Jumping a 6 volt from a 12 volt?
Discussion in 'The Hokey Ass Message Board' started by greg_usa, Aug 19, 2010.
  1. greg_usa
    greg_usa
    from New York
    Figured I'd ask before I tried it. Will nothing happen? Will the battery explode and blow my face off? I've heard mixed things on this and I'm not really sure what's true.
    Bear with this newbie and and his newbie questions..
    Thanks fellas!
  2. You can do it, just be careful.
    takes two people- one to try starting the car and the other put the cables to the 6 volt battery JUST BEFORE you start it and take them off RIGHT after you get it running.
  3. chrisntx
    chrisntx
    from Texas .
    I've done it hundreds of times.
    No problem, but I dont EVER leave the jumper cables on a second longer than needed!
  4. BOWTIE BROWN
    BOWTIE BROWN
    yep, don't even connect the cable to the six . Just hold on the terminals . And like your mother always told you , damn-it boy becareful or i'll tell your father.
    git-r-done
  5. 49ratfink
    49ratfink
    interesting... so what do you suppose would happen if you hooked up the 12 and just left it? I mean without even cranking to motor.
  6. junk yard kid
    junk yard kid
    same thing that happens to all over charged batterys. it will boil all the fluid out of it makeing hydrogen, whith the potential to explode. well thats my guess anyways
  7. greg_usa
    greg_usa
    from New York
    Great - thanks guys!
    how about the positive ground on my 6 volt? I would still connect pos to pos and neg to neg - yeah?
    I'm also curious about happens. Is this thing gonna blow up in my face if it's on too long? Or maybe damage the electrical system in the car?
  8. F&J
    F&J
    Always a chance of a battery popping even if both are 12v.
    You are supposed to hook the ground last, and hook it to part of the engine away from the battery.....but not many of us do that.
  9. 53sled
    53sled
    from KCMO
  10. waldo53
    waldo53
    from ID
    AND....make sure everything on the 6V car is OFF,(except the ignition of course) lights, radio, or whatever. Otherwise you'll be replacing burned-out stuff. Don't even step on the brake pedal, use the emergency brake.
  11. plym_46
    plym_46
    from central NY
    To be safe byp*** the 6V battery. Jumper to the block and the starter side of the solenoid, just put the key in the on position and jump the starter ot the battery.
