Projects Crosley engine build
Discussion in 'The Hokey Ass Message Board' started by Deuce Chev, Aug 15, 2010.
  1. Wooly
    Wooly
    Hi,
    My other post didn't post. But to add an oil filter you use the main oil p***age that goes all the way down the crankcase. You put a plug down the p***age from the front of the motor just p***ed where the oil pump inlet into the p***age is.
    Then go behind the plug and re-enter the oil there.
    Use the screw in plug hole in the p***age on the front of the motor with an AN fitting
    for your oil filter inlet.
    Then another AN fitting to put the oil back in.
    Make sure you get the clearances right on all the gears on the tower shaft.
    Dodge
  2. Wooly
    Wooly
    Hi,
    Forgot to ask you if you still have the Areojet intake/exhaust manifold by any chance, I need one for a boat project.
    Thanks,
    Dodge
  3. chevy43
    chevy43
    There are some advantages to leaving the original byp*** oil filter system. Byp*** systems usually filter the oil finer. If you have a clean engine to start with and you are the only one working on it and changing the oil, it is very unlikely that you will ever get any dirt pumped through the engine.
    I always put a powerfull magnet on the drain plug to pick up any iron.
    I have been driving a Crosley, Chevy, and Jeep for years with just byp*** filtratration and I see no evidence of any more wear on my drain plug magnets. I am very carefull not to drop any dirt in any engine while adding, checking or changing oil.
  4. Wooly
    Wooly
    Take the motor apart and see which system you like better..............
  5. Deuce Chev
    Deuce Chev
    from Pacific NW
    For ease this go around I'll probably go with a byp*** filter system. I'll try the other method on the next Crosley build...
    kiwijeff likes this.
  6. Wooly
    Wooly
    Looks great, good job.
  7. Paul
    Paul
    Editor
  8. Deuce Chev
    Deuce Chev
    from Pacific NW
    I am liking it!!!
  9. plym49
    plym49
    from Earth
    X2 on keeping the byp*** filter. I would suggest adding a PCV, though, to prevent airborne grit from getting into the crankcase via the road draft system.
    More importantly, that is the nicest Crosley motor I have ever seen! Fantastic.
    You get an idea of how tiny these motors are when you see them dwarfed by spark plugs or generators. :)
  10. pdq67
    pdq67
    These are ALL SOHC Crosley engines, right?
    I only know of them in two ways, that a couple a guys in the late '50's to early '60s had a pair and would road race home late Sat. night between Macon and Atlanta, MO and have the cops follow them because they couldn't break the speed limit.
    The other is up at the 1/8th mile strip at Kahokia, MO when I saw two race as g***ers, The yellow one called the "Blown Banana" and I forget the name on the blue one.
    What a hoot to watch them take off like "scalded dogs"!!!
    pdq67
  11. Deuce Chev
    Deuce Chev
    from Pacific NW
    Thanks!it's been a lot of fun to build. I have added a filter to the vent in the cam cover.
  12. ARNIE
    ARNIE
    Here are some shots of the blower motor mock-up for the rail. I will have the engine rebuilt this winter!
  13. Deuce Chev
    Deuce Chev
    from Pacific NW
    I would LOVE to find one of those Pepco blowers....
  14. Paul
    Paul
    Editor
    how much power can the rest of the drivetrain handle?
    that blown motor must be worth at least a hundred horsepower
  15. Deuce Chev
    Deuce Chev
    from Pacific NW
    I don't know what she'll take but I am willing to try and feed as many horsies as possible... (I have spare parts)
  16. Paul
    Paul
    Editor
    atta boy! :)
    missed you at Engels this year,
    we were only there for an hour or two but it was a decent turnout
  17. Deuce Chev
    Deuce Chev
    from Pacific NW
    Yeah, had planned a family vacation to Oregon before I knew the Engels date.
    With that kind of HP what's more concerning than the gear box & rear end of the Crosley is the steering & brakes.... they would need to be thouroghly gone thru.
  18. Paul
    Paul
    Editor
    oh yeah, right, you might want to steer and stop..
    funny how some little things tend to get overlooked
  19. Wooly
    Wooly
    When you start making horsepower you need to do some serious upgrades.
    The rods are whimpy, the cam is whimpy and the buckets for adjusting the valve lash are real whimpy and break real easy. Make sure you have a steel crank and a strapped main crankcase.
    We use a lot of the bearcat stuff in these motors to make them live.
    We have put 100hp down at the rear wheels naturally asperated spining 9500 to 10,000 rpm. with the big bore long stroke motor. 1,000 cc's instead of 724 cc's
    It takes a lot of work but its worth it.
    Dodge
  20. ARNIE
    ARNIE
    ---------------------------------Are these pans still available??
  21. X38
    X38
    Great thread, thanks for the road less travelled information.
  22. Deuce Chev
    Deuce Chev
    from Pacific NW
    Yes. Nick's son Blaz Brajevich will make you one if you want one...
  23. Deuce Chev
    Deuce Chev
    from Pacific NW
    Here's a few shots of the car the engine is going in.....
  24. I love Crosleys (we had a baby blue wagon for a whil when I was little) and this post a great!...
    but MAN I hate the "rhinoceraus horn" they plunked on the front- looks like the pimple you'd get on cl*** picture day!
  25. Deuce Chev
    Deuce Chev
    from Pacific NW
    Awe c'mon... I kinda like it, it's only on the late 1948 models... the "rhino horn" was in a box of parts when I got the car from my grandpa, he must not have like the look of it either!
  26. seb fontana
    seb fontana
    from ct
    The rest of the late 48' grill was way worse than just the horn, made the nose look "buck toothed"..OOoogly..
  27. Deuce Chev
    Deuce Chev
    from Pacific NW
    You'll note that I left that cr@p off!!!
  28. seb fontana
    seb fontana
    from ct
    Yep, and I'm glad you did..Had my Crosley out tonite..Tuning the headlights and the carb..One headlight hits the ground about 3 feet out [on high beam!] and I will have to move the bracket that bolts to the fenderwell..The carb I richen about a 1/32 turn and make a p*** on an uphill stretch, made three p***es and figured the neighbors were about iritated enough..The dog didn't think too much of it either...
  29. Crosley
    Crosley
    from Aridzona
  30. oldgoaly
    oldgoaly
    I've got a motor supposed to have come from a forklift? have you heard of that before? Had to buy it for the midget I haven't found yet.....
