57 chevy body on a 55 chevy frame?
Discussion in 'The Hokey Ass Message Board' started by 57 shaker, Aug 7, 2010.
  1. 57 shaker
    57 shaker
    from phx.az
    Hey guys, you've bailed me out before and now I'm in another mess. I have a 57 chevy 2dr.210 sedan body and no frame. On craigslist I found a 55 chevy 2dr wagon frame here in town.I know that the 57 frame is boxed and the 55 is not. I'm planning to put a big block in it . Will the weaker 55 frame work ok as far as strength ? Other then the bumper mountings different would this combo work ? Before I go buying another mess I thought I'd run it by The Hamb.I know it would be best to have the 57 chev frame but right now this is the best and cheapest available. Any help would be great,thanks.
  2. THREE ROOMS DEEP
    THREE ROOMS DEEP
    Okay, the main diferences are as follows, the frame horns are different from 55 to 57, the 57 horns are boxed and the 55 is tapered meaning mounting a front bumper will need some custom brackets, the 55 rear spring pearches are different from a 57 and the rear rail ends are different which will need custom brackets for mounting the rear bumper. A sedan is a sedan as long as its a 2 or 4 door sedan frame and not a sport sedan hardtop or convert or 56-57 9 p***enger frame.
  3. ELpolacko
    ELpolacko
    Boxed tri-five frame?
    Are you referring to the two piece seamed frame vs the seamless frame?
    Regardless, the major difference on all three frames is the frame horns. 57's are shorter.
  4. treb11
    treb11
    g***ers don't have bumpers anyway.
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I've got a guy who will sell you a stack of 57 frames 10 feet tall if you want.
    It will fit, but why not get the better boxed 57 frame instead,especially if your're big blocking it?
  6. I would hold out for a 57 frame and sell the 55 frame if you have already purchased it. Just my two cents.:)
  7. LANCE-SPEED
    LANCE-SPEED
    wtf??
  8. 57 shaker
    57 shaker
    from phx.az
    ELpolacko, what I ment by a boxed frame (and I'm prolly all wet) but the 55 is like channel iron as opposed to the 57 boxed, welded or what ever it just looks like the 57 would be stronger. Maybe the 55 can be beefed up some. I looked at your site and Damn you do some amazing stuff. Thank you all for helping me.
  9. Reported!
  10. ELpolacko
    ELpolacko
    Do you have a picture of this? I have never seen or even heard of an open channel 55 Chevy frame and would be curious to see it.
    Thanks!
  11. unklgriz
    unklgriz
    isn't the wagon frame too long?
    Larry
  12. 325w
    325w
    Know of two real good frames here in the DFW of Texas. Best to do it right the first time.
  13. ElP is right, a couple pals just killed some Tri 5s to build ch***is with. 3 California frames and a standard one.
  14. 57 shaker
    57 shaker
    from phx.az
    Hey ELpolacko, get on craigslist -auto parts-chevy frames-july 22 under 55 chev 2dr. station wagon frame complete. If you look close you can see the frame horns are not square but more like a u or c shape .I just thought with a big block the 55 frame might have more twist maybe. Thanks for taking time to respond. I haven't bought it yet just gathering info.
  15. jonzcustomshop
    jonzcustomshop
    from the front cross member forward the 55 frame horns are a c chanel, and the 57 are boxed. the only thing they do is hold the bumper on, no other support or structure...from the crossmember back the frames are the same, 5-6-7.
    even a hardtop frame will work, they will just have a few extra mounts that you will not need..
  16. ELpolacko
    ELpolacko
  17. 56sedandelivery
    56sedandelivery
    The wheelbase is the same, 115 inches, for ALL the models. The hardtop frames have a couple of extra body mounts, they will still work. 55-56 frame horns are the same, 57's are "boxed" shaped. You could swap frame horns. There are also some minor differences in the rear shackle hangers, 55 are one of a kind, 56-57 are the same. I have a friend that deals in 55-57 Chevrolet cars AND parts, PM me if you need anything. Butch/56sedandelivery.
  18. 57 shaker
    57 shaker
    from phx.az
    Thank You Thank You Maybe I'll go out and take a look at it tomorrow. Just trying to put something together before I kick the bucket. Something that we can cruise around in. She keeps telling me it'll never happen and at 66 it might not but I'm gonna try.Thank you all.
  19. 66 is YOUNG, start living or get to dying! Plenty of time to have fun with your 57. Just sit down and do ONE small task each night. Even if it is a 10 minute task!
  20. 57 shaker
    57 shaker
    from phx.az
    Thanks Tman, your right I ain't dead yet. NO MORE NAPS!
  21. Hey, naps are ok! Just not 4 hour ones!
  22. 57 shaker
    57 shaker
    from phx.az
