what is the fuel gauge ohm's for a 68 camaro?
Discussion in 'The Hokey Ass Message Board' started by deerchooper, Jul 16, 2010.
  1. deerchooper
    deerchooper
    i would like to know what ohm range is the 68 camaro?
    im going to buy a sending unit but i dont know which kind.
    thanks
    terry
  2. thadeal4real
    thadeal4real
    from FRESNO, CA
    i believe it takes a 0-90 ohm sender like 99 % sure hth
  3. deerchooper
    deerchooper
    i hope your right.
    just for peat sake. i also have a question about wiring it in.
    do you run a hot wire to the sending unit, return to the gauge, then ground?
  4. thadeal4real
    thadeal4real
    from FRESNO, CA
    i believe the ground is internal or on ring basically and just 1 wire goes to the sender from gauge
  5. deerchooper
    deerchooper
    i plan on using a 68 camaro gauge pod in my ride(older car) with an aftermarket fuel tank. the camaro guage pod has 2 hook ups and so would the sending unit.
  6. power to gauge gauge to sender then ground. I think 90 0hms is correct
  7. TagMan
    TagMan
    Absolutely 0-90 ohms.
  8. Retrorod
    Retrorod
    I just looked at an old shop manual...90 ohms is correct.
  9. deerchooper
    deerchooper
    thanks everyone.
    ill test it tomorrow
