And so, it begins.... '55 Ford Mainline.
Discussion in 'The Hokey Ass Message Board' started by Sid13, Aug 28, 2010.
  1. Sid13
    Sid13
    Well, I picked up this gem back in Febuary because we kinda out grew my ol' '65 Chevy truck. Kinda got old stuffing a family of 4,with 2 teenage girls, into the truck when goin' to a show. So, I sacrificed the truck and luckily the following weekend I sold the truck, I drove this baby home.
    So far, I've replaced the valve cover and push rod cover gaskets, new fuel pump,tune-up and did the 12v conversion. The seats are toast but it's all there. Next up, is some patch work on the p***enger side floor and fenders. Plans are to do give this baby a shave and lower it. I'm gonna keep the I6 and split the manifold & run straight pipes to piss off the neighbors.:cool:
  2. 56 ford custom
    56 ford custom
    from Socal
    Looks like a great project. If you need anything let me know.
  3. Sid13
    Sid13
    Thank buddy! Will do..
  4. Sid13
    Sid13
    Got a couple more....
    A little clean-up & paint...
  5. spiertb
    spiertb
    Wow; Look at all those delete plates--heater, radio, and clock!! And three-on -the-tree to boot! Neat car. Syl
  6. pdq67
    pdq67
    You got yourself a real sweety there!
    pdq67
  7. tommy
    tommy
    Yeah. I had to buy all of mine for my 56. I'm making a mainline out of a Customline.
    You can buy pressed pleat seat covers from J.C. Whitney for small money and install them yourself. Mine came with them already installed by the PO.
    Yours is looking better already!
  8. t-vicky
    t-vicky
    from Kansas
    They also came with no arm rest, no sun visors, no nothing.
  9. Sid13
    Sid13
    Thanks guys!! Yeah, it's "bare bones". It's okay though, I'll work with what I got.
    Hey tommy, thanks for the info on the seat covers!! I'll check that out.
  10. Sid13
    Sid13
    After a few cups of coffee, I got an idea to make the tail light lenses look a little better till I buy new ones. I had a can of metallic paint on the shelf an gave it a whirl. Here's how they turned out....
    Lookin' a little rough....
    Before & after some paint.....
    What I used....
  11. Chili Phil
    Chili Phil
    There are a lot of later model truck 6 cyl parts that are relatively cheap ways to add power to that little 223. Good motors.
  12. Sid13
    Sid13
    Cool!! Thanks Phil!!
  13. loveoftiki
    loveoftiki
    from Livonia,Mi
    Cool start to what can be a sweet car
  14. Sid13
    Sid13
    Thanks Tiki. Gonna a fun project...
    Gonna take a look in the Tech section to see if anyone has split the brake lines on this type of car. I split the lines on my '65 Chevy truck using a 70's master cylinder for an Impala/Caprice. Worked out sweet...
    Plus, a little safer...
    kinda like this...
    during installation...
  15. JeffB2
    JeffB2
    from Phoenix,AZ
    Adding a dual master to your Ford is EZ to do and EZ on your wallet,I sent you an invitation to join the 1952-56 Ford owners group here on the HAMB,watch "your notifications" in the upper right side click on it,do a "new guy" intro first and then post the master cyl question and I'll hook you up with all the part numbers you'll need.You will find a wealth of info at the group with almost 400 members and lots of pics too.
  16. Sid13
    Sid13
    Got it. Thanks a bunch Jeff!
  17. Philbilly
    Philbilly
    Looks good man! Keep us posted.
  18. Sweet '55 Mainline. Ozelle the '55 Ford (a Fairlane Town Sedan) and Henrietta the '38 Ford pickup are both impressed and send friendly horn honks. These are good driving cars, only thing you need to really watch for is that the front crossmember directly under the radiator that the front legs of the lower control arms attach to is bad to rust out on these cars. Good idea to crawl under it and poke around on that crossmember with a big Phillips screwdriver to find any spots that are weakened by rust. One of my cousins wrecked a '55 Fairlane Club Sedan because one of the control arm bolts pulled through a rust-weakened crossmember. As long as that crossmember is solid and front end parts are not worn out, these cars drive really good. I worked in a body shop when I was in high school, and our parts chaser was an old white '56 Ranch Wagon that had the same 223 six and 3 on the tree setup as your '55. That thing would haul, could easily bark the tires when you shifted from low to second. Those engines are simple, reliable, easy to work on, and as others here have noted, they take very kindly to some inexpensive performance upgrades. It's easy to upgrade to disc brakes. I used spindles, rotors, and calipers from a '76 Mercury Montego, a straight bolt-on swap.
  19. Unibodyguy
    Unibodyguy
    Rather than trying to split the manifold, I would just look for a header from like Clifford Performance in Temecula CA. That would be a lot easier and less BS than the split. Espesiclly since 3&4 portsd are simeased togther. Great little motor and good on gas when you take it easy on it. Just wish it had overdrive since your gears are like 3:92's. 55-60 about as fast as you want to go even with taller tires.
    Michael
  20. Sid13
    Sid13
    Thanks Philbilly!! Will do..
  21. Sid13
    Sid13
    THanks for the "horn honks"!! Yes, they're good driving cars and simple to work on. Yes, I did look underneath for signs of cancer in tose areas and looks like I'm good to go. thanks for the heads up... And thanks for disc brake conversion info!! I was wondering about that..
  22. Sid13
    Sid13
    Yeah, those Clifford Performance parts are nice but a little outta my price range for now. But I will revisit them later down the line... I've done a few manifold splits and I don't mind doin' it just to make little noise around the neighborhood.:D
    Yes, she tops out @ 60mph but it's cool for now.
  23. Spent a lot of time on this one. Fun car.
