Is this Ford rear end a 9" ? (picture)
Discussion in 'The Hokey Ass Message Board' started by corndog, Jul 21, 2010.
  1. corndog
    corndog
    from Indiana
    Gong to an auction this weekend that has lots of Ford rear ends. Kinda like this "round center" one but unsure if it is a Ford 9". Can anyone tell from this picture? Thanks in advance. :)
  2. It sure looks like a 9 inch from here but the real clue is the chunk to housing bottom bolts. If you can put a deep socket on the bottom nuts/studs it's an 8 inch. If not it's a 9 .Looking at the perches and housing that is an old one.
  3. hotroddon
    hotroddon
    From what I can see in that picture, it looks like a 57 wagon 9" rear
  4. Brahm
    Brahm
  5. If you can't get a deep socket on these it's a 9 inch.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It looks like a 9" roundback to me - a desireable piece because of their intrinsic esthetic beauty. The '81 Bronco rear end in my champ car is also a roundback 9". To which I grafted a Winters quick-change.
  7. artythefarty
    artythefarty
    from Yakima, WA
    Hey Ratmotor, Great tip with the deep-well socket and the 8"-9" Ford 3rd member ID. Very simple and easy to explain. Even a caveman could do it !
  8. Deuce Roadster
    Deuce Roadster
    Check and see if it has a bottom drain in the lower section of the housing. Right on the bottom. Every 57 Ford 9 inch I ever had ... had the drain plug. I have owned well over 2 dozen 57 Ford 9 inch rear ends. :D
