'65 235-swapping trans.?
Discussion in 'The Hokey Ass Message Board' started by IGOR, Sep 2, 2010.
  1. IGOR
    IGOR
    A turbo 350, 400 or 700r4 doesnt happen to bolt right up to a '65 235 does it? What will I need?
  2. bobss396
    bobss396
    I've done the swap in trucks and cars, its a bolt in all the way, at least with a TH350 and 400. The transmissions are the same length (with the short tailshaft housing). I had to slot the transmission mount holes a bit in one case only, I may have had a mis-match of year parts.
    Just use everything off the donor car and you should be ok. Are you going from a stick to automatic? If so, make sure the 235 block is drilled for a starter.
    Bob
  3. five-oh
    five-oh
    from Arkansas
    I may be wrong, but I thought '62 was the last year Chevrolet made the 235. If it's a '65 model, I believe it will be a 230, in which case it would be a bolt in. I've always been told it would require an adapter to put a turbo 350, ect. behind a 235.
  4. OldBuzzard
    OldBuzzard
    A '65 235???
    <br />
    <br />
    A '65 230 maybe. If so, the above transmissions will fit. The older 235, no.
  5. R Pope
    R Pope
    Yep, '62 was the last Stovebolt. A '65 will be a 230,or possibly a 194, and any Chevy trans will fit, same back end as a V8.
  6. bobss396
    bobss396
    I was figuring it was for a p***enger car. Were the 235s still used in trucks in '65? I forget, been a while since I dove into one.
    Bob
  7. dbradley
    dbradley
  8. IGOR
    IGOR
    The motor is in a 65 step van. Has a powerglide in it now. Guy said it was a 235 but dont know if he knows what hes talking about or not.
  9. dbradley
    dbradley
    '65 "Step Van" will have either a 230 or 292 in there.
  10. dragsta
    dragsta
    the van may not have the orig motor. check out the link with the pics to be sure.
  11. dbradley
    dbradley
    Ask him if it has a spin on oil filter (not 235)......... 235's use a canister with lid mounted to intake manifold.
  12. bobss396
    bobss396
    If he does have a PG in it (odd combo for a step van...) the TH350, etc should bolt up.
    Bob
  13. bowtie40
    bowtie40
    Huh, didn't know the General built the 235 in 65' Sounds like you have a 62 or earlier to me,
    several outfits build an adapter for that setup, (Buffalo Ent. in Stanwood ,Wa. comes to mind...
  14. jcmarz
    jcmarz
    from Chino, Ca
    The guy probably believes all Chevy station wagons are Nomads.
  15. Dirt Diggler
    Dirt Diggler
    Check the casting numbers here. http://www.inliners.org/ If it's a 235 you can get swap out the ****** for a borg warner t-5 transmission
    http://www.stovebolt.com/techtips/t5******.htm
    http://t5conversion.wetpaint.com/
    <table bgcolor="#cccccc" border="3" bordercolor="#000080" cellspacing="0" width="635"><tbody><tr><td valign="top" width="120">[SIZE=+1]Number[/SIZE]
    [SIZE=+1]4001133[/SIZE]
    [SIZE=+1]1970[/SIZE]
    [SIZE=+1]2135412[/SIZE]
    [SIZE=+1]2193980[/SIZE]
    [SIZE=+1]2324003[/SIZE]
    [SIZE=+1]2324004[/SIZE]
    [SIZE=+1]2404929[/SIZE]
    [SIZE=+1]2192402
    289890
    [/SIZE]
    [SIZE=+1]328518[/SIZE]
    [SIZE=+1]328572[/SIZE]
    [SIZE=+1]328575[/SIZE]
    [SIZE=+1]328576[/SIZE]
    [SIZE=+1]328578[/SIZE]
    [SIZE=+1]328880[/SIZE]
    [SIZE=+1]329990[/SIZE]
    [SIZE=+1]352194[/SIZE]
    [SIZE=+1]358825[/SIZE]
    [SIZE=+1]3629703[/SIZE]
    [SIZE=+1]364909[/SIZE]
    [SIZE=+1]366855[/SIZE]
    [SIZE=+1]3692703[/SIZE]
    [SIZE=+1]3692708[/SIZE]
    [SIZE=+1]3692713[/SIZE]
    [SIZE=+1]3693374[/SIZE]
    [SIZE=+1]37001481[/SIZE]
    [SIZE=+1]3701946[/SIZE]
    [SIZE=+1]3703414[/SIZE]
    [SIZE=+1]37127[/SIZE]
    [SIZE=+1]3733340[/SIZE]
    [SIZE=+1]3733813[/SIZE]
    [SIZE=+1]3733946[/SIZE]
    [SIZE=+1]3733949[/SIZE]
    [SIZE=+1]3733950[/SIZE]
    [SIZE=+1]3737012[/SIZE]
    [SIZE=+1]3738307[/SIZE]
    [SIZE=+1]3738365[/SIZE]
    [SIZE=+1]3738476[/SIZE]
    [SIZE=+1]3738813[/SIZE]
    [SIZE=+1]3739365[/SIZE]
    [SIZE=+1]3739716[/SIZE]
    [SIZE=+1]3759365[/SIZE]
    [SIZE=+1]3764476[/SIZE]
    [SIZE=+1]3769716[/SIZE]
    [SIZE=+1]3769717[/SIZE]
    [SIZE=+1]3769925[/SIZE]
    [SIZE=+1]377127[/SIZE]
    [SIZE=+1]377129[/SIZE]
    [SIZE=+1]3773949[/SIZE]
    [SIZE=+1]3777178[/SIZE]
    [SIZE=+1]3782856[/SIZE]
    [SIZE=+1]3782858[/SIZE]
    [SIZE=+1]378307[/SIZE]
    [SIZE=+1]3783949[/SIZE]
    [SIZE=+1]3788378[/SIZE]
    [SIZE=+1]3788406[/SIZE]
    [SIZE=+1]3788514[/SIZE]
    [SIZE=+1]3788813[/SIZE]
    [SIZE=+1]3789404[/SIZE]
    [SIZE=+1]3789412[/SIZE]
    [SIZE=+1]3789716[/SIZE]
    [SIZE=+1]3792852[/SIZE]
    [SIZE=+1]3792858[/SIZE]
    [SIZE=+1]3821970[/SIZE]
    [SIZE=+1]3833057[/SIZE]
    [SIZE=+1]3833067[/SIZE]
    [SIZE=+1]3833340[/SIZE]
    [SIZE=+1]383340[/SIZE]
    [SIZE=+1]3835253[/SIZE]
    [SIZE=+1]3835309[/SIZE]
    [SIZE=+1]3835335[/SIZE]
    [SIZE=+1]3835353[/SIZE]
    [SIZE=+1]3835363[/SIZE]
    [SIZE=+1]3835374[/SIZE]
    [SIZE=+1]3835491[/SIZE]
    [SIZE=+1]3835497[/SIZE]
    [SIZE=+1]3835527[/SIZE]
    [SIZE=+1]3835692[/SIZE]
    [SIZE=+1]3835794[/SIZE]
    [SIZE=+1]3835846[/SIZE]
    [SIZE=+1]3835849[/SIZE]
    [SIZE=+1]3835894[/SIZE]
    [SIZE=+1]3835911[/SIZE]
    [SIZE=+1]3835917[/SIZE]
    [SIZE=+1]3835946[/SIZE]
    [SIZE=+1]3835949[/SIZE]
    [SIZE=+1]3836012[/SIZE]
    [SIZE=+1]3836223[/SIZE]
    [SIZE=+1]3836233[/SIZE]
    [SIZE=+1]3836340[/SIZE]
    [SIZE=+1]3836386[/SIZE]
    [SIZE=+1]3837004[/SIZE]
    [SIZE=+1]3837012[/SIZE]
    [SIZE=+1]3843363[/SIZE]
    [SIZE=+1]3850817[/SIZE]
    [SIZE=+1]3851656[/SIZE]
    [SIZE=+1]3851659[/SIZE]
    [SIZE=+1]3851859[/SIZE]
    [SIZE=+1]3854036[/SIZE]
    [SIZE=+1]3855914[/SIZE]
    [SIZE=+1]3855987[/SIZE]
    [SIZE=+1]3855991[/SIZE]
    [SIZE=+1]3856233[/SIZE]
    [SIZE=+1]3858190[/SIZE]
    [SIZE=+1]386855[/SIZE]
    [SIZE=+1]3877178[/SIZE]
    [SIZE=+1]3879875[/SIZE]
    [SIZE=+1]3886061[/SIZE]
    [SIZE=+1]3890011[/SIZE]
    [SIZE=+1]3890013[/SIZE]
    [SIZE=+1]3892858[/SIZE]
    [SIZE=+1]389770[/SIZE]
    [SIZE=+1]3897702[/SIZE]
    [SIZE=+1]3921770[/SIZE]
    [SIZE=+1]3921967[/SIZE]
    [SIZE=+1]3921968[/SIZE]
    [SIZE=+1]3921970[/SIZE]
    [SIZE=+1]828575[/SIZE]
    [SIZE=+1]837751[/SIZE]
    [SIZE=+1]839770[/SIZE]
    [SIZE=+1]8397715[/SIZE]
    [SIZE=+1]839910[/SIZE]
    [SIZE=+1]839931[/SIZE]
    [SIZE=+1]8994256[/SIZE]
    [SIZE=+1]93403466[/SIZE]
    [SIZE=+1]93403467[/SIZE]
    [SIZE=+1]93406004[/SIZE]
    [SIZE=+1]9787437[/SIZE]
    [SIZE=+1]9790043[/SIZE]
    [SIZE=+1]9795066[/SIZE]
    [SIZE=+1]9890043[/SIZE]</td> <td valign="top" width="289">[SIZE=+1]Make[/SIZE]
    [SIZE=+1]Chevrolet[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]Chev/Buick/Olds/Pontiac
    Chev/Buick/Pontiac
    [/SIZE]
    [SIZE=+1]Chevrolet/Olds[/SIZE]
    [SIZE=+1]Chev/Buick/Olds/Pontiac[/SIZE]
    [SIZE=+1]Chevrolet/Olds/Pontiac[/SIZE]
    [SIZE=+1]Buick[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]GMC[/SIZE]
    [SIZE=+1]Buick/Olds/Chev/Pont/GMC[/SIZE]
    [SIZE=+1]Buick/Chev/Olds/Pontiac[/SIZE]
    [SIZE=+1]Pontiac[/SIZE]
    [SIZE=+1]Pontiac[/SIZE]</td> <td valign="top" width="108">[SIZE=+1]Year[/SIZE]
    [SIZE=+1]76-80[/SIZE]
    [SIZE=+1]64-67[/SIZE]
    [SIZE=+1]46-54[/SIZE]
    [SIZE=+1]52-54[/SIZE]
    [SIZE=+1]55-63[/SIZE]
    [SIZE=+1]55-62[/SIZE]
    [SIZE=+1]Military[/SIZE]
    [SIZE=+1]63-77[/SIZE]
    [SIZE=+1]73-77[/SIZE]
    [SIZE=+1]73-76[/SIZE]
    [SIZE=+1]68-84[/SIZE]
    [SIZE=+1]68-76[/SIZE]
    [SIZE=+1]73-84[/SIZE]
    [SIZE=+1]66-76[/SIZE]
    [SIZE=+1]50-52[/SIZE]
    [SIZE=+1]75-79[/SIZE]
    [SIZE=+1]66-84[/SIZE]
    [SIZE=+1]42-49[/SIZE]
    [SIZE=+1]53-55[/SIZE]
    [SIZE=+1]53[/SIZE]
    [SIZE=+1]54-56[/SIZE]
    [SIZE=+1]55-57[/SIZE]
    [SIZE=+1]58[/SIZE]
    [SIZE=+1]54-55[/SIZE]
    [SIZE=+1]58-62[/SIZE]
    [SIZE=+1]60-62[/SIZE]
    [SIZE=+1]59[/SIZE]
    [SIZE=+1]59-62[/SIZE]
    [SIZE=+1]73-79[/SIZE]
    [SIZE=+1]54[/SIZE]
    [SIZE=+1]62-67[/SIZE]
    [SIZE=+1]53-54[/SIZE]
    [SIZE=+1]62-74[/SIZE]
    [SIZE=+1]62-69[/SIZE]
    [SIZE=+1]62-70[/SIZE]
    [SIZE=+1]55-59[/SIZE]
    [SIZE=+1]63-76[/SIZE]
    [SIZE=+1]63-66[/SIZE]
    [SIZE=+1]63-72[/SIZE]
    [SIZE=+1]62-66[/SIZE]
    [SIZE=+1]67-72[/SIZE]
    [SIZE=+1]63-70[/SIZE]
    [SIZE=+1]42-53[/SIZE]
    [SIZE=+1]48-52[/SIZE]
    [SIZE=+1]54[/SIZE]
    [SIZE=+1]54[/SIZE]
    [SIZE=+1]51[/SIZE]
    [SIZE=+1]53[/SIZE]
    [SIZE=+1]53[/SIZE]
    [SIZE=+1]53[/SIZE]
    [SIZE=+1]54[/SIZE]
    [SIZE=+1]55-58[/SIZE]
    [SIZE=+1]62-78[/SIZE]
    [SIZE=+1]62-76[/SIZE]
    [SIZE=+1]63-71[/SIZE]
    [SIZE=+1]55[/SIZE]
    [SIZE=+1]74-77[/SIZE]
    [SIZE=+1]68-72[/SIZE]
    [SIZE=+1]42-51[/SIZE]
    [SIZE=+1]64-69[/SIZE]
    [SIZE=+1]64-76[/SIZE]
    [SIZE=+1]72-77[/SIZE]
    [SIZE=+1]64-77[/SIZE]
    [SIZE=+1]75-83[/SIZE]
    [SIZE=+1]75-84[/SIZE]
    [SIZE=+1]66-67[/SIZE]
    [SIZE=+1]68-69[/SIZE]
    [SIZE=+1]68-69[/SIZE]</td> <td valign="top" width="102">[SIZE=+1]CID[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]248,270[/SIZE]
    [SIZE=+1]302[/SIZE]
    [SIZE=+1]270[/SIZE]
    [SIZE=+1]302[/SIZE]
    [SIZE=+1]270[/SIZE]
    [SIZE=+1]302[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]230[/SIZE]
    [SIZE=+1]153[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]261[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]230-250[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]230[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]194[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]230[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]216[/SIZE]
    [SIZE=+1]235[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]292[/SIZE]
    [SIZE=+1]230[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]250[/SIZE]
    [SIZE=+1]250[/SIZE]</td></tr></tbody></table>
  16. five-oh
    five-oh
    from Arkansas
    Dirt Diggler, I think I love you! I've been looking for a chart like this for a bit now. This will make determining exactly what I've found easier. Just this last week, my brother in law brought home a '53 pickup that had been fitted with a 261. It took a bit of searching to verify what it was. This will be printed out and laminated for those trips to the junkyards.
