VEGA or REVERSED CORVAIR????
Discussion in 'The Hokey Ass Message Board' started by brawal128, Sep 1, 2010.
  1. brawal128
    brawal128
    I'm wondering if you can use a vega steering box the same way as a reversed corvair for traditonal steering? Or do you just buy the Corvair? I'm working on a budget and the price difference is 175$. Any help on this subject would be nice.
    Thanks,
    Brandon
  2. steel rebel
    steel rebel
    Their are other options. I still see old Ross steering boxes at swaps pretty often. I think Von Franko used a 60-70 aluminum mid size Mopar box.
  3. thunderbirdesq
    thunderbirdesq
    No, a Vega box is for a "side-steer" draglink setup, and reversed corvair is used for traditional fore-aft draglink steering.
  4. brawal128
    brawal128
    I know Vega is for cross-steer, but I didn't know if you could flip it on its side and use it like a corvair?
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    As out-of-place as it would look on an otherwise traditional hot rod, yeah, they can be mounted like that and even reversed the same way as the Corvair box.
    Honest question: Why are you limiting your choices to Corvair or Vega?
  6. brawal128
    brawal128
    That's just what I've seen in the aftermarket parts. What are some other options that I could use that would safe and reliable? While not having to go junkyard scavaging.
  7. kingpins
    kingpins
    exactly there are a **** ton of great boxes to use.....
  8. Smokin Joe
    Smokin Joe
    Old School used to be F 100 boxes on top of the frame. Lots of choices.
  9. brawal128
    brawal128
    F100 box is one option. What other options do I have???
  10. CYCO_FISH
    CYCO_FISH
  11. Kevin Lee
    Kevin Lee
    Super Moderator
    All ******** aside, sure seems like a tough row to hoe if you're not willing to scavenge and looking to aftermarket as your first option. If you're truly on a budget I would suggest poking around here for a while and doing some research.
    F1
    F100
    Nearly any Ford 32-48
    Early GM
    Hudson
  12. brawal128
    brawal128
    SmokinJoe- I found a 80 F100 manual steering box used for 149.99. Think that is a reasonabl price?
  13. Kevin Lee
    Kevin Lee
    Super Moderator
    ***uming "80" means 1980, seriously just stop shopping and start researching. If you're set on an F1/F100 box you should be looking for anything from 1948 to 1956.
  14. brawal128
    brawal128
    I am researching Kevin Lee, your advice has opened my eyes to alot of ideas. Understand too, that I am not a seasoned hot rodder. I am learning as I go and any input is much appreciated. This will be my first hot rod build and I'm trying to learn from seasoned hot rodders such as yourself.
  15. Old Mustang boxes were once a ubiquitous as the Vega, especially with a 4 bar. I know most don't consider the 4 Bar set up traditional, (I disagree) but that's an argument for a different day. I think it may even be the same box as the Maveric, the Mav. ones I've seen in the yards look just like the Mustang box I have.
    Kevin's right, get out there and scrounge around some. You don't know what you're missing.
  16. At the risk of hi-jacking this thread, I have a reversed Corvair for traditional steering. Any opinions on whether to mount it inside the cowl or outside the firewall. I too, am learning as I go. I have a steel body with a custom frame, so either way, I'm making mounting plates/brackets.
  17. olds vroom
    olds vroom
    diggin in the bone yards is a lot of fun ,and some times you come out with new ideas for your ride you had not intended or thought of yet.
  18. falcongeorge
    falcongeorge
    from BC
    When you say "early GM" what years/applications are you talking? The F1/F100 boxes are getting thin on the ground now.
  19. kingpins
    kingpins
    kevin lee has mentioned some good boxes....46 chevy are good boxes ive used, easy to find boxes like 65 mustang boxes are good (running one on my roadster). ive never paid over 60 bucks for a used box here in NC. listen to these guys man....shop around and cool you wallet down.
  20. kingpins
    kingpins
    first advice...TAKE YOUR TIME!!!!! SHOP AROUND. im almost done with my roadster and just over $2,500 into it....trade, swap meets.....im a craigslist monster...there are good deals out there just gotta look
  21. Kevin Lee
    Kevin Lee
    Super Moderator
    Yup, I fully get it. Learning as you go... that is exactly how I did it. (and still do it, and will keep doing it) But understand that from here it looks like you're more willing to buy as you go. We're just trying to save you h***le.
  22. 29woodie
    29woodie
    from boston, ma
  23. need louvers ?
    need louvers ?
    How about sixties Ford Chevy and Dodge vans? Practically any Ross box from hundreds of applications throughout the fifties and sixties? Saw a thread the other day about Suzuki samurai, Haven't looked at that one myself, but will next time at a U-pull it yard. Sixties Chrysler small car stuff looks great and is relatively easy to do as cowl steering. Volvos up until '78 used a kinda cute aluminum box that the Europeans have used for years now. Ya just gotta get out and look!
  24. brawal128
    brawal128
    Thanks guys, I will be taking my time and trying to slow down on the buying. I researched alot last night and found that 65, 66 and 67 mustang boxs are usable. I like the idea of cowl steering (thanks need louvers). I guess something else that I am curious about the the ratio of the steering box. Some are 19.9:1, 20:1, 16:1..... I would think that the ratio is pretty important, but does the ratio make that much difference between 19.9:1 and 16:1?
  25. I took what, at the time, seemed to be the easy route on our roadster. Vega box with cross steer. Very happy with it. No bump steer and the stock ratio works well on this car.
