My 60 F100 as it sits!
Discussion in 'The Hokey Ass Message Board' started by HotRod60F100, Jul 16, 2010.
  1. nutajunka
    nutajunka
    All it needs is a gun rack. :D
  2. HotRod60F100
    HotRod60F100
    A few new shots of it. Today I removed the twisted rear bumper. I'm gonna pressure wash the **** out of it top to bottom tomorrow then I'll start on the engine removing the generator,Rad. & carb and see about fixing all 3.
    You ever notice how the front of a 1960 Ford truck looks like a Checker cab? lol
  3. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Man, that bumper really took a beating ...
    I had a 292 in my '60 F100. Awesome motor. The sound through dual Cherry bombs with long tailpipes was amazing. The '60 heads have tiny valves. The hot ticket is the '57-'59 heads. The '56 heads have valves smaller than '57-'59, but I believe they're still bigger than the '60. I happen to have a pair of '56 heads that I'm not doing anything with.
  4. DanIam
    DanIam
    I have a couple really nice 60 grilles, as well as the trim pieces. Let me know if interested.
  5. krackerjack88
    krackerjack88
    from Fresno,Ca
    Does it sit like that because the springs? Or the frame?
  6. grovedawg
    grovedawg
    from Heber, UT
    Keep the Y! You can get stock rebuild parts from a lot of places if you look. You can also get performance parts through John Mummert's Website. There is a Y block Forum Here. Really cool truck man. Keep posting your progress!
  7. TexasDart
    TexasDart
    Your cousin has some nice old stuff in his yard....good luck on the truck. I think it is pretty cool to come with a V8...most were the inline 6.
  8. HotRod60F100
    HotRod60F100
    the p*** tires low plus the front springs broke too.
  9. 510madmav
    510madmav
    solid truck!!
  10. slickscustoms
    slickscustoms
    so did the truck come from boaz? im from north alabama. it must have been really sweet when it was parked for it to still look like that after that many years sitting. looks like a nice truck to get running and lower then drive while u work on it. congrats!
  11. HotRod60F100
    HotRod60F100
    My cousin Tony lives in Boaz out off the main highway where you see all them old 30's-40's cars. But my truck came from Albertville.and Yeah I was shocked it was in that good of shape after sitting behind my grandfathers barn for 16 years. It woulda been in the barn but it was falling apart so they moved it behind it in the woods.
  12. OahuEli
    OahuEli
    from Hawaii
    So have you given any thought to what you want to with it beyond fixing those first items? Stocker, low & slow, G***er type etc?
  13. nedrog
    nedrog
    from ca
    Keep the y block i have freinds who won alot of beer /races with built y blocks i also had a 312 interceptor that wood smoke the tires until you let off the pedal
  14. HotRod60F100
    HotRod60F100
    prob low and slow.I got the 74 AMC Gremlin drag car for my go fast needs
  15. Hotrod1959
    Hotrod1959
    Check out CJs website for ideas. www.cjcool.com. It is dedicated to 57-60 F100s. They look *****in lowered.
  16. ratamahata
    ratamahata
    from Argentina
    Very cool man!! Good find!! and good luck with this project!!
  17. chrisntx
    chrisntx
    from Texas .
    I had to get a new radiator for my 60
      560.2 KB
  18. davis574ord
    davis574ord
    koool! i have a 60 and a 58 BIG BACK WINDOW! GOOD LUCK!
  19. HotRod60F100
    HotRod60F100
    Yanked the batt. tray and its wasted as you can see.though the sides are in good shape so maybe I can weld a piece of metal where the old middle part of the tray was?
    You can see where the tray was here and surprisingly it was rot free.
  20. 53olds
    53olds
    Mine is like that too...
  21. Hotrod1959
    Hotrod1959
    The tray should be just spot welded on to the sides. I had the same with my 59. I ground off the welds and wire wheeled the brackets. Then I took some measurements and headed to pick n pull. I found a good donor tray for $6. I had a buddy spot weld it to the brackets, repainted it then bought new hold down hardware at a auto parts store.
  22. LM14
    LM14
    from Iowa
    I just kept my battery tray side pieces that bolt to the firewall and bent up a new base plate and welded it to the firewall brackets. The new base fit current batteries that are out there.
    Enjoy!
    SPark
  23. HotRod60F100
    HotRod60F100
    Farking around seeing what it look like with the"G***er" stance and a pic of the broken p***. side front spring.
  24. OahuEli
    OahuEli
    from Hawaii
    Your truck would be easy to set up "Early G***er" style. There are a couple around the HAMB and they look great. Lemme know if you'd like to have it Photoshopped.
  25. HotRod60F100
    HotRod60F100
    Yeah sure man by all means please photoshop it Thanks :)
  26. sdbcivic
    sdbcivic
    from West Ga.
    looks like a great start.......I want your cousins 57 chevy and the foxbody 5.0 for my wifes 66 mustang lol.
  27. sdbcivic
    sdbcivic
    from West Ga.
    heres a quickie
  28. clutch58
    clutch58
    got a rust free 59-60 front clip minus hood-small dents dont matter-if you do, please email me with price(ronburgess58@yahoo.com.)thanx much!
  29. OahuEli
    OahuEli
    from Hawaii
    Here you go. Used your original color, sorta. Eli
    [​IMG][​IMG]
  30. HotRod60F100
    HotRod60F100
    Whoooa thanks guys for the killer photochops. As for the 57 and the rest of the cars My cousins wife owns em and she's one of the damn weird *** "hoarders" sadly. :-(
