Holley carb i.d. by number
Discussion in 'The Hokey Ass Message Board' started by Red 49'er, Nov 16, 2006.
  1. Bozzmotox
    Bozzmotox
    Ok, I have a list # of 9219 2021. I know it's a 4160 model. Can someone tell me all the specifics on this or where I can find the info? I have looked on all the websites and have found nothing. Would like to rebuild, but need info. Thanks
    Deuces likes this.
  2. It's a 600cfm 4160 (as you know)....the Renew Kit is 37-1536 and the Trick Kit is 37-933 (Holley numbers).
    It originally used a .031 pump nozzle; a black sec. spring; and a secondary plate with .073 main holes/.029 idle holes, if you want to check for modifications.
  3. bbbjr
    bbbjr
    i was woundering if anyone could help me with this one. i have a holley model 4160 list number 6515 i cnt find what the cfm is does anyone know? thanks for your help.
  4. ford_george
    ford_george
    I have an old holley and the number on the carburetor are:
    RB 4011-3
    1887
    Does anyone know anything about this carb?
  5. mart3406
    mart3406
    from Canada
    Actually on model 3310 Holleys using either the
    750 or 780 rating is correct and depends on what
    you want to call it. The original 4150-series (ie-
    with the secondary metering 'block') "List 3310AAS"
    carb was an OEM Chevy carb used on 375-HP 396
    Chevelles and Holley rated it at 780 cfm. Later
    when Holley came out with aftermarket versions of
    the carb - both in 4150-series versions and the
    cheaper 4160-series (ie - with a secondary metering
    'plate') they were still rated at 780 cfm in the earlier
    catalogs and then, in later catalogs at 750 cfm.
    However the carbs never changed - the early and later
    versions (both 4150 and 4160 versions) flow *exactly
    the same*
    and the *supposed* 30 cfm reduction in
    airflow rating was merely done for marketing reasons
    - to simplify cataloging and to make carb better fit into
    the Holley line of carbs in nice even 50 cfm increments.
    Mart3406
    Deuces likes this.
  6. arcv1971
    arcv1971
    I have a Holley list # 3796-1 Can you tell me what it is ?
    Deuces likes this.
  7. arcv1971
    arcv1971
    I have a Holley with List-3796-1 Above that # is C8OF-9510-0
    Did it come on a 1968 Ford ? What CFM is it ?
    Deuces likes this.
  8. arcv1971
    arcv1971
    I went to that site but mine is not listed there. Thanks !
  9. johnnie
    johnnie
    from indiana
    They are different. I have both carbs. First ones rated at 780 had downleg boosters. 750 ones have straight boosters. Downleg boosters restrict the airflow less, thus the different rating.
    Deuces likes this.
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    My 1978 Holley Illustrated Parts&Specs Manual lists it for 1967-68 Comet, Cougar, Mustang and Fairlane 390 engines.
    Deuces likes this.
  11. arcv1971
    arcv1971
    that was the # 3796-1
    Deuces likes this.
  12. arcv1971
    arcv1971
    Thank you ! What is the CFM though ?
  13. Checkerwagon
    Checkerwagon
    3796 is the 4V 600cfm Auto Cal. Emisssion
    per mustangtek.com
    (happened to be researching a carb as well) Found the post by using the SEARCH !!!!
    Thanks to all before me, great stuff.
    Deuces likes this.
  14. squirrel
    I just got a 1982 holley book...shows the 3796-1 is the 1968 version of the 390 auto trans carb used on mustang/fairlane/cougar/comet
    Neat book, has more numbers in it than I can shake a stick at
    Deuces likes this.
  15. custom50
    custom50
    from Indiana
    I've been searching today to find out what CFM my Holley is.
    I found out the carb is from a 65 Chevelle HP 327 #3043 595 CFM.
    I called the Holley Tech line. The guy was really helpful.
    Deuces likes this.
  16. FlatHat
    FlatHat
    Please help identify an old Holley four-barrel. It's a square bore with 1-7/16" bores. On the left side of the air horn is stamped "124." On the right side, the first line reads, "C1TLE 9510-AN." The second line reads, "LIST 2349."
    I've been to a dozen or so sites trying to find that LIST number, but I've had no luck.
    I'd like to know the common-usage model number and the CFM.
    Thanks.
    Deuces likes this.
  17. swade41
    swade41
    from Buffalo,NY
    Hey fellas, I got a stumper I can't find these carbs in the book or site. They are on a tunnel ram, single feed like a 1850 600 cfm. The only two numbers are
    5776
    0276
    same on both and the front bowl on the carb says Holley since 1930 or something like that.
    thanks
  18. swade41
    swade41
    from Buffalo,NY
  19. Deuces
    Deuces
    Yours sounds like a Ford Holley carb with those numbers.
  20. Deuces
    Deuces
    I'll see what I can find.. Just give me a few!!
  21. Deuces
    Deuces
    Are you sure it's List-5776???? I know a 4776 and that is a 600 double pumper carb...
  22. swade41
    swade41
    from Buffalo,NY
    I called the Holley tech line and he thinks the first number is a 9. The funny thing is that I was reading one carb while another guy (Fullfendered) was reading the other, we both thought either 5 or an S. The tech said that they would be 450 tunnel ram carbs which sounds right, not that it's worth anything but they are on an Offenhauser tunnel ram.
    thanks for the help though
    Deuces likes this.
  23. pishta
    pishta
    from Tustin, CA
    What model Holley (?) is that wacky round 4bbl carb that is a spreadbore design, but the bores are REALLY far apart? Something like a TQ replacement carb? I know it was a small CFM, like 450 or so. Maybe good for a slant six? No mistaking when you see one, its like "WTF is that?"
    PS>> Holley economaster "baby quadrajet"..Any good or just wacky?
  24. mr.mota81
    mr.mota81
    from colton ca
    :rolleyes: i have a holley with numbers 1850-5 on bottom of that its 1349 and on top it says 6r 7809 can any one tell me anything about this carb...
  25. Looks like 1961 Ford truck by the first few numbers.
  26. mudder
    mudder
    from eugene
    any help wit th # on this holley 6210-3 thanks
  27. johnnie
    johnnie
    from indiana
    4150-G
    1961 Ford Trk., 312 Eng.
    From this site, http://www.tocmp.com/manuals/Carbs/Holley/MasterList/index18.html.
  28. Oldmics
    Oldmics
    That would be a 302 engine designation-Not a 312-missprint :confused:
    No 312 engines were ever installed into trucks from the factory.
    Oldmics
  29. johnnie
    johnnie
    from indiana
    Yeah, my mistake. I kinda thought so. No 302s in '61 either.
