A Arm funnycar suspension
Discussion in 'The Hokey Ass Message Board' started by dragster, Jul 13, 2010.
  1. dragster
    dragster
    My question deals with the front A arm suspension of a funnycar ch***is. What is the size of tubing used in the fabrication of A arms front suspension in a funnycar ch***is?
  2. Nitro crew chief
    Nitro crew chief
    from Illinois
    I'll check on our car. it might take me a day or so, the shop is 20 miles from me.
  3. gasserjohn
    gasserjohn
    mark williams &other company's have kits for sale giving specs&jigs for setup
    nhra hand book?
  4. CH3NO2JAY
    CH3NO2JAY
    from Chicago
  5. spoons
    spoons
    from ohio
    ask Rooman....he might have an idea since he builds TF cars
  6. lippy
    lippy
    from Ks
    Or you could run aluminum A-arms. :D
  7. dragster
    dragster
    Thanks for the response ,my ch***is is 85% done but still needs the front suspension and rear 3rd menber to be fabercated .I was useing a straight axle but trying to the a-arm set up thanks
  8. lippy
    lippy
    from Ks
  9. gasserjohn
    gasserjohn
  10. rooman
    rooman
    Actually SFI could care less about what holds the car off the ground. All that the SFI specs cover is the construction of the part of the ch***is that surrounds the driver (and a few other sections in the case of Top Fuel).
    Most floppers that I have had anything to do with use 1.125" or 1.25" for the upper leg and .875" for the lower (double) section.
    Roo
  11. dragster
    dragster
    thanks for your help Roo
