I finally found a new worm gear that matches up with the steering sector on my '51 Merc box. Now I need to yank off the old galled gear and press the new gear onto the 46 inch hollow steering shaft. It is a tight interference fit, with a shallow keyway in the shaft, and if anyone has done this press before, would you share how you did it? Thanx.
With something like that, I would heat the gear and use a press very gingerly. Very light pressure on a hollow shaft situation. Then to reinstall I would chill the shaft and heat the gear. It has worked for me very well in the past.
