1952 Chevy Sedan what manifolds
Discussion in 'The Hokey Ass Message Board' started by Yanksta, Aug 5, 2010.
  1. Yanksta
    Yanksta
    Everyone,
    I am sure this has been covered before i but i cannot find a definite answer. I am putting a 350 in my 1952 Chevy sedan and i am using ch***is engineering mounts. I also have stock front suspension. What manifolds will fit this perfect where they will not run and the exhaust pipes can be run. I have a few junk yards that are full but i want to be able to go straight to what i need and get them. Not bring some home test fit. Can you give me years of the vehicles to please thanks for everyone's help!!!
  2. 53sled
    53sled
    from KCMO
    ram horn p***enger side,
    305 HO or some 80s truck driver side. needs to dump straight down between 5 and 7.
    top one with br*** pipe plugs (same as used on s10 v8 swaps.
  3. Yanksta
    Yanksta
    Sorry im stupid what is a ram horn? i take it this one dumps out the back? I have seen alot in the junk yard that both dump out the back?
  4. Yanksta
    Yanksta
    would have helped if i would have scrolled down to see the pic see i am stupid. Can you email me this pic so i can blow it up big mwinchel@cvproducts.com thanks.
  5. 56sedandelivery
    56sedandelivery
    We did the same swap to my 51 Chevrolet Business Coupe, now my nephews car. We used 94 Chevrolet Caprice LT1 Cop Car exhaust manifolds. The trick is to use manifolds that go OVER the plugs rather than BELOW them. The old 55-56 exhaust manifolds work very well also. Getting back to the LT1 Caprice manifolds, they are rear dump and have upswept runners, and almost look like big block MOPAR manifolds. They have independent runners, so they're almost like headers. We removed the tin covers from them, brazed up the AIR injection ports, and drilled a couple extra holes so they would bolt to "older" heads. They are designed to be used with the "newer" 7 bolt heads. They look good, the car sounds good, and I'm sure they're good for a few extra horsepower over other manifolds. Sorry, no pics, but we also used Ch***is Engineering mounts. Rams horns will only work on the p***enger side of the engine, the drivers side requires a front or rear dump to clear the steering box. So basically, any manifold that has over the plug runners and end dumps will work. You will have to modify the front firewall body supports for clearance. Butch/56sedandelivery.
  6. Yanksta
    Yanksta
    Thanks for the help and i am having a pair of these caprice lt1 headers delivered today. These are hard to find luckily a buddy of mine owns a junk yard and just this week a 95 caprice came in. I am kinda confused about the 7 bolt u talked about when i look at these online they look like 6 bolt and even the gasket is 6 bolt can you shed a little light on this thanks again.
  7. miller
    miller
    from New Jersey
    I may be wrong but I think there is a v8 chevy pick up ( what year s is not known ) thay have manifolds that dump on the back ends,..easy enough to see....Miller
  8. 49ratfink
    49ratfink
    I had some 1970 (?) Chevy truck rear dumps on my 49 sedan with stock suspension and brakes. pedal got a little mushy and the brake pedal arm eventually hit the rear dump exhaust before the pedal went its full travel. this is not good if you want to stop before hitting something.
    ended up going with Sanderson header$ $$$$
  9. atomickustom
    atomickustom
    I have a 1994 Chevy 3/4 ton pickup 350 in my garage and it has rear dump manifolds, but I don't know if they'd work in a '49-54 Chevy. They do not look like good performance manifolds, though: pretty small internal p***ages.
  10. 53sled
    53sled
    from KCMO
    I found a non egr manifold that I used on the driver
    side. chevy trucks had em for years. Early ones don't have the holes as seen here.
    I see them all over at swap meets for $10.
    87-92 camaro has the same design, but you plug the egr holes.
