corvette rear end wheel fit headache
Discussion in 'The Hokey Ass Message Board' started by 46chevyrat, Aug 1, 2010.
  1. 46chevyrat
    46chevyrat
    from Deland FL
    I was just wondering if anyone had ever put a smoothie wheel on a corvette rear end, I want to use a set of 15x8 smoothie wheels but I don't know if they will fit. anyone ever tried? The backspacing is 4" I think and the inside of the rim toward the caliper has to be at least a 14" diameter. 5 on 4.75 bolt pattern, 2.75" center hub and I don't know what offset would work, but I think it has to be 0 offset or in the negatives. I have called every so called know-it-all wheel guy around and nobody seems to know anything about the mystical dana 44 corvette rear, and btw; no I am not putting smoothies on a vette, it just happens to be the rear end somebody stuffed under this ch***is I picked up. I would really appreciate the help guys, thanks!!
  2. fms427
    fms427
    What year Corvette? If it is a C3 rear (63-82), the production wheel was 15X8 - 4" backspace - so you would be OK. Corvette caliper sticks outboard of the wheel mounting surface, so wheel contour is important - many alloy wheels interfere, but most steel wheels clear.
  3. 46chevyrat
    46chevyrat
    from Deland FL
    Thanks fms, I got this ch***is with some old kidney bean aluminum rims on it, great rims to be sure, but my truck is a bit old school for them, I have been hunting for about three weeks now to find a set that fits or some info on the "smoothies" from summit, but to no end. I guess I can order one and see if it works... The backspacing on the smoothies is 4" so I should be ok.
  4. racemad55
    racemad55
    Ran western wheel smoothies on an 80' vette rear in my deuce 15x8's ,no problem
  5. 46chevyrat
    46chevyrat
    from Deland FL
    I have never hheard of western wheel, do they have a website that you know of? Googled it but nothing related came up. Also, are the smoothies from western the same as wheel vintiques, if so then they might fit.
  6. 46chevyrat
    46chevyrat
    from Deland FL
    I am guessing since I found the western wheel site and they dont show prices that I probably don't want to know how much they cost, may have to stick with wheel vintiques.
  7. racemad55
    racemad55
    Didn't know they were still in business,this was back in 80-81 ish!
  8. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I have American Racing Daisys from 1967-ish on my C4 rear. Fit perfectly
  9. If its a dana 44 it is probably C4 84-96 Vettes. Does it have a fibergl*** monoleaf spring ?
