**** Engine Rotating ***emblies 1-94605BI Rotating ***emblies from **** are fully balanced and include rings, rod / main bearings, **** crank, Ross pistons. **** good stuff or p***? 1-94605BI setup is: <TABLE border=0 summary=""><TBODY><TR><TD cl***=body>Cubic In. |</TD><TD cl***=body>Piston Bore |</TD><TD cl***=body>Stroke |</TD><TD cl***=body></TD></TR></TBODY></TABLE> <TABLE border=0 summary=""><TBODY><TR><TD cl***=body> 286</TD><TD cl***=body> 3-5/16"</TD><TD cl***=body> 4.125"</TD><TD cl***=body></TD></TR></TBODY></TABLE>
we use 'em in our racing engine (3-3/8" x 4-1/4") and sell the complete kits. we have had nothing but good luck with them.
Thanks for the info doctorz, are you running a blown setup on the race engines? I know on flatheads 286 is a grey area for running a blower or going n/a. As far as filling the cylanders with air.
**** builds quality parts. We're using a **** crank in a blown big block we're putting together. We went rhough 4 cranks from another well respected manufacturer never got one that wasn't either knicked or that would mic out correctly. Contacted **** and they sent us a perfect crank first time out.
Ran a **** crank and rods in a 408 stroker sbf 351 W. Went 7.90's all day long on 25% nitro injected. Nothing wrong with **** stuff. Sold the engine and the rotating ***y went in another dragrace engine and is still going. Lippy
it's an original 59AB block, bored/ fully sleeved/ ported/ polished/ relieved with high dome pistons. we're running fuel and about 20 lbs. of boost. at least that's what it was until we killed block on monday in bonneville ...
