Projects Satin's 58 Impala update (grille mod/install)
Discussion in 'The Hokey Ass Message Board' started by Satinblack, Jul 23, 2010.
  1. Satinblack
    Satinblack
    Well been a few weeks, been busy on modifying a 59 buick grille to install into the Satin 58 project. Actually takes 2 full buick grilles to build this since the impala opening is much larger. Had to learn to weld pot metal and then I started cutting and welding. The plan for my dream car always included a 59 buick grille. So here it is, next thing is mark holes to bolt in and polish and paint grille. Apron and such will go to powder coater soon. Hope you like it
  2. henry29
    henry29
    It does look pretty good.
    What are you planing on doing for turn signals/ parking lights?
  3. Satinblack
    Satinblack
    Ah good question, like my old panel project that Kenny bought and went to England, I prefer the bulb be mounted behind the grille so when they come on you see blinking light emitting from the grille, more sinister in my opinion
  4. Damelot85
    Damelot85
    I like, how wide is the Buick grille to start??
  5. Satinblack
    Satinblack
    The buick grille is 50 inches across stock. To fit the impala I had to extend it to 70 inches across. I also filled in the notched area at the end where the buick would normally have the bumper/turnsignal light. I used the actual end pieces so the grille would have a stock look. I have to cut the mounting tabs off on the center two tabs then lower them so they match the stock impala cross piece, then all the mounting will look as if stock also
  6. Squablow
    Squablow
    Looks nice, fits like stock. How do you weld pot metal?
  7. Satinblack
    Satinblack
    Muggyweld makes a low heat rod, its more like soldering really although I use a oxy/ace setup. Works very well I might ad and you can get it chromed afterward too. go to
    muggyweld.com
    Real nice guy
  8. reece
    reece
    from NC
    Damn that is nice!
  9. hemifarris
    hemifarris
    Looks good. Any pics of the rest of the car?
  10. ChromePlaterJosh
    ChromePlaterJosh
    I like the grill! It looks like it could have been stock.
    I have actual experience plating muggy weld. It is a bit fickle, but it is plateable. Good for the DIY guy. Not economical for a plater welding pot metal all the time.
    Platers will copper strike (a cyanide based thin basecoat of copper plating, usually about 2-5 minute plate) the prepared (stripped, sanded) pot metal and then use a regualr solder to do the welding. I personally use lead-free silver bearing solder with oxy/acetylene torch. It plates easily (silver content helps that point) and has a higher melting point than the lead solder (helps keep solder from melting under the thick copper plating during copper buffing.) The elimination of lead in the shop makes me feel good too.
  11. Satinblack
    Satinblack
  12. Damelot85
    Damelot85
    Thanks for the info. I think it would be exact kind of look I am going for my in my 59 Olds wagon.
  13. 59IMPALER
    59IMPALER
    Great grille idea, just when you thought all the tricks were used up. Is the car called "Satin Impala" because of the suede finish yet to come? Or is it "Satan's Impala" because it's bad*** ?
  14. Satinblack
    Satinblack
    Well its Satin as in Satinblack, my original idea was satin black, but tons want it gloss. Ill just say i'm gonna go with my heart and leave it at that. Hopefully all will appreciate it when its done
  15. Dat Dirty Rat
    Dat Dirty Rat
    Damn it dude 1st the Keystones..(i know your a lucky ******* with Radars)....now similar grill treatment...i give up.... lmao...but we both know them are as bad*** as it gets...My favorite one is that copper/bronze one that was ont the cover of that one old school mag...you prob seen it too...Anyways, looks good man & keep up the good work!!
    Anyonw interested in a couple buick grills :)???
  16. Satinblack
    Satinblack
    Dat! YOu gotta be kidding me right??? ROFL
    **** we gonna have to set up a east meets west thing
  17. Cruiser
    Cruiser
    Looks 100% better then the stock grille, very cool looking. What will you be doing outback?
    CRUISER :cool:
  18. LSGUN
    LSGUN
    from TX
    Love the grill, keep the pics coming!
  19. Satinblack
    Satinblack
    Good question Cruiser, I'll be starting that project next. Don't want to spoil the surprise but I will say it will NOT have the usual 59 caddy tail lights :)
  20. lawman
    lawman
    Looks very nice !!!! In my area finding one 59 Buick grill is very hard
    BUT finding two is a "No way in Hell" !!!! LOL Tom ( Tired Old man)
  21. kennyboy
    kennyboy
    from uk
    hi bud
    yes i have still got the blinker bulb inside the grill ,yes it is more sinister looking, your ride is looking kool i will follow your build with interest
    kenny
