Home made Steeringwheel.
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Aug 10, 2010.
  1. metalshapes
    metalshapes
    My latest installment in my Billet Is Uncool series....:D :D
    I built my Roadster with a steeringwheel out of a '40 Ford.
    I really liked the look of the huge steeringwheel in the small interior of my Roadster.
    But you kinda had to bend your legs around it, which could make you cramp up if you were on the highway for a while.
    So I started to think about an other steeringwheel...
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Ok... And then?
  3. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
  4. metalshapes
    metalshapes
    I got a chunk of aluminum.
    And cut and filed it, untill it looked like this.
    And I bought a new wood rimmed steeringwheel, and drilled out the rivets.
    Edit.
    Sorry guys... I type slow... :D
  5. metalshapes
    metalshapes
    Next were the spokes, and rim.
    I layed out my pattern on 4 pieces of 1/4" thick aluminum.
    Rough cut them to size, and bolted them together.
    I cut and milled on the stacked spokes a bit more.
    And then I cleaned up some of my rough cuts on my rotary table.
  6. crotex
    crotex
    from cuero, tx
    I wish I had your equipment.
  7. temper_mental
    temper_mental
    from Texas
  8. gladeparkflyer
    gladeparkflyer
    type faster!!! yer KILLIN me here! "i want some patience.... and i want it NOW!" :)
  9. metalshapes
    metalshapes
    I unbolted the stack, cut them in 4 exact 1/4 pieces.
    And welded them together at the rim.
    Next was a thick weld from the spokes to the hub.
    ( thick enough it could be blended in later...)
    Rough shaping it on the Lathe...
    Probably not how you are supposed to do that, but it worked for me. :)
  10. TheMonkey
    TheMonkey
    from MN
    oh. thaaat's what that is.
    for some reason i found that statement and picture funny.
    nice work, looking forward to 'the rest of the story'.
  11. metalshapes
    metalshapes
    After a ****load of filing and sanding, it looked like this.
    I opened up the countersunk part of the wood rim so they'd accept br*** screws.
    Drilled and tapped the steeringwheel, and put the wood on.
    ( the wood had to come off again so I could polish the aluminum to a kind of a dull shine...)
  12. UnsettledParadox
    UnsettledParadox
    KILLIT BILLIT!!!
    just kidding, turned out a whole lot better then i had imagined!
  13. metalshapes
    metalshapes
    Yup.... :D :D
  14. doctorZ
    doctorZ
    that looks fantastic. great job and terrific work.
  15. metalshapes
    metalshapes
    Bolted up and in the car...
    BTW...
    The horn ****on is early Fiat 600.
    ( I thought it was just about perfect for this wheel...)
  16. Anderson
    Anderson
    Looks like an adapter for a Bell style wheel to early Ford column? I was about to ask about the horn ****on. Carve a V8 into the center, and it'd be perfect. Looks good man, I envy your machining skills and equipment!
  17. metalshapes
    metalshapes
    Yeah, the adapter bolts to the back of the hub.
    I'm not skilled or trained as a machinist...
    ( I measure everything with a ruler and a very old set of calipers...:D)
    But I'm having fun... :) :)
  18. UnsettledParadox
    UnsettledParadox
    those old calipers are the best!!
  19. metalshapes
    metalshapes
    They are!! :)
    And you can use them as a scribe...:D
  20. Paul
    Paul
    Editor
    cool Alex
    very art deco
  21. metalshapes
    metalshapes
  22. crapshoot
    crapshoot
    super nice wheel man looks great
  23. draggin'GTO
    draggin'GTO
    Nice work as always, that's a beautifully designed steering wheel.
  24. So, when do finish the ***** with real paint and interior?!
  25. MikeRose
    MikeRose
    from Yuma, AZ
    Really goes with the car I think. cool
  26. NealinCA
    NealinCA
    Nice work...as usual.
    Neal
  27. ENFO
    ENFO
    from Tucson AZ
    I'm without a computer, so Im looking at the pics on my phone.... Guess, Ill just have to make the drive and see it better!!!! It looks like an early Itaian design... LOVE IT!!!!!!
  28. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Dude, thats over the top..very nice.
    man, to have the machines and knowledge to make stuff like that is so sweet
