Looks good Kevin! I saw you picking up the Cab today. Looks like it'll be nicer than it was 70 years ago when it's done.
Just hammering out the mul***ude of dents and getting it as close as I can before filler and primer. Its not as bad as it looks in that one photo where its tipped forward, the shadow's make it look worse than it actually is. Most importantly no rust, except for the header which Is in process.
I just started working on it again. I hunted down the valve train noise. I had a good used cam and lifters so I replaced the old one. I measured all the bearing clearances, and cleaned everything up. Flex-honed the cylinders, faced the valves and lapped them in. I went through the oil pump as well. It is by no means a rebuild, but I have confidence that everything is close and will run.
Find your dash as of yet ? Need pic's real bad, as we are having '40 Ford P/U withdrawl...... Eh.....
Just found this built moving along and looking great, some good info ..Rod Sent from my iPhone using TJJ
