"Gowjobs": Depresion Era Performance and Early day hop-up tech
Discussion in 'The Hokey Ass Message Board' started by MrModelT, Aug 13, 2010.
  1. GuyW
    GuyW
    I hate to say this, but that mount looks too weak to me...
  2. totally should have used 1" plate. ;)
  3. Hitchhiker
    Hitchhiker
    Dude it's a T. It weighs like 1300 pounds soaking wet. It'll do okay.
  4. GuyW
    GuyW
    It APPEARS to be bent already, tho....
  5. Hitchhiker
    Hitchhiker
    I noticed that too.....
    But......
    Looks CAN be deceiving.:p
  6. Angry Frenchman
    Angry Frenchman
    any body got A pic of the front of Alrich Multi T. I've seen it in person A few years ago and this looks just like this. I don't rember the front cross member being arch but maybe it was. we all know he put more than 50,000 mile on his car.
  7. Ted H
    Ted H
    Fellas,
    I don't think you realise just how strong steel is. Look at the surrounding parts. For instance, look at the perch bolts. and I am sure the bar was formed to conform to the shape of the spring. Had that been made of 1" plate it would have supported an 18 cylinder Pratt& Whitney Radial. And just so you know, I spent the last half of a long working like as a fabricator in heavy industrial steel fabrication.
    After all, the car lasted for decades.
    Now back to the cars.
    ted
  8. 29nash
    29nash
    from colorado
    That spring mount looks just like the trailer hitch on my grandpa's '29 Model A that came with the car when it was new.
    My brother is custodian of the car now, including that original trailer hitch.
  9. Bodger45
    Bodger45
    Saving thread.
  10. BadgeZ28
    BadgeZ28
    from Oregon
    My dad built a ram air system for his old Dodge sedan back in the 1930's. He took the car out to Sauvie Island and hit 85 mph. He said the whole car was shaking at that speed.:D RIP Dad
  11. plym49
    plym49
    from Earth
    A brilliant blacksmith approach. There was a time when no one had MIG welders and CNC plasma cutters. You worked with regular stock, a fire, an anvil and a vise.
    Traditional rods sometimes can benefit from traditional tools, materials and techniques.
    This one is perfect.
    Outback likes this.
  12. GuyW
    GuyW
    LOL! my engineering degree and blacksmithing and welding experience failed me...better get my money back...
  13. Jay Rush
    Jay Rush
    This is a cool thread lets not turn it in to a ******* match
  14. The37Kid
    The37Kid
    DITTO Rush!
  15. Gaters
    Gaters
  16. need louvers ?
    need louvers ?
    Those were cool, but pardon my lack of knowledge, but what was the purpose? It could seem that they would add a small amount of artificial caster maybe? Makes me think more of trail on a bike... Teach me on this, please!
  17. Hitchhiker
    Hitchhiker
    So you think it's bent on purpose to conform to the arch of the spring?
    LOL! engineers....:rolleyes:;)
    Just kidding.:D
    seriously though
    How it mounts at the frame is what concerns me. Do we even know if it's bent or not? And from an engineering point, if it was bent would that make it more likely to fatigue in that direction?
  18. flyin-t
    flyin-t
    After I built that front mount I heated the center of it and shaped it (tried to) to the contour of the top of the spring pack after it was mounted on the axle. I didn't want to stress the springs by tightening it to a flat surface, possibly breaking the spring.
    The car's been on the road for over 10 years like that and runs straight and true. I built in 7 or 8 degrees of camber too.
    Though it's no longer mine, the guy I sold it to drove it in the Pasadena Roadster Reliably Run a few years back and finished. Won an award for oldest engine!
    Outback likes this.
  19. MrModelT
    MrModelT
    That's how I would have done it...conform it to the curve of the front spring, would give a larger "pad" area to mount to and would allow you to move the spring clamp U-bolts farther apart..both of which would make the front spring more stable. The steel stock he used looks rather substantial and if it was heated, bent and cooled properly, the steel should retain all of it strength and flex rather than becoming hard and brittle if it were dowsed in cold water immediately.
    I have seen my fair share of "rickety" modifications done with T's and a few period mods that would make even me a little nervous..but Flyin-T's setup is a real nice one, perfectly period and plenty strong.
  20. flyin-t
    flyin-t
    I tried to build the car as if my grandpa would have back in the day. He was a mechanic at the White garage in Hollywood and was, a**** other things, Ken Maynard's mechanic, maintaining his fleet of cars. (Maynard was a silent film cowboy for all you young 'uns).
    Grand pa also bought a new Ford roadster in '24 and went right down to Western Auto and bought a 4 valve Rajo for it.
  21. flyin-t
    flyin-t
    Thanks, I was shooting for a period look.
    I cooled the mount in oil after each heating.
  22. daredevilcustoms
    daredevilcustoms
    from Ohio
    Posted these before. You need to drill out the rivets on the Model T axle tubes and rotate them, moving the spring to the front of the axle rather than on top.
  23. MrModelT
    MrModelT
    You certainly nailed that one dead on!
    Cooling it in oil is an old trick that allows you to harden and cool the steel at a slower rate than with water since oil has a higher boiling point. I was always tought that with flexing or load bearing parts, such as suspension parts...it was better not to harden then like that, but rather to cool them slowly by placing them in an oven and slowly reducing temperature until they are cool
    so they retain their strength and flexibility rather than hardening them which could cause them to crack or shatter. Used that process a few times and seemed to work great....haven't had anything on the roadster break yet....knock on wood :D
    ...now watch, next time I take the roadster out...somethings gonna break.:eek:
  24. daredevilcustoms
    daredevilcustoms
    from Ohio
    Found some pictures of the front end.
  25. MrModelT
    MrModelT
    I have seen this car or the same set up on another very similar car before. great design...was most likely an old dirt track car. The frame has been stretch 10 -12 inches using a T rear cross member and frame sections for the lengthening portions and the axle is actually Model A.
    Love the knee action shock set up though!
  26. Sure looks like after all that book learning, you forgot how to combine the basic powers of observation and deduction. ex: "gee, wonder if that guy put the bend in there on purpose?" :confused:
    nah, he couldn't have.
  27. ironpile
    ironpile
    Can you see the gates of Hell from your back door, I could when I lived there.Now it`s been too hot in Illinois to work in the shop during the day. I did have a swamp cooler in my garage in PHX so it wasn`t too bad.
  28. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    The spring is suposed to mount to a flat. Because the spring has to flex upward and flatten. As it is now the spring doesnt have much free area to arc upwars into.
  29. need louvers ?
    need louvers ?
    You must be talking to me! Yes I can, but the devil is reluctant to get any closer than he has to, Either I scare him, or it's a bit cooler in hell! Could be either really! And that temp, that's with the cooler doing it's best all day out there.
  30. need louvers ?
    need louvers ?
    Yes, I think that shock arrangement might be duly stolen! very nicely done!
