Need some help with my 46 Ford 2 Door Coupe
Discussion in 'The Hokey Ass Message Board' started by wildfan1833, Jul 22, 2010.
  1. wildfan1833
    wildfan1833
    from Minnesota
    New Question. I can't seem to find any rims to fit the car. Anyone know what size the bolt pattern is? I have been told it's a 5 1/2" But I measure it out to be 5 1/4". Thanks, Cole
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Check with Dennis Carpenter Ford Parts in Charlotte NC or the Duck (Bob Drake) in Grant's P***, Oregon. They should bolt kits for everything for your car.
  3. wildfan1833
    wildfan1833
    from Minnesota
    Thanks for the information
  4. wildfan1833
    wildfan1833
    from Minnesota
  5. jetmek
    jetmek
    ***uming its stock..it is a 5 on 5.5 16"x4" wheel. shouldnt be too hard to find some good ones...
  6. windjammer
    windjammer
    from Illinois
    Try Ford PU rims.
  7. wildfan1833
    wildfan1833
    from Minnesota
    Thats what we thought. But we tried the rims that were once on my dads ford ranger and they don't fit. From what I know the front and rear ends are stock. They have 5 bolts. I took on of the drums off and I think I'm just going to bring them to a junk yard and see if they have anything. I just need some junk rims and tires to have a rolling chaise. If anything we might just drill new holes into an old set of rims.
    How do you measure the bolt pattern? Is it center of the lug to the center of the lug across from it?
  8. arkiehotrods
    arkiehotrods
    The bolt circle is measured by the cir***ference of a circle drawn through the middle of all bolt holes. So you measure from the center of one bolt hole straight across the rim to an imaginary arc between the two bolt holes opposite the first one.
    The bolt circle is 5.5 (aka 5 X 139.5mm). Here are some vehicles that used the 5 X 5.5 wheels:
    Ford F100/F150 late 1940s-1996; some F100s c. early 1980s have the 5 x 4.5 bolt pattern
    Dodge Ram 2WD pickup/van 150/1500 1986 - present
    Jeep CJ to 1986 (includes J-series 1/2 pickups to 1973)
    International Harvester 1/2 ton pickups incl. Scout SUV to 1980
    pre-1960s era Mopars
    Lincoln RWD to 1960
    Toyota Landcruiser early 2000s
