Our ugly welded in Nova clip
Discussion in 'The Hokey Ass Message Board' started by dubie, Jan 25, 2005.
  1. dubie
    dubie
    Here are the pics of the Nova clip that was welded into our 58 by the previous owner 14 years ago. YUCK!!
  2. dubie
    dubie
    anothe rpic of the other side. You can see the ugly fish plates on there
  3. monsterflake
    monsterflake
    damn, how high does that sit?
  4. carmerlin
    carmerlin
    from west texas
    SON OF A BEACH THATS UGLY. It must look like a 4x4. Time to start over. Keith
  5. dubie
    dubie
    There is 12" of difference between the truck frame and the Nova subframe. And the guy drove it like this for 12 years man!! friggin crazy. This is why I am looking for pics on how to do it properly. I am also looking at swapping the chassis out for the spare 72 pickup chassis I have.This is the worst weld in I have ever seen
  6. dubie
    dubie
    oh, here's a pic of the truck before we started tearin it down. He never even had the front wheels centered in the wheel well
  7. KoppaK
    KoppaK
    Yikes you sure that's welded...nasty
  8. flamedabone
    flamedabone
    MAN! That thing is tall. No offence..
    Here is a quick shot of the GM clip in my Studebaker. The two frames are welded to each other then I welded boxing plates to go completely over the joint.
    There are lots of pros and cons to a subframe job. LOT of stuff to know..Holler if you need any help.
    -Abone.
  9. monsterflake
    monsterflake
    ho-lee shit, you didn't mention the GOLD package! now that's some serious bling!
  10. flamedabone
    flamedabone
    PS. Here is a shot of my beater truck. It was taller than yours when I drug it home. I didn't put it all the way on the ground, cause I still have to haul stuff and bang around junk yards with it.
    Pretty solid little truck you have there, BTW.
    -Abone.
  11. dubie
    dubie
    HAHAHA bling bling. That gold will be gone, we are having all that crap chromed.
    Damn, that beater is sweeeeeeeeet!! That is the same stance we eant on this 58. How much of a drop was put on it? I have always wanted a shorty 60-66 ford/merc. A buddy's ol man had one that he gave to his brother in law who in turn chopped it in half and made a garbage trailer out of it. That truck was in nice shape to!
    I actually saved that pic og your truck when it was posted in the shop trucks post a couple months ago. Gotta love ol skool!!
  12. A clue that I have used on Nova-type subframes: Cut off those nasty 'legs'. Massage the OEM frame to meet the sub fairly well. Box the OEM frame if it is a 'C' section. Cut the sub approximately 1 foot rearward of where it meets the OEM frame. Cut along each corner of the sub and peel like a banana. Slide the OEM frame into the sub. Roll the 'peels' back and seam weld ALL joints. Fishplate if you want, but usually not necessary as you will end up with around three foot of weld on each side, which should be strong enough [​IMG]
    Oh, measure that bad boy eleventy-seven times, and at least twice after you start welding, 'cause sh*t happens.
    Cosmo
  13. CharlieLed
    CharlieLed
    When I subframed the Merc I peeled the Vette frame back like a bannana and laid it over the Merc frame. Once everything was fitted I began welding and folding...here's what it looked like while fitting...
  14. CharlieLed
    CharlieLed
    Here's the finished joint...
  15. Crosley
    Crosley
    from Aridzona
    that is nasty.
    I've seen some camaro clips bolted onto the stock frame of 55-57 chev trucks.
