small block Ford?
Discussion in 'The Hokey Ass Message Board' started by sixbangr, Aug 7, 2010.
  1. sixbangr
    sixbangr
    I have a '78 302 in the hot rod I just bought. It has a huge HEI. Will a distributor from a '60's 289 fit?
  2. mart3406
    mart3406
    from Canada
    Unless it's some sort of aftermarket unit like a
    'Davis DUI' distributor, or similar, your present
    distributor is not an 'HEI'. The HEI was a large
    cap, electronically-triggered, 'high energy' OEM
    GM piece. Ford came out with a large cap,
    electronically-triggered distributor of their own,
    but it's not an HEI. If you ask for parts for an
    'HEI' distributor at a parts store, they'll give
    you parts for a GM distributor.But yeah, if your
    engine's a '78 302 Ford, any distributor designed
    for any year Windsor-style 221, 260, 289 or 302
    Ford V8 will fit.
    Mart3406
  3. mrforddude
    mrforddude
    Make sure you dont get one from a 351w as the oil pump drive shaft is a different size. 302's and down use 1/4" where as the 351w uses a 5/16"...yeah dont ask how I know...
  4. AnimalAin
    AnimalAin
    And, don't forget that the later ones (post-85?) have a steel gear to be compatible with the hydraulic roller cams. Could cause wear issues on a flat-tappet cam.
  5. George
    George
    just fixin to add that!:)
  6. !!!! Holy **** !! It's amazing how people get confused on here !! Look at the original question !!! >>>>.
  7. Spyder
    Spyder
    from Houston
    If it's an original duraspark distributor, You should be able to just switch to a 289 distributor cap. It would look the same, except with one more wire coming out of it.
  8. sixbangr
    sixbangr
    here's a pix
  9. billygoat67
    billygoat67
    that is a aftermarket hei not ford oem. they do make a aftermarket hei with a small cap available. check the auction sites their fairly inexpensive, unless you want the original look.
    hope that helps
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    And you don't like it because? I have one on my 302 and real happy with it eliminated extra wiring clutter and curve was right on for my cam change.
  11. sixbangr
    sixbangr
    '29 roadster with no hood. It just does not look good to me. That is the only reason.
  12. Raunchy
    Raunchy
    I am running a Summit with their box. It is small and I got the black cap. It is a stand alone unit if you don't want to run the box. It is working great. Way better than the Duraspark I was running that had a big cap. I don't like the HEI either because of their size.
  13. davidwilson
    davidwilson
    from Tennessee
    it is an ugly sumbum
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    Check out this link: www.skipwhiteperformance.com put this part number in search:6702-R this is small cap electronic,3 year warranty and a nice price.
  15. AllSteel36
    AllSteel36
    huh?
  16. George
    George
    It's along the lines of...Posi is a GM name & isn't technically apropriate for describing a Ford or Mopar locking diff.
  17. George
    George
    My reading must still be off! A 60s dizzy is a direct bolt in on a '78 302.
  18. junkyardjeff
    junkyardjeff
    You dont have to use the big cap on a duraspark,I got the points cap and rotor on one on a 351 thats in my 55 sunliner.
  19. I will attempt to answer this again !! YES !!! A dist out of a 60s 289 will fit in your 78-302 !!! >>>>.
