Hi all, I have a 32 es*** terraplane, the front end is parallel leaf springs and a drop axle, does anyone know what spindles would fit on the 32 axle? Thanks Rob
Do u want drums mor discs? If u want drums ford f-100 drums will work will go right on your axle king pins and all!
i think he thought you had 32 ford spindles, f100 spindles will fit on a ford , not sure with an es***,
Thanks, tomorrow I will have to take the measurements as you stated. I was thinking of using the parallel leaf suspension
