2 link or 4 link??
Discussion in 'The Hokey Ass Message Board' started by RPIERCE, Aug 10, 2010.
  1. RPIERCE
    RPIERCE
    from Alvin Tx
    I've got a 54 chevy belair and I can't decide on going with a 2 link or 4 link suspension for the bags. I don't have that big of a budget so price and quality I need to find out. If you have a pictures of either set up that would be nice!! What did you do?
  2. 40hemicpe
    40hemicpe
    from anaheim.ca
    run early chevy truck arms you can find them cheap and get really low...
  3. metalix_421
    metalix_421
    went with four link on mine built my own tabs and c notches $40 worth of metal and if I remember right my bags and links were around $250
  4. Hightone111
    Hightone111
    +2 for truck arms
  5. gimpyshotrods
    gimpyshotrods
    x3 for truck arms, so you can keep your rear seat, and go low.
  6. RPIERCE
    RPIERCE
    from Alvin Tx
    What year of truck arms because I really don't want to cut up into the back seat area.
  7. temper_mental
    temper_mental
    from Texas
    I put a 4 link under my wifes mercury I was under that car all weekend!
    I vote 4
  8. 40hemicpe
    40hemicpe
    from anaheim.ca
    mid to late 60's chevy or gmc...
  9. Chevy54
    Chevy54
    from Orange, CA
    Run truck arms and they wont interfere with your rear seat pan...just relieve the rear part of tunnel and the rearend doghouse area for your c notch...63 chevy were the first year w truck arms I believe..run your set up just like them or make one to match!
  10. RPIERCE
    RPIERCE
    from Alvin Tx
    Thanks for all the info. I wasn't even thinking of the truck arms!
  11. uglydog56
    uglydog56
    You can get used winston cup truck arms for 50 bones from muscle motorsports.
  12. you guys run a panhard with the truck arms right? anyone doin a watts link? the sway from a panhard with a good ammount of lift could cause tire/skirt or fender clearance issues depends upon wheel choice.
    something to think about.
    i prefer a 3 link wishbone style myself. check what steve sellers did or b*** did on that 49
  13. big creep
    big creep
    4 link! thats what i did!
  14. 1badrat
    1badrat
    I did a two link with bags at pivot point close to the hanger, And it has a 4" pinion angle block made on to it!!upper bag mount on frame and lower is on the arm itself!! It allows you to run less air than an over the axle setup, giving u a much smoother ride!! As for the pan hard , the longer u can make it the less the rear end mOves from left to right as u raise and lower!! Set your pan hard at ride height to center the rearend! Good thing bout four link is it keeps ur pinion angle in motion all the way thru the trAvel!! Check with Alex gambino, he has everything u need if u you want to go that route!! Excellent stuff!!
