clutch fork question??
Discussion in 'The Hokey Ass Message Board' started by 40hemicpe, Jul 31, 2010.
  1. 40hemicpe
    40hemicpe
    from anaheim.ca
    i have a heavy duty clutch fork part number 14066235..gonna use it in a 57 chevy specific bellhousing gonna modify the bell and fork.my question is how much travel is needed?? running a hydralic clutch so running a slave cylinder.how much travel does it need to move the throw out bearing??
  2. 40hemicpe
    40hemicpe
    from anaheim.ca
    today modified the the clutch fork now i got a lot of movement.with the fork arm forward toward the front of the motor to all the way back toward the trans is about 2 1/2 inches is this enough?/?
  3. gas pumper
    gas pumper
    Sounds good. but you really need to fit up the flywheel clutch t/o bearing etc. so you can see if not only the lenght is OK. whichit is you need about 1 inch to 1 1/4 on the outside end of the arm.
    But you also need to see that the relationships are right for it to work without anything interfearing. and give you the 1 to 1 1/4 movement.
    BTW the T/O bearing only has to move 3/16 to 1/4 inch once it hits the PP.
  4. 40hemicpe
    40hemicpe
    from anaheim.ca
    thanks for the reply has been awhile since i messed with this combo/style.. also when i make my bracket for the slave cylinder do i set it up to where the cylinder rod is pushed in half ways with the fork end or all the way in ??
  5. gas pumper
    gas pumper
    The last one I did, was a pull type cylinder,
    So I set it up for the clutch to be in engaged position with the cylinder all the way out. So it pulls in 1 1/4 inches and the clutch releases.
    A push cylinder would be set with the clutch engaged and the cylinder all the way in. Than 1 1/4 inches later the clutch is released.
  6. 40hemicpe
    40hemicpe
    from anaheim.ca
    thanks this is the info i needed.:D:)
  7. 40hemicpe
    40hemicpe
    from anaheim.ca
    also what about throw out bearings i here there are 3 sizes.i will be running a diaphragm clutch wich one will i need????
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Bent finger diaphragm old BCA # was CC1705C ,flat diaph. old BCA #1697C .First # is short 2nd the long one.
  9. 40hemicpe
    40hemicpe
    from anaheim.ca
    cool thanks...
