Looking for some history on this possible "A/FX" car.
Discussion in 'Off Topic Hot Rods & Customs' started by Brahm, Aug 12, 2010.
  1. Brahm
    Brahm
    I came across what I was told was an A/FX car. I haven't run the vin yet, but I have a few concerns and doubts before pick it up. I may regardless just because I think it's damn cool to find an original 60's drag car like this, but not at asking price.
    Basically, the run down that I was told is it was a "factory race car" (1966-67 Camaro), that was purchased new and turned into an A/FX car. When I heard this I was skeptical, but there is one things that leads me to believe this may be true is that the doors are factory GM fibergl*** (stamped with a gm logo in the sill about 2"x2" and they are the best quality fibergl*** doors I have ever seen or felt. They close better then my steel doors.
    Outside of that it's got your typical 70's drag car build. Straight axle, struts, tilt front end, set back engine, and of course.. fancy pearl paint job!
    The car was purchased by it's current owner in the 70s, from what I understand is a racer named John Messos. (but I can't find any info on this guy), and has been sitting in storage since the 70's
    With that said, the bad, and what leads me to believe it wasn't a "PRO A/FX" car is the quality of the welding on the cage and some of the work on the car, the square tube used ect, the frame ect looks fine but the cage work is rather shotty. (see picture with gauge note:booger welds)
    I showed it to a friend of mine who much more verse then me, and he believe it was more of a run of the mill home built drag car that may have been built in the 60s. (still cool in my books..but not sell every project i own cool put it in my living room and tie it off with a velvet rope)
    The car has been painted at least 3 times, originally it was factory red, ontop of that is a black, and ontop of that is it's current colour a pearl white, with blue mutlitone pearl.
    The front end and the trunk is gl***, the rear end is a Pontiac w/big gears a spool and henry axles.
    Thanks for the help, and insight guys!.
    Gasser 57 and swade41 like this.
  2. 4Door54
    4Door54
    from Nor*Cal
    That things pretty cool.
  3. mart3406
    mart3406
    from Canada
    I'm not aware the GM ever made any fibergl***
    doors for a '67 Camaro, least of all with a GM
    logo on them. Remember that in 67, GM was
    officially 'not racing'. I know a few teams got
    some help and some 'special parts' via the back
    door of the various GM division 'engineering
    departments', but why Chevy engineers would
    go to the trouble and also, run the risk of getting
    caught, making up a small run of fibergl*** doors
    - and with a GM logo on them even - when
    the aftermarket could more easily supply them,
    escapes me. That's not to say it couldn't or
    didn't happen, but it seems unlikely.
    Mart3406
  4. Brahm
    Brahm
    Thanks for the responses, I'll take some pictures of the doors tonight, I'm going to go back by after work.
  5. Deuces
    Deuces
    Looks like the old Rislone car.... I could be wrong..
  6. Zig Zag Wanderer
    Zig Zag Wanderer
    this car was probably not an a/fx or a funny, i believe it was a b/gas type car
    also keep in mind that the construction methods originally used could be pretty crude by today's standards
    57Fury440 likes this.
  7. roughneck424
    roughneck424
    That would look good at Famoso!
  8. zigzag is likely right that's an old g***er a friend has a trans/am mustang built by the ford factory and the welds don't look any better than that
  9. Brahm
    Brahm
    Thanks again for all the replies guys. One thing I forget to mention (not sure if it matters) is that the original wheelbase of the car was 118", and then was reduced back to stock at some point.
    The other thing that sticks out to me is the rear spoiler/trunk. It's the exact same setup as the Wild Thing II
    all the camaro rear spoilers i've seen outside of these 2 are the entire width of the car, while these spoilers are just the width of the trunk. Not saying it's the same car, but the gl*** came from the trunk gl*** came from the same place. I also read somewhere the WT2 had fully functional doors..which this has as well which leads me to believe maybe all the gl*** could have came from the same location?
    Deuces likes this.
  10. plymouth1952
    plymouth1952
    I thought the same thing but it had lace in the dark blue as I recall but its a repaint. kool any way you look at it I would gess a gl*** over factory doors if theres a gm mark on them
  11. Billybobdad
    Billybobdad
    What is the asking $$
  12. Brahm
    Brahm
    I thought that as well, but the GM mark isn't the same as the stock GM mark. It's a rather larger I'd say 2"x2" with an 1/8th" emboss, and not in the same location either.
    From what I can tell, the car was originally that dark stock red, then it was painted black, which now that I think about it could have just been a coat to make sure the white didn't bleed red threw. Then the colour it's painted today.
  13. Brahm
    Brahm
    I'm not really going to get into cost, location, ect. Until I either have the car in my possession, or have decided to p***. I hope you guys understand.
  14. Deuces
    Deuces
  15. I don't blame you, someone might try to buy it out from under you! ANY '67-'69 Camaro is going to draw big $$, I'd ****** that up if at all possible! Welds can be fixed.
  16. mart3406
    mart3406
    from Canada
    If the wheelbase was out to 118 inches and
    then later put back to 'stock', that *could*
    indicate that the car had been been originally
    built as an 'FX'er' and then later, perhaps
    when it when was no longer compe***ive as a
    funny, been 'front-halfed' and had the
    wheelbase shortened in order to run in one
    of the Altered cl***es. That wasn't an
    uncommon fate for some of the early
    'first-generation' funny cars.
    Mart3406
  17. Brahm
    Brahm
    Thanks again Mart, what should I look for? I'm going to head back out today after work are they anything in particular, I should pay attention to things I should try to get shots of that will help identify the car? I know the gl*** doors are a big thing, what about frame mounts? Rear end setup??? Anything that may be unique to the era or specific cl***?
  18. yellow wagon
    yellow wagon
    from WI
    that thing is killer!!! I hope you end up with it!
  19. mart3406
    mart3406
    from Canada
    A few things things come to mind. Maybe send me a PM.
    Mart3406
  20. Brahm
    Brahm
    ok a few more pictures, here are the doors I talked about
    This is the state of the paint
    and here is the "odd" rear suspension
    Deuces likes this.
  21. HELLBILLY
    HELLBILLY
    4406
    from Oklahoma
    That is a very cool car. You should buy it before someone else does,the find out about the history. Lost out on a maxwedge car once. Goodluck
  23. stlouisgasser
    stlouisgasser
    That's a very cool car! It's definitely not Kelly Chadwick's car that's pictured above because Mr. Gibson has that one presently under restoration. Buy it now and with the power of the HAMB, I bet you can trace it's lineage. This website has been responsible for finding old Drag car history in a metter of hours sometimes!
  24. jamesgr81
    jamesgr81
    Pontiac rear end and "lift ch***is". Pretty standard stuff in the day. I have an old Popular Hot Rodding magazine on how to build that suspension.
  25. Brahm
    Brahm
    Hmm, I've never seen that setup in person. The quality is just so shotty. It's really giving me some second thoughts.
    Also on an unfortunate note, yesterday either somebody clipped it as it sat on the street, or it got damaged when it was being moved. It's not a huge dent, but right behind the door the body got pressed in maybe about a 6" circle..it pretty much was straight before that.
    Deuces likes this.
  26. Is that this car on eBay: Item 330465188948
    Check out the vin on the car in my link.... Interesting.
  27. pont406
    pont406
    i would guess by looking at the red plexi back window with slots/holes cut in it,and straps holding it down, and parachute, it looks like an early funny car or g***er to me, as they may have run it with no side gl*** at one point. the GM gl*** doors are interesting! time to get out the old drag mags i'd guess .
  28. Brahm
    Brahm
    same paint scheme, but not the same car. That car still has the stock subframe, this one it has been replaced with square tube and a straight axle.
  29. Brahm
    Brahm
    no side windows
  30. Falconred
    Falconred
    Being a Ford man I know very little about Camaros but back then a lot of fibergl*** was made by making molds of original steel parts. Do stock Camaro doors have that GM logo on them? If so that would account for the logo. Either way that would be a neat car to buy and make a survivor.
