embled the windshield at least a 8 or 9 times to get the fit correct.
    One of my favorite comparisons. Meet Wendell. :D
    After all the welding some grinding took place. The combination of the two stanchions isn't noticeable other than the top one is slightly wider. It will get softened up and be unnoticeable once painted.
    Below are a couple other shots for perspective.
    Lil'Alb likes this.
  6. Equipped28
    Equipped28
    ahh man that car is the nuts! a pre war T gow job is deffinatly on the cards after my A gow is done!
  7. lorodz
    lorodz
    sweet work..keep it up
  8. Update, update, update..... Now, Now, Now!!!! :D:D
    Haha
    Awesome build Brent it has inspired me.... I went and bought a '25 T cowl top and firewall to build a roadster I may ask for measurements so I can fab the rest. (another late 40s lakes roadster build :rolleyes:)
    keep up the great work, you'll have this done before I finish my '25 Chev
      52.4 KB
      32.2 KB
  9. Equipped28
    Equipped28
    im thinking a Gow Job HAMB Group is in order as there so many cool rides coming out the woodwork lately
  10. GuyW
    GuyW
    The rod "will think" that the force is in a straight line from clevis to clevis, because it is - no matter how many bends or straight sections are in between....
  11. -Brent-
    -Brent-
    Also, the exhaust was ****oned up.
    A few weeks ago, I had a muffler shop make a new down-pipe because the original was too thin to weld to. The 36 torque tube was trimmed and welded and below is the result.
    The last thing to get done was to open up the hole in the firewall to accommodate the Model A column.
    The column mount is going to be made from a radius rod mount on a torque tube. For now, it's floating.
    That's all for this update!
  12. -Brent-
    -Brent-
    I don't know, Jimmy. I've got a lot more to do. This is only the mock-up. Then I'll be breaking it down and prepping it for paint, some extra body work will be in order, sandblast the frame and re***emble, new wood, wiring... etc., etc., etc.
    Thanks a bunch, fellas!
    There is! Check out the Model T Hot Rod Social Group. There are a bunch of members and some cool cars, as well.
  13. -Brent-
    -Brent-
    A shot from each side of the front. Rear brake rods are tucked in well.
  14. Stovebolt
    Stovebolt
    Brent and Jimmy
    you two guys should try to meet up In August when Jimmy
    is over for bonneville!
    Jimmy is one of the most knowledgeable dry lakes guy on the HAMB, and you Brent are one of the nicest hosts out there.
    And you know that if I could be there I'd be over in a flash especially to be able to go for a fang in what is turning out to be a great gow job
  15. -Brent-
    -Brent-
    Hey thanks... and yes, Jimmy and I will have to meet up. However, my goal to have the car ready for Bonneville is not going to be met. There's just too much to do and not enough time with all the other stuff I have going on. Plus, I am really happy with the quality of the car and don't want to cut any corners by rushing.
  16. Neat little roadster man!
  17. -Brent-
    -Brent-
    Thanks, Tman!
  18. No_Respect
    No_Respect
    from So-Cal
    wicked! looks like you will be tearing up the salt soon!
  19. modelAsteve
    modelAsteve
    A thought on the steering: the stock Model A is a press on- could you rotate it 90 degrees or flip it up side down or both or?????
    To much for me to figure out- help!
  20. -Brent-
    -Brent-
    I ***ume you're talking about the pitman arm? Yes it can be switched and, at the moment, it is. However, switching the pitman from the down position to the up postion reverses the action of the box. Meaning, when the pitman faces up and I turn the steering wheel to the right, the car will turn to the left. :D
    The RHD (Right Hand Drive) steering parts "should" take care of the above-referenced issues.
  21. Mark H
    Mark H
    from Scotland
    Great work,as usual!
    Like what you did with the windshield,very cool.
  22. benchseat4speed
    benchseat4speed
    from Golden, CO
    This roadster is ****in sweeeeeet.:cool: I read this one like my grampa reads the paper.....everyday.
  23. -Brent-
    -Brent-
    Thanks Mark. And Kev, thanks for the compliment, I'm sorry I can't update it often so you're not reading old news...hahaha. By the time this one is finished... this fall, hopefully, I'll have ALL the parts for the next roadster project and that one will go faster.
    I like this budget building stuff! :D
  24. V4
    V4
    Excellent project from top to bottom, front to back.
    Where is the source of the RHD steering parts? England, Oz, NZ, or?
    And what it takes to do the conversion?
  25. zmcmil2121
    zmcmil2121
    Looks good, I believe I to taught you well... even though we have never met... and I never really taught you anything... I just feel that it tied the post together well because I already posted... :rolleyes:
    But in all seriousness, it is really coming together nicely and I cannot wait to see it finished. Your rode has influenced me so that one day, a long time from now (when I have the money) I will rod a early 20's roadster. The only bad thing I have to say is that you go too slow for us impatient people who can't wait to see this bad boy done. Way, WAY too slow.
  26. -Brent-
    -Brent-
    Hahaha... thanks for the timeless lessons!
    Don't worry about the money, seriously. This car is more about history lessons and p***ion than money. A lot of these parts are parts people wouldn't want these days. They just happen to fit a time period when combined made something faster than what was available to farm boys and such.
    Thanks for the compliment... and for the kick in the pants. Just know that you're not the only one, I've been getting prodding from around the globe, hahaha. Although it's meticulous work, I know the next stage will progress a lot faster.
  27. -Brent-
    -Brent-
    Snyders has the sector shaft and steering gear. I did find a place in Oz for the parts but don't have the link handy at the moment. I don't have the parts in hand yet, so I am not sure if the parts are comparable yet. When I find out, I'll be sure to bring that info here.
  28. MrModelT
    MrModelT
    Brent,
    Excellent work my friend! A very impressive build that I have been following with much enjoyment. You have built a unique and impressive car with allot of ingenious design work....and it is so nice to see someone else building a T in this early period besides me! :D
    Keep up the great work!
    Clayton - MrModelT
  29. -Brent-
    -Brent-
    Hey all...
    This weekend, the mock-up should be mostly finished. I've got some NOS Chevy oil tube shocks for the rear and a box from Mac's with all my RHD steering parts.
    Progress pics in the next update!
  30. 41 Dave
    41 Dave
    Brent, The "T" is really getting close. Hope you get it on the road. I have had Bonneville on my"Bucket List" for a while. I should be there. Only reason I don't make it is if my wife's left hip gets worse. She is in so much pain. The physical therapy just seems to irritate it.
