help with 51 business coupe
Discussion in 'The Hokey Ass Message Board' started by 67stangbanger, Aug 11, 2010.
  1. 67stangbanger
    67stangbanger
    from Texas
    Hey, I have a simple problem. My son-in-law acquired a complete 51 chevy business coupe. Wondering if a different inline 6 could swap in place of the 215. Also need a couple numbers decoded. Style # is 51-1027. Body # is N-5502. Trim is 201. Paint is supposed to be Aztec Tan, but is mostly rust now. Wanting to eventually swap to a more conventional drivetrain, maybe using S-10 pieces. Thanks for any help!
  2. 51NINETYEIGHT
    51NINETYEIGHT
    Thers alot of info here, use the search feature. Also join the social group rockstar with torque wrenches for everything 49-54 Chevy, or chevytalk.com.
    I belive a 235 bolts right up, 4x4 S10 rear ends or early 70s Nova. Not sure on the numbers.
    B.
  3. Jack Luther
    Jack Luther
    235 or 261 should swap in easily. You'll need to use a short water pump. Patrick's can answer all these questions for you. Good luck with your project.
  4. CARLOS8A
    CARLOS8A
    from waukegan
    if you do the 235 i know that you have to drill new holes for the motor mounts! search it theres allot of info on that here...
  5. Sam Navarro
    Sam Navarro
    I had a 235 out of a 54 chevy in mine, when that motor went I easily replaced it with a 51 chevy 216. If you need any parts for it let me know, I'm in the middle of swapping out for a 350/350 and I have a ton of straight 6 parts that are filling up my garage! Good luck. Sam
