Allmetal....the worst ever
Discussion in 'The Hokey Ass Message Board' started by jerry325w, Aug 22, 2010.
  1. jerry325w
    jerry325w
    from baltimore
    DOING A 58 CHEV CONV THAT CAME FROM A SHOP THAT PUT IN NEW FLOORS AND PAINTED CAR, BUT NO PANELS WOULD LINE UP AND IT LOOKED LIKE **** SO I GOT THE JOB TO REDO......WORST MISTAKE IN MY MISPENT LIFE!
    the shop used the aluminum powder filler called allmetal, this **** is hard as a rock to remove and they even seamsealed with it. gonna be done with this pig in a couple weeks now, just cant believe how bad this stuff is or was. God help us if they still make this mistake of a filler.:mad:
  2. Bluto
    Bluto
    Use a mapp gas torch ...... it will fall off
  3. lil av8
    lil av8
    that stuff is great for 1st coat over welded seams if used correctly works best if let dry overnight dont know about seam sealer tho lol
  4. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Yeah, that "product" was big in the 70s for a time, it was suppose to replace lead altogether. " AllMetal & "Alumalead" are two I remember. The guys in the restoration shops wouldn't use it, and it retailed for 'bout ten bucks more than regular mud, so it didn't sell very well.
    I don't think I'd use it beneith a different type of filler, as it is very dense in nature, and would probably expand and contract at a different rate than standard filler, which could lead to serious problems.
    Plastic filler is for collision repair, not restorations and the building of kustoms!
    '' The ice cream truck in his neighborhood plays Helter-Skelter "
  5. slammed
    slammed
    This stuff aluminum based? Wear a cartridge mask for sure.........silica!
  6. olcurmdgeon
    olcurmdgeon
    the shoebox I bought of a HAMBer here in NH this summer was chopped a decade ago and allmetal was used to do the top. Car has been in DP 90 all that time and not a blemish or bubble on the top at all. So I agree with lilAV8, in the right application it appears to be better than bondo. Of course I don't intend to grind it out, just finish sand, seal and paint at some point.
  7. BulldawgMusclecars
    BulldawgMusclecars
    I haven't used the stuff in years, but used PROPERLY...just like any plastic filler...it has its place.
  8. i havent heard of allmetal but metal2metal used to be some good stuff easy sanding and forming
  9. Lone Star Mopar
    Lone Star Mopar
    Thankyou !
  10. My 51' has had "allmetal" in the roof for around 12 years now, not a crack in it. I also have it around my frenched headlights and tunneled tail lights without a crack. So yes it does have its place but I wouldn't use it on everything! I own a powder coat operation and have used it a few times for filling in imperfections before powdering and it will handle up to 400 deg
  11. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I concur, I like that stuff for the first coat. A lot of folks I know have used it for such, dries bullet proof and none of us have ever had a problem with it.
  12. pony96
    pony96
    from tn
    I used it on several small places and I have had no problems.
  13. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    You got the job to re-do and you've never heard or worked with allmetal.
    Makes me wonder. That's all.
  14. RPaciotti
    RPaciotti
    Allmetal should be used as a 1st coat over a weld seam, then plastic over that. The advantage of allmetal is that it will not absorb moisture through the porosity of the weld like a plastic filler would.
  15. lil av8
    lil av8
    id like to explain my reply a bit more, we would use it on welds that were ground and sandblasted or a mac brand resin wire wheel, let allmetal sit over night sand down with fresh 80 grit on da leaving just a skim in the welded seam area never had problems this was a old guy teaching a young guy (ME) lol
  16. Racewriter
    Racewriter
    Allmetal is still around; I've seen it at the place where I buy my materials. I prefer Duragl*** for the first-coat over the weld, but I've used Allmetal with no problems.
  17. Chevy55
    Chevy55
    from Nebraska
    I have used it a lot in applications listed above just to seal welds and used in areas where the factory leaded seams had cracked. It has lasted 20 years on a couple of our cars. I like the stuff.
  18. moparmonkey
    moparmonkey
    from NorCal
    Wait, you're complaining about a filler because it's hard to remove? That would be a GOOD quality to have in a filler. I don't know about you, but I wouldn't want my body filler to just fall off and take my paint job with it.
    The only people I've ever heard complain about all-metal, or Metal2Metal as its called now, have never used it properly. :mad:
    My old man, and I by default, used it exclusively in his restoration shop for years. Unlike the plastic garbage that everyone seems to love, it will not absorb water and rust out your panels. It feathers much smoother than bondo, and as you noted, is a lot harder (gee, more like metal right?). You can wet-sand it all day long, so once you get to finer grits you don't have to worry about breathing it either (and don't kid yourself, a lung full of talc will kill you too). Can't see how anyone can wet sand bondo without having nightmares about their filler falling backward through the hole it ate in their fender.
    Yes, it's harder to mix because it doesn't change color. Yes, its harder to sand because, well, its harder. But it holds its shape better, can supposedly be drilled and tapped (yeah I wouldn't go that far), and can be finished to a damn near polished looking smoothness. And you won't have to worry about those damn rust bubbles lifting your paint down the road, because they won't be there.
    Bottom line, if you actually take the time to learn how to use it, its probably the best filler out there besides lead. Is it harder to learn to use than bondo? Hell yes. But its 10x the product. And if this sh*t was easy, everyone would be doing it.
  19. thesupersized
    thesupersized
    i've heard nothing but bad things about all-metal, therefore i never bought it. but it seems to me, the "harder" it is, the more prone to cracking as it will be more brittle
  20. BuiltFerComfort
    BuiltFerComfort
    A buddy suggested I try allmetal for repair of pitted pot-metal trim, that would then be powder coated. I think the idea was the metal in the allmetal would help the powder coating process. Any feedback on that idea?
  21. caper150
    caper150
    read post #10, seems to work for him??
  22. bowtie40
    bowtie40
    I've used it to skim coat a cowl vent I welded up on my 40 chev, after regular body filler "shadowed" after a couple of years, I'm glad I did, because I've had no problems since, and it's still hangin' in there
  23. Seems to me the filler isn't the mistake, the alignment of the replacement body panels before they laid the filler on, is the mistake.
  24. plymouth1952
    plymouth1952
    used it for years as over welds as stated never had lift or shift filler still use it on some projects.
  25. Speedmaven
    Speedmaven
    Years ago, I had an OT late model Mustang that some clown had butchered a big hole in the roof for an aftermarket leaker sunroof. I removed the roof skin via 3/4 million spotweld removal, and laid on a solid roof skin from a boneyard donor. I used Allmetal on the roof seams on the C-pillars, as there had been a factory lead joint there. After finishing and repaint, you couldn't tell it had been done, and it's still driving around my hometown...
  26. gearheadbill
    gearheadbill
    There are a lot of up and coming young guys who have mad skills but are too young to remember Allmetal...or lead...or arc welding...lots of other "ancient technology".
  27. K13
    K13
    Be very careful with it when powder coating. It can work sometimes and can let go sometimes it completely depends on how the powder coater does his work. The temperatures used, how quickly he heats stuff up, cools things off, how thick the part is, how thick the filler is etc will contribute to whether or not it works. There are specific fillers designed for powdercoating that I would use before Allmetal or Metal-2-Metal (which are two different products made by two different companies)
  28. redo32
    redo32
    K13, what fillers do you use under powder coat?
  29. K13
    K13
    I have never personally used it but dodgerodder on here used one made by Tiger Drylac which is a powder coating company on his RPU frame. They are usually epoxy based and a ***** to sand but are not as vulnerable to problems as the polyester based products mentioned above.
    I actaully work for one of the companies that make one of the polyester based products mentioned above and we definitely DO NOT recommend using it for powdercoating. It is pretty much a **** shoot as to whether it will work or not even if you know all of the factors involved.
  30. theHIGHLANDER
    theHIGHLANDER
    Yes indeed...
    This is why "where" you use it is as important as how you use it.
    Well, yeah...
