Removing rusty screws
Discussion in 'The Hokey Ass Message Board' started by HemiRambler, Aug 5, 2010.
  1. HemiRambler
    HemiRambler
    Bought a nice old set of ET wheels over the weekend. The only problem is that the screws holding the center cap on are pretty rusty. I REALLY don't wanna have to drill out the broken screws so what good tricks have you used??
    So far I tried an impact driver and of course soaking it with some ATF/Acetone - you can see the heads "move" but the screw ain't budgin'
    Any tips are apprecaited!! Got 20 to get out!!!
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Some heat if you can. Try tighting the screw first then loosen. You get any movement keep working them back and forth,going looser a bit at a time.
  3. curbspeed
    curbspeed
    Kroil. Good product. Should loosen them up.
  4. hotrod40coupe
    hotrod40coupe
    Melt some candle wax into the screw hole.
  5. Ralph
    Ralph
  6. rustdodger
    rustdodger
    kroil x2
  7. Kroil x3. Used it once for a set of lower rockers on a springer that I figured had become reclaimed by mother natures as hers. Soak, soak, soak. Keep 'em wet
  8. DougHH
    DougHH
    aviation industry spray called Aerokroil.
    edit: i guess thats Kroil x 4 huh.
  9. nefareous
    nefareous
    from maryland
  10. Ratrod37
    Ratrod37
    WTF...Next time open the garage door when you run the car!!!!
  11. 53Crestline
    53Crestline
    Aerokroil x5!!! I love that stuff! Could also try some PB Blaster(available at any auto parts store)...but Kroil has NEVER let down. Not once(available online only I believe)!
    After letting them soak in some kroil or something, try hitting downward on the handle of the screwdriver as you twist it too...and like johnevans said, try tightening first and work it back and forth until it lets loose...
    Good luck!
  12. gerrald meacham
    gerrald meacham
    tap them lightly with hammer thin use kroil ,real light
  13. tommy
    tommy
    Because these are such a PITA, I'd use all of the techniques above. I'd heat the head of the screw with a torch, let it cool, add the Kroil and let it work some and then use the impact screwdriver with the correct sized tip. The heat expands the metal breaking the rust seal and letting the Kroil in. The shock of the impact SD breaks it loose. Don't get in a hurry.
  14. Deuces
    Deuces
    Huh??? Wrong thread dude!
  15. Jax2A
    Jax2A
    Another Kroil convert here. Kroil and patience.
  16. DougHH
    DougHH
    if you cant get Kroil, try Rostoff. its not half as good as Kroil but its still good.
  17. HemiRambler
    HemiRambler
    Well today was the day - 99% of them were tighter than a Nun's ...
    Anyways I thought I was being careful and I still managed to break 7 - I guess that's a failing grade ;-(
    The funny part is that out of those 7 - almost ALL were moving - really surprised me.
    I can still move the stubs, but they ain't budgin'..yet!!!
    I 'm debating on welding washers over the studs or just clamping them to the mill table and start drillin'....
  18. I find with a super fine brazing flame on my torch, heat the heads till just red, let cool, heat again, let cool and one more time. Then try moving then a bit. If they move don't rush them. Move back and forward carefully if they seem to be loose enough hit them with penetrating oil of choice.
    and continue the back forth action.
    This may work on the stubs too if there is enough left to get a grip on them.
    Biggest weapon in your ****nal is .....patience
  19. fab32
    fab32
    Have you ever used Gibbs Brand penetrant? After using everything on the planet it's now my choice. Go to Roadsters.com and learn all about it. Take the time to read what has been posted, it's interesting. After learning about it you can order it at the same site.
    Frank
  20. Casey J
    Casey J
    from Ada. MN
    Used half a can of PB Blaster this weekend, worked great!
  21. shortbed65
    shortbed65
    from ne Ill
    Try this for corroded steel screws in aluminum
    leave acetylene soot near the screw boss - bring to neutral flame to burn off soot
    this should leave it at 300-350 degrees (avoids melting)
  22. ATF+BBQ Lighter Fluid - Let soak for 10 minutes or longer.
    Screwdriver & Hammer - Hold pressure on screwdriver and give it a couple of whacks.
    Lefty Loosey.
  23. B21A
    B21A
    from Canada
    chemicals chemicals chemicals- mother nature is best-exposure to water cause-solution.
  24. mikeco
    mikeco
    from virginia
    If you mess up the caps let me know. I have 4 new ones that have been sitting in the garage for years.
