Projects Yet another Falcon Gasser build
Discussion in 'The Hokey Ass Message Board' started by 60 ford, May 11, 2010.
  1. johnnie
    johnnie
    from indiana
    Looking good! Have ya got the parts and engine planned ?
  2. 60 ford
    60 ford
    Im just going with the 302 and tunnel ram for now.
  3. Baron
    Baron
    Looking great. Is the front subframe in good shape? If it is, a couple of diagonal braces from the top of the firewall to the front of the subframe would be fine. I'd put the motor in place and headers and fit the bracing so that everything will clear and no surprises later.
  4. lorodz
    lorodz
  5. ***Area-51***
    ***Area-51***
    from Ohio
    always room for another straight axle..gotta lovem
  6. 60 ford
    60 ford
    The subframe is in really good shape but Im going to remove the inner fenders so Im using 2X3X 3/16 tube. Got one side done and it looks pretty good. It has to be stronger than stock.
  7. Baron
    Baron
    Couple diagonals similar to these will triagulate the front end (no problem with damage from wheelies ;) )
  8. OahuEli
    OahuEli
    from Hawaii
    Your project looks like its coming along nice. What width axle kit did you use? Between you and Chuckles Garage I'm leaning more towards a '65 falcon for sale over here. My 429 would love it!
  9. Chalupa55
    Chalupa55
    from So-Cal
    Looks bad***. Makes me wish I still had my 61'.
  10. AnimalAin
    AnimalAin
    Neat project. Please keep us updated.
  11. 60 ford
    60 ford
    I should get to spend this afternoon in the shop,I hope I can get somethings done. Ill try to post some pics tonight or tomorrow.
  12. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    On my Falcon I added to the factory rail, and added support with 1 3/4 tubing that attaches to the dash bar/cage.
    Looks good.
  13. 60 ford
    60 ford
    Well I finally got back in the shop to work on the Falcon,I summer at the dirt tracks and winter in my shop. I hope to make some good progress over the winter and have it finished by spring. I will post some pictures soon.
  14. johnnie
    johnnie
    from indiana
    Lookin forward to some more pics!
  15. Red71
    Red71
    from Illi-noise
    cool build , what is the measurement from floor to top
    of front wheel opening? I like the way it sits.
  16. Badhabit
    Badhabit
    Looking good and great tire and wheel choice! I'm a Chevy guy but I love these Falcons!
  17. 60 ford
    60 ford
    It is 32" to the top of the wheel opening.
    I actually got to spent some time with the Falcon this weekend. I got the p***enger floor cut out and cleaned up, and the new panels trimed up and ready to go in.
  18. 60 ford
    60 ford
    This weekend I picked up a 67 390 FE and a close ratio toploader, so I am going to 86 the 302, tunnel ram & automatic for a blown FE & 4-speed. I think I will be a lot happier with this.
  19. Kustom Komet
    Kustom Komet
    Sounds perfect for that car!
    -KK
  20. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Much better!
  21. 60 ford
    60 ford
    Thanks, I value your opinion very much.
  22. Ray C's son
    Ray C's son
    That is going to be sweet. I figured Chuckles Garage would approve, also.
    Nice work, love those Falcon g***ers!
  23. 60 ford
    60 ford
    Got the FE on the new engine stand I built, the old one wasn't strong enough to hold it up. Now I can start the tear down to see exactly what I got. It's supposed to be a 68 390 truck motor.
    I was able to get some work done to the right floor pan also.
  24. fitzee
    fitzee
    I have a soft spot for the early Falcons. One of the best looking cars when it comes to a g***er.
  25. newfalconowner
    newfalconowner
    from NS Canada
  26. 60 ford
    60 ford
    I got to spend some time working on the Falcon over the weekend. I got the clutch and brake pedal ***embly and steering column out of one of the donor cars. I started converting the steering column to be like a floor shift column. I also was able to get the right hand toe board and floor pan trimmed up and welded in. I should get the Hurst Verta-gate shifter I bought off ebay in the mail tomorrow. I cant wait.
  27. johnnie
    johnnie
    from indiana
    That is the best kind of shifter that I have ever used. You will be happy with it. Yup, blown big block is much cooler! Glad ya found it. Can't wait to see more pics of the progress.
  28. low budget
    low budget
    from Central Ky
    A guy on here owns this one,I like it also
  29. HotRod60F100
    HotRod60F100
    Awesome build so far Subscribed!
  30. falcon_flyer
    falcon_flyer
    from Omaha
