Incredible welds
Discussion in 'The Hokey Ass Message Board' started by rusty f100, Oct 6, 2008.
  1. oj
    oj
    B***, being the boat header guy? That B*** can weld for sure, i have welded on some of thier headers (repairs) and they actually get PC7 behind thier weld! How that is done is beyond me, imagine welding stainless steel with contaminants in the seam of the weld - on purpose -and laying down perfect beads going around a tube.
    I've gone bind in one eye so i now have an excuse for some imperfections -gasp!- when i had perfect vision i was just a poor welder.
  2. Boy are you correct on B***ett headers - I think that is who you're talking about! I have a set of B***ett 417 Donovan chrome zoomie boat headers -- they are works or art and Paul B***ett is one heck of a nice guy if you ever call them. I bought them just so I can start the motor with them on!
  3. WelderSeries
    WelderSeries
    Alliance Vendor
    Josh, you're a welding nut bar. Crazy!
    Lincoln 255 Square Wave (with the digital controls) from something like 15 years ago? I pulse with a foot pedal and a small gas cup.
    These are some recent parts...
  4. StinkBug
    StinkBug
    from San Diego
    Not the most incredible in the world, but here are a few brackets I put together for the last car I built. I'm using an old Idealarc TIG 300/300 that was built about 15 years before I was born.
  5. Zookeeper
    Zookeeper
    OK, now that's what I wanted to know! But here's my problem, hopefully you can help: when I TIG, I was taught to use minimum stick out of the electrode, maybe 1/4" or so. While I can produce a nice-looking weld, it's not even close to some of the welds I see here. Now I'm thinking that's because I can't see much of the puddle, I actually find myself looking only at the front end of the puddle because I have the cup so close and minimum amperage ( for better control) on the pedal. So now I'm wondering if more stick-out would help? How much is too much? I don't think I'm in any danger of losing my sheilding gas and I ***ume that's the whole point of such a small stick-out. Thanks again!
  6. CoolHand
    CoolHand
    Alliance Vendor
    This is something I would be interested in knowing myself.
    I've got a gas lens on my torch, but nobody (not even the MFG) says how much stick-out is too much. The consensus seems to be that stick-out should be "minimized", but that's not really what I asked.
    So how about it, gents (I'm looking at you guys here, B*** and jdustu)? What kind of stick-out can you get away with?
    I'd like to know that info for gas lenses and standard shields ('cause sometimes that gas lens cup is just too damned big to fit where it needs to).
  7. Bass
    Bass
    from Dallas, TX
    This is not as elaborate as the stuff Stinkbug just posted (nice work!), but it is hot rod related. These are parts of some motor mounts I made for an unboxed '32 frame with a '57 283.
    I do use a gas lens by the way. I know my stuff isn't perfect...but I try to improve everytime I pick up the torch.
    There's some seriously great stuff on this thread...some of you guys make me embarr***ed to post my welding.
    -Brian
  8. Bass
    Bass
    from Dallas, TX
    Here's one more...a 9" rearend housing for another recent project.
  9. stealthcruiser
    stealthcruiser
    "Embarr***ed"..........................You're killin' me, Brian.......................
  10. jdustu
    jdustu
    from Detroit
    The stick out on the tungsten can vary. There are rules of thumb, but I just do whatever works. This is just another one of those things that welders argue about..."this is how you do it" "no, no, THIS is how you do it!"
    It depends on your tungsten size, the cup size, the cup type, the joint, the gas flow, the material....and so on and so forth. It's all about reading the situation and adjusting accordingly. Is the puddle not smooth or is it full of porosity, is my tungsten discoloring, is the arc erratic, is my bead dull?...just a few things that could be caused by the wrong gas flow, tungsten stick out, arc length, angle, bad gas, machine settings....
    No kidding...lol
  11. jdustu
    jdustu
    from Detroit
    I can't really post pics of the stuff I do at work...but here is a practice piece I did when I was stressed out last night. How I relax lol
  12. 51 Hemi J
    51 Hemi J
    Hey Dallas, its Neil from over on Pirate. What heat setting are you using with your Idealarc on these pieces?
  13. jdustu
    jdustu
    from Detroit
    I'm not really a pipe welder, but it's fun to mess with every now and then. I don't think much looks cooler than tigged pipe.
    Some of the guys that do pipe welding for a living lay down some of the sickest welds...mine just have a cold.:D
    Couple of fillets I did last night for practice.
  14. langy
    langy
    Incredible indeed mate.
  15. coopsdaddy
    coopsdaddy
    from oklahoma
    B***...would like to know your process on making a weld look like that,i learned how to walk the cup in votech but cant seem to make that type of weld,lots of heat,low pulse setting?what size filler rod and tungstun do you guys think is the best for sheetmetal,1/8,3/16,thanks,you guys should be proud of what you do.
  16. lostforawhile
    lostforawhile
    they use mig for all of the chromealoy at work, and we also have some incredible tig welders, it's too bad so many got laid off, airplane welding is a real art, and at one point they had one hell of a weld department, we had guys who had been with the company welding for 40 years, a good friend of mine who runs the weld shop and one other welder are all thats left. airplane welds look just as nice as those good looking welds but also have to be strong. we have one woman who does nothing but tig and only comes in sometimes, best tig welds i've seen in my life.
  17. VOETOM
    VOETOM
    from MO
    Having a pal that welds weapon components for a living that also was a professional welder helps when you weld 304 st. st VOE mufflers! Check these out!
    Tom
  18. speedmetal
    speedmetal
    from houston
  19. 392_hemi
    392_hemi
    Re: stickout with a gas lens, maybe check some of the guys who build Ti bicycle frames. They have the electrode way out, and I mean like 1/2" or more. Guess it doesn't really matter as long as gas flow is sufficient to keep everything covered.
  20. noboD
    noboD
    You guys are incredible, thanks for sharing your secrets.
  21. PhilJohnson
    PhilJohnson
    My "Incredible" welds :rolleyes: Welding computer case metal to a rusted out car body using a stick welder. They aren't pretty at all but they hold.
  22. krackerjack88
    krackerjack88
    from Fresno,Ca
    Here's some aluminum I did today. TIG.
  23. rusty f100
    rusty f100
    from CHICAGO
    Incredible in its own right.
  24. bill wallace
    bill wallace
    If you are having trouble seeing the pudule 'CK Welding" sells clear pyrex cups & the gas lens to go with them in a veriety of sizes. The largest is used for Ti welding. These are for DC tig only as AC deposits on the cup & ruins it. Electrode extension is dependent on conditions of the weld For instance on a fillet where the gas can trap itself more extension is used & some times in odd positions where extension is needed the gas flow may be raised. Using a gas lens allows better coverage of the gas & is the prefered method for thin materials.
  25. GARY?
    GARY?
    Many ***anium builders use a large lens and nozzle which allows them to stick the tungsten out there a ways. Where I works sells a cup for ***anium welding. It's inside diameter is 24mm.
  26. jdustu
    jdustu
    from Detroit
    This is a wheel off a bulldozer track that needed a couple low spots raised.
    I put two 1/8" rods together and did a little free hand weave all the way around on the top and bottom.
  27. itsnotaratrod
    itsnotaratrod
    from california
    its hard to follow jdustu but heres my contribution..
    root p*** on 1/4" plate.. i weld all AL at school so i jump at the chance to weld some ms whenever i can ..
  28. jdustu
    jdustu
    from Detroit
    I think somebody asked about stick welding a while back. Last night I found out my GMAW-P plates p***ed X-ray, so I messed around with this bad boy at school today:
    It's so freaking smooth. I did a 1" thick plate with a K joint using 5/32" 8018 electrodes. It's hard to see in the pic, but the root p*** came through the back side really nicely. I need to get a bigger shop so I can start collecting some of these machines :D
    The back of the root:
    front finished
    back finished
    Pretty happy with it considering I don't stick weld much. I forgot how much fun it is. Especially compared to spray transfer pulse welding lol
  29. 392_hemi
    392_hemi
    That looks like the setup for an AWS guided bend test. If it is, shouldn't the edges be beveled?
  30. jdustu
    jdustu
    from Detroit
    Those pics ****, but one plate's edge on the front and back was beveled, and then the other plate is flat. It's a k joint. Plates were 1" thick, and it was X-rayed not bent. It was mil spec, not AWS, although they are similar....and it p***ed.
