What carb set up for trips on SBC???
Discussion in 'The Hokey Ass Message Board' started by Lowboy44, Aug 12, 2010.
  1. Lowboy44
    Lowboy44
    from New Jersey
    I'm currently building a 327 with a trips Edelbrock intake. What are your thoughts on what carbs to run? Looking for something that are somewhat easy to find and tune
    Thanks for the help
    Lowboy:D
  2. chaddilac
    chaddilac
    Rochester 2GC
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, small base 2GCs from 265-283-307 engines. I still find them cheap at swap meets, and if you want to spend the $$$, there are aftermarket tripower end carb style bases with no mixture circuts available now.
  4. Lowboy44
    Lowboy44
    from New Jersey
    Thanks for the info.
    BTW the iphone covers are sweet....anything can be cool with pinstipes:D
  5. Lowboy44
    Lowboy44
    from New Jersey
    Thanks bro, I'm looking to build this motor 60's era so I would like to stay away from the newer aftermarket stuff...so off to the swapmeets I go:cool:
  6. budd
    budd
    you can still buy these carbs allready rebuilt at any parts store, i paid around $125 each.
  7. pdq67
    pdq67
    I have a set of trip Rochester 2G's in the front p*** floorboard of my '67 Camaro that are off probably a latter '50's Indian or '57 Olds?
    The two end carb's don't have any idling jets in them.
    I had a second set and a so-called "friend" stole them!
    Now all this said, I took a 348" "W" engine trip intake and had it brazed up so that I could mount three 2GC's that I installed on my hopped up , .060" over, 11.5 to 1 CR, NASCAR solid cam equipped 409 "W" engine way back in like '73 or so. In myn '67 Camaro!!!
    The big 409" engine looked like it was a stock install when you opened the hood and saw the great chrome "W" shaped valve covers...............
    ****er was like a SB on steroids!!
    pdq67
  8. Lowboy44
    Lowboy44
    from New Jersey
    Are they marked 2 GC or do the have a different number stamped on them?
  9. chaddilac
    chaddilac
    haha no problem... thanks!
    Yep usually they have a small "GM" in the casting on the side. They are pretty easy to find. I found 3 for a buddy, he's going to buy the kit from speedway to make them tri power it's like $400.
  10. chaddilac
    chaddilac
  11. budd
    budd
    as i understand its not just the idle mixture screws that are not used, but also the throttle blades are thicker on stock 3x2 setups, the thicker blades do not stick shut when they are fully closed, something that never happen when you run just one carb.
  12. GassersGarage
    GassersGarage
  13. pdq67
    pdq67
    Geez, back then 2G's were at the most, $5.00 each off junk SB Chevy engines!
    And the somewhat larger 2GC's like $6.00 each...
    I got my three 2GC's off of older latter '50's/early '60's 2-barrel big car Pontiac engines in a couple of Saturday's scrounging "Boneyards" back then.
    pdq67
  14. Lowboy44
    Lowboy44
    from New Jersey
    awesome info..thanks
  15. Lowboy44
    Lowboy44
    from New Jersey
    Thanks guys for all the quick responses.
  16. Pontiactripower.com
    Pontiactripower.com
    Take a look at www.chevytripower.com
    Ron Kellogg runs the site. He does excellent work. He can be reached (309) 360-6385. Ron is in Central Illinois.
  17. Pontiactripower.com
    Pontiactripower.com
    Correction..
    Ron Kellogg (309) 256-2550
  18. carcrazyjohn
    carcrazyjohn
    from trevose pa
    You want the side inlet carbs not the one pictured ,Look at all chevy 307's + boats ran electric chokes for the center .4 cylinder of course
  19. A Rodder
    A Rodder
    Those carbs offer inlets for pvc/vacuum advance options as well.
