tig wire
Discussion in 'The Hokey Ass Message Board' started by ASPHALT RIPPER, Sep 5, 2010.
  1. ASPHALT RIPPER
    ASPHALT RIPPER
    what kind of wire you guys using for welding mild steel and chromoly i use a wire called missle wire. getting hard to find maybe you can help me find or let me know what u use
  2. flatmotor40
    flatmotor40
    from georgia
    for tig I use a roll of mig wire and just cut off what I need and keep on going be sure no flux
  3. youngrodder1929
    youngrodder1929
    ER70s-2 or ER70s-6 i belive both work -6 has more deoxidizing compounds silacon/mangaes ect
  4. harley man
    harley man
    e-80s e2 for moly.It has moly in it.Steel e 70 type wire is just fine and more econmical.The so called missle rod is a stainless wire.I like eutectic 680.Stainless wires are not to be used on moly..................
  5. oj
    oj
    I use allstate 275 and e70s, i think the e70s is 'tougher' and will let the joint flex while the 275 is stronger, so i'll use the 275 for ch***is welding and the e70s for suspension pieces and bracketry.
  6. ASPHALT RIPPER
    ASPHALT RIPPER
    ya the missile wire is a low carbon stainless it says for welding disimilair metals the reason i ask is its 130 for a ten pound box i got it from a off-road shop that tigs everything. were would i get the 275 at "oj"
