Projects The Tale of Two 49's
Discussion in 'The Hokey Ass Message Board' started by Chopped50Ford, May 20, 2010.
  1. Luke__805
    Luke__805
    I also think that part of it is that a lot of the pics are taken from a diagonal angle so it really makes it stand out more than it does at any other angle. I found a good pic of from the side and it really is kinda subtle from the side profile.
  2. Luke__805
    Luke__805
  3. MarkS1975
    MarkS1975
    Looking good dont you just love the smell of Argon in the morning!
  4. Johnny C.
    Johnny C.
    Great work. Both cars are turning out really cool.
  5. gorgeous!, gives me hope that witha little hard work and elbow grease i can straighten out the ****ty chop my chevy has and get it looking just how its should!
  6. captainjunk#2
    captainjunk#2
    i tip my hat to you , thats some excellant repair and fabrication work , awesome
  7. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Work continued on Shoebox #1. The upper crowns at the upper corners of the rear gl*** are being formed and tacked in place. Some might ask "why do it in several pieces?"... Its actually easier, and the shaping of the panel can be more accurate. We do add/finish the roof off with 18ga, which is similar to stock. It can be tough to work with on the english wheel, so smaller parts make it easier during the fabrication process.
    The lower sections and the continuation of the rear panel below the rear window to be started tomorrow. This should be all tacked in, in the next few days.
    Stay Tuned!
  8. Johnny1290
    Johnny1290
    Very humbling. Wow.
  9. Finnrodder
    Finnrodder
    from Finland
    Nice work and thanks for posting those rocker pics.I guess they may help me a bit with my project.
  10. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    KILLER Work ! ! Don't you just Love cuttin' **** Up ! ! !
  11. Theo Douglas
    Theo Douglas
    Wow! Great work. I have to say, I'm leaning toward shoebox #2, but they're both really cool. And I like the flipped rear window. Nice touch.
  12. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Were off to repairing the windshield surround on Shoebox #1. It had alot do be desired. There was no way gl*** was going to fit in it properly without breaking.
    Both the A pillars were re-cut. Old lead was heated and removed. Its amazing that some folks think that lead is a good filler, it is on 'old school' terms to skim or lightly fill, but not in the forms of 1lbs per square inch. :) ... and not if the panels aren't properly aligned.
    The upper and lower corners were cut out so both upper and lower pillars could be moved for re-alignment.
    You can see during the process and measuremnts, it needs repaired.
    Here we go!
    B-Pillar realignment.
  13. captainjunk#2
    captainjunk#2
    nice repairs , you got your hands full fixing someones screw up for sure
  14. clifforddean
    clifforddean
    I'm gonna be movin in 29 days and can't wait to unpack all my **** and get busy on my shoebox. Sure is nice to see you guys gettin busy outside and kickin out quality work. Nice job.
  15. Keep the updates coming! This is great stuff.
  16. freebird101
    freebird101
  17. Tony Ray
    Tony Ray
    wow.. thats all I can say...
  18. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
  19. Deu55
    Deu55
    Great work both shoeboxs looking bad as..keep the pix coming...
  20. need louvers ?
    need louvers ?
    Good looking stuff! Nice to see someone else working out side under a canopy like my self. I've been jokingly calling myself "hajji Babba's hot rods" for the last couple of years now. My louver press has always taken up the lions share of my shop, so fabrication is usually done outside under cover. By the way, even though my louver shop has been around as a part time thing for many years, my reason and philosophy behind the fabrication end is the same as yours. I too seem to spend lot's of time undoing the mistakes of others. Good work.
  21. Itchy
    Itchy
    Man this makes me miss my 49 sedan. You sure make this stuff look easy......
  22. Hotrod95
    Hotrod95
    Oh man. Shoebox #2 looks killer!!!! The other one is coming along nice! Great job man!!
  23. shoebox50
    shoebox50
  24. shoebox1950
    shoebox1950
    Nice work...it's never fun fixing other people's previous mistakes.
  25. Luke__805
    Luke__805
    Can't wait to see the further progress on my shoebox, the more work Norm does on my car the more astounded I am by the quality of work he does. Top notch!
  26. elrobo818
    elrobo818
  27. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
  28. Luke__805
    Luke__805
    Norm, just was finishing up the custom floor on my shoebox (shoebox#2) Car now has a 16 gallon tank instead of a fuel cell, like it had beforehand. Also has all kinds of trunk space and provisions to run a rear seat which it didn't have before. The custom grille surround is in progress, it'll be a merc style surround w/ rounded hood corners, and the car is having 51 hinges modified to work so that I don't have to run exterior trunklid hinges like it originally had.I'm so happy with all the work Norm's done on my car and am excited to see it turning into the custom that I've always wanted
  29. Johnny1290
    Johnny1290
    Man I went from a cell to a 16 gal mustang tank like yours. It eliminted a ton of h***les and freed up lots of trunk space.
    If you need a used filler pipe I've got extras, also a really cool bob drake flexible filler hose goes between the tank and the pipe $24 and it makes it way easier to fill the tank. I gotta pick one up!
  30. billys54
    billys54
    Great work, keep posting.
