Is There Such Thing as Generic Stainless Trim?
Discussion in 'The Hokey Ass Message Board' started by 4woody, May 17, 2010.
  1. 4woody
    4woody
    I'm wanting to add some trim to my skirts. It would need to be about 3/4" wide x 30" long with a "Half-oval" cross section. Other similar stuff on my cars is stainless channel so you slide the fasteners into position on the back.
    Is there anyplace to just get lengths of the stainless channel?
  2. 4woody
    4woody
    I found a place that sells solid half-oval in br*** or steel, but I'd still have to solder pins on the back and then get it chromed.
    Stainless channel??
    Anyone??
  3. Phil1934
    Phil1934
  4. Dan Boehm
    Dan Boehm
  5. alchemy
    alchemy
    Look at Bob Drake's repro stainless molding for a '39 Ford. Maybe you could use a hood side molding? It has almost a half round profile, maybe slightly peaked.
  6. atomickustom
    atomickustom
  7. revkev6
    revkev6
    from ma
    yeah, except a 3' piece will cost you $50 :eek:
    $10 a ft and $10 per finished end....
  8. charleyw
    charleyw
    Look at the hood side trim on a 48-50 F-1.
  9. 4woody
    4woody
    Those are some good suggestions- Thanks.
  10. 40StudeDude
    40StudeDude
    Cheap at half the price...By the time you find some that will work for you, have it polished ($12.00 per foot is the cheapest I've found) and get it trimmed to whatever length you need ($$$-welding stainless ain't cheap) and finding clips for it...buying it ready made is the way...!!! I have a small fortune wrapped up in my '55 Caddy...
    R-
  11. 50Fraud
    50Fraud
    I remember seeing an ad for lengths of stainless half-round for use as side trim. Might have been in the Goodguys Gazette, and it might have been Mr. Merritt as noted above. In any case, I can't seem to find the ad I saw. Anybody aware of any other source, particularly for material < 1/2" wide?
  12. Biff.bailey
    Biff.bailey
    volvo amazon (121) side trim is around 3/4" wide, slightly peaked and available in fairly long, straight lengths (3 to 4 feet)
  13. BulldawgMusclecars
    BulldawgMusclecars
    I'd head to a good automotive swap meet...there are often guys with tons of vintage stainless trim, often of unknown origin, and you may be able to find an odd piece that is exactly what you are looking for.
  14. Fidget
    Fidget
    EXACTLY!! Expensive as hell as I've found out, my NOS cruiser skirts didn't have any trim with them. They're 5' long, and finding any trim is either really really really expensive, or plastic stick on stuff. Finding it ready made would be a steal!
  15. OshkoshRob
    OshkoshRob
    from Oshkosh
    48 Ford sedan trim would be good. 1/2 round at least an inch wide. Easy to find and relatively cheap. I bought a rear quarter piece for $25 at BTT50's
  16. cool57
    cool57
    I have some NOS cruiser skirt trim:)
  17. I need some of this help too. I'm looking to recreate some factory style rear fender vertical accent trim pieces. The attached pic shows a bit of quarter panel, bit of left running board and front of the left rear fender of a white '34. My problem is this trim is only 3/8" wide. What I'm finding is suppliers that start at 1/2" wide or 3/4" wide and I definitely need 3/8". It is half round or slightly lower crown than half round. I'll figure out attachment if I can just find the 3/8" stainless or br*** trim. Thanks!
  18. unkamort
    unkamort
    Using this for my grill center strip till something better comes along... looks OK, didn't really take much of a polish.
  19. Joel W
    Joel W
    Your local Mack Truck dealer may have some too, I know my dad and a friend have gotten stainless pieces from them. They were used on some models down the center of the hood. You can buy the ends and straight lengths. I think they were used on B Series trucks.
  20. pprather
    pprather
  21. sir
    sir
    try 60/66 c-10 lwb bed trim.....
