56 Olds guys., Need wiring schematics for the instrument cluster
Discussion in 'The Hokey Ass Message Board' started by Von Rigg Fink, Aug 26, 2010.
  1. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Any of you wiring gurus? or guys with 56 olds that might have a wiring schematic for the instuments , could you post up a drawing?
    It will make life easier for me..i could chase them all down but , am hopeful for a time saver
  2. fordcragar
    fordcragar
    from Yakima WA.
    Isn't the wiring on instrument clusters fairly generic?
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    im not really sure..and its not going back in a 56 olds its going in a Hot Rods dash..just kinda would like a schematic so i dont fry anything important or have something not working properly because i rushed it and did it wrong..
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Dont have one but since its GM this may help.
    Rt Turn Signal 20 ga Dk Blue
    Left Turn Signal 20 ga Lt Blue
    Dash Lamps 20 ga Gray
    Fuel Sender (push on) 20 ga Brown
    Fuel Gauge (push on) 20 ga Pink
    Oil Lamp 16 ga Dk Blue
    High Beam 20 ga Lt Green
    Temp Sender (push on) 20 ga Dk Green
    Temp Gauge (push on) 20 ga Pink
    Gen Lamp (2 wires) 20 ga Brown
  6. batt69nova
    batt69nova
    from OR
    I've got a shop manual for the 54 olds-It's got color schematics in it for wiring, and also trans etc.
    I'm at work right now, and it's at home...PM me if you think that the 54 diagram could be of help, and I'll scan it.
  7. gregneun
    gregneun
    from SoCal
  8. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Wow dudes, thanks
    I think i can figure it out with those..
    i want to figure out where everything goes, some i have gotten, i need to look close at those drawings and see how they had the fuel sender wired up...and a few other things that werent clear with just looking at the back of the cluster
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I looked at mine and i have Grey and Yellow for the fuel gauge..(original 56 wires)
    im thinking my yellow is the + power to the gauge..and the grey to the sender .
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes grey is sender, however the yellow im not sure. Easy to test, if yellow has power with key on then thats your Ing. power for gauge. The colors I put up are for another GM 56 model.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    well i took a shot at it.. wired the grey to sender, and yellow to power..grounded both of them and got nothing..I ran the sender thru its range and nothing happened..
    although when i hooked it up it pegged the gauge at empty, so i know its sensing something
    so now what? dammmit
    i never get the easy ones
    anyone know if the olds gauges need a voltage drop? if they can run on 12 volts or need to be reduced?
    tried 6V too..nothing
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is the cluster in the dash board when your testing it. Or I should say is the cluster grounded. It needs to be grounded.
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah i even pulled the gauge and grounded it, to be dam sure that wasnt it..i think its shot:mad:
  15. 123
    123
    from Seattle
    This is all I have, it shows the connector for the gauges but not the gauges them selfs.
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ive decided that the fuel gauge is dead,,innop.
    so I am disecting a known good gauge and corrisponding sender, and fitting it back into the cluster
    next week i should have a working fuel gauge..wish me luck
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    3 weeks and 3 days ago, anything new to report ?
  18. BOWTIE BROWN
    BOWTIE BROWN
    no, i just parted a 56 . More wiring then i got pubic hairs.
    good luck .
