36 3 Window Going to Paint - photos
Discussion in 'The Hokey Ass Message Board' started by 58Lincoln, Aug 9, 2009.
  1. Sixguns
    Sixguns
    Right on 36, The skin does good, you will like. you made some great choices.
  2. 58Lincoln
    58Lincoln
    A little progress update here.
    While the body was on the rotisserie, Lizardskin was applied to the bottom of the body, also to the rear inner fender wells, the inside of all the fenders and the bottom of the running boards. The firewall was body worked for final paint, as well.
    The final coat of dark blue exterior paint was applied to cover all the areas that had Lizardskin and the firewall received it's final finish coat of exterior blue paint too.
    The body was put back on the chassis, ready for final exterior paint.
    I also had all the window glass cut to my patterns and installed in proper chopped windshield frame and NOS Ford glass channels.
    It's getting closer.
    Here are a few photos. Even though there is a thick layer of dust on the firewall you can get an idea of the exterior dark blue paint color.
  3. junkyardgenius
    junkyardgenius
    from Kernow
    Gteat stuff, keep us posted.
  4. I think the 36 three window Ford was the most beautifull style that old Henry ever built. I envy you.----Brian
  5. 50Fraud
    50Fraud
    VERY nice. Good color choice, and I think the maroon interior will look great in it.
  6. seret
    seret
    lookin good!
  7. silverdome
    silverdome
    What a BEAUT! That '36 is going to be great. I'm afraid I would be scared to drive it, because it looks like it'll be showroom fresh. But I live on a gravel road and some people drive like a bat out of hell without a thought as to throwing rocks on nice cars.
  8. the car looks good....its getting me motivated to start mine now....
  9. 58Lincoln
    58Lincoln
    Here are the latest progress photos.
    Need to do a little more cut & buff and paint about 15 small interior pieces.
    Also, I now have EVERYTHING needed to do the wiring.
    We're getting close.
  10. Big Nick
    Big Nick
    THat car is so BAD!
  11. Looking good. Just started on paint with mine.
    Is it black? Looks blue and even purple in some shots!
  12. 58Lincoln
    58Lincoln
    The color is a custom mix midnight blue, single stage paint.
  13. rustyhood
    rustyhood
    That is Bad Ass!
  14. reefer
    reefer
    2.5" chop looks spot on...the stance is right...real nice car...keep posting updates, the maroon interior sounds like it will work nice.
  15. 58Lincoln
    58Lincoln
    Time for a project update.
    A couple of weeks ago I spent a few of days at the paint shop with the guys putting the sheet metal back on the body.
    The trunk lid and door gaps are really good and the front end, including the 4 piece hood, came out great, especially for a 36 Ford.
    I then moved the car back down to my buddies shop to finish the build.
    Been pretty busy since the first of the month putting the rest of the car back together.
    No matter how well you mock something up, there are still plenty of things left to do.
    Here are a bunch of photos from a few weeks back.
    The dash "waterfall" came out good.
    The steering wheel is painted the dark red interior color with the 2 ribbed areas on the spoke painted the exterior blue.
    The body and paint guys, Altissimo in Napa, CA, did a great job. The car looks beautiful.
    The dark blue color really needs to be seen in person.
    That's it for now.
  16. poorboy
    poorboy
    Looks excellent!
  17. shoebox1950
    shoebox1950
    wow! looks nice!
  18. hellonwheels
    hellonwheels
    from Bastrop
    Wow, that looks fantastic! Been following your build for a long time, you should be proud, that car is hot!
  19. Hot Rod Michelle
    Hot Rod Michelle
    ¡Muy bueno! My dream car.
  20. 50Fraud
    50Fraud
    Beautiful. Let's see it in the sunlight with the whitewalls on it.
  21. mopargnome
    mopargnome
    Same here!
  22. Tindall
    Tindall
    looks real clean...great stance
  23. kool32
    kool32
    from Kentucky
  24. bonesy
    bonesy
    Looks great. The interior and exterior shades look great!
  25. scotti32
    scotti32
    Wow, that is gonna be beautiful.
  26. 58Lincoln
    58Lincoln
    A lot of work has been done since my last post.
    Although I had done a thorough mock-up, it seemed like I had to redo quite a bit.
    The wiring job, with an EFI controller and electronic trans controller and my use of weather pack connectors took a bit longer than I expected, but everything is working as it should now.
    I started the engine about a month ago. The A/C system is charged and working well. Everything in the dash is working properly and the brakes and steering are OK.
    I FINALLY drove the car for the first time last week.
    At 1/4 throttle it breaks the tires loose shifting gears, and thats with a automatic trans. It is comfortable to drive and cruises great on the freeway. It sounds pretty radical at idle.
    I want to put a few miles on it before I really open it up.
    I plan on taking it to the upholstery shop just before Thanksgiving.
    Hopefully this 4+ year project will be "completed" soon, because I can't wait to drive the wheels off this old Ford.
    Here are some progress photos.
  27. 50Fraud
    50Fraud
    Very nice. It looks a bit like my old '36:
    Unfortunately, the current owner has changed my old car a great deal.
    Are you planning to run hubcaps?
  28. hasty
    hasty
    Looking good. Really nice chop
  29. Rude Dude
    Rude Dude
    Pretty sweet paint got your monies worth!!
  30. HotRodHighley
    HotRodHighley
    from cincy, oh
    looking great. can't wait to see the final product.
