What mufflers are you running on your flathead?
Discussion in 'The Hokey Ass Message Board' started by 1low51f1, Aug 21, 2010.
  1. 1low51f1
    1low51f1
    I am running fenton headers with smithy mufflers....seems quiet.
  2. PhoenixFear
    PhoenixFear
    I'm probably running a stock setup, and I couldn't tell you what it sounds like because it doesn't run. I kinda want Smithy's gl***packs on it as I've heard an early '50s Merc with those on and it sounds good, however I'm not sure what the different length gl***packs do. I want something loud, but not annoying.
  3. GARY?
    GARY?
    none and I love it!!!:D
  4. Oh, I knew I forgot to install something!
    I do have a small baffle in mine.
  5. 1low51f1
    1low51f1
    I am leaning on taking the gl*** packs out and running open headers as well. I will have about 5 feet of pipe from the headers to the tips. That might quiet it down a little...right?
    Any thoughts on cutouts?
  6. StrickV8
    StrickV8
    Brockman MellowTones steel packs on my 53 Merc. Might look at Porter Mufflers for my 31 though.
  7. oldiron73
    oldiron73
    from WISCONSIN
    Brockman mellow tones steel packed, sound real nice.
    I am going to put a set on my F1 with a 337 Lincoln engine.
  8. 1low51f1
    1low51f1
    Are they louder than the Smithy's?
  9. 31fordV860
    31fordV860
    None - V860 flathead
  10. hellcat666
    hellcat666
    a buddy of mine runs the real little 10 inch steel packs on his 49. mounted as close to the motor as possible the thing sounds awsome
  11. barry wny
    barry wny
    Tractor supply has a straight thru, maybe steel packed, cheaper than smithys. I will say that after making tubes to replace the iron manifolds the volume went up. Instead of 1 1/2" runners to a collector. I went with a 2" pipe from the center port & blended in, maybe the digger tube add's volume? Manifolds muffle a lot compared to headers IMO.
  12. flat34pu
    flat34pu
    im running Smithy's, i just like the sleeper look and sound.
    rich
  13. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    No Mufflers for the Thunderturd ! ! Speedway "economy" headers only. Very sweet sound and not really loud ! ! !
