66 thunderbird HELP!
Discussion in 'The Hokey Ass Message Board' started by loaded dice speed shop, Aug 25, 2010.
  1. loaded dice speed shop
    I am working on a 66 thunderbird conv windows have no power to them and do not roll up and down . does anyone know a good spot to get a wiring diagram for this car , all fuses and relays good. thanks
  2. 61TBird
    61TBird
  3. flynbrian48
    flynbrian48
    My first guess would be that the window switches are corroded, a common thing in old convertibles. You can (carefully) take them apart and clean the contacts. Have you tried checking things with a test light?
  4. thunderbirdreg
    thunderbirdreg
    from Toronto
    The power window relay is on the firewall on the top about the middle, did you check that one?
  5. loaded dice speed shop
    thanks , I will check the relay , already check sw with a test probe no power to them I will let u guys know what i find . Thankyou for input!
  6. Joe Johnston
    Joe Johnston
    from Ohio
    The best advice is to join VTCI and then you can get all the manuals at a reasonable price. Please get all the convertible manuals too, you will need them!!!! (don't ask how I know)
  7. jetmek
    jetmek
    X 2..been there done that!
