Taking out a Model A gas Tank. Easy or Hard?
Discussion in 'The Hokey Ass Message Board' started by FlatheadsForever66, Sep 8, 2010.
  1. FlatheadsForever66
    FlatheadsForever66
    from Arizona
    I am going to be taking out my gas tank of my '30 Model A. any tips or steps on how to do this?
  2. Metaltwister
    Metaltwister
    Take the goofy clips of bottom lip, loose the fuel line, Take the S/Steel hoop off, remove the bolts along the windshield and lift it out... Did I forget anything guys? :confused:
  3. walrus
    walrus
    Well, maybe drain the gas ?,,,Sam
  4. junk yard kid
    junk yard kid
    sometimes the coil is on there too, you may want to disconect the wires.
  5. FlatheadsForever66
    FlatheadsForever66
    from Arizona
  6. Bikertrash
    Bikertrash
    from Boise
    It's easy. If you are going to use that tank again make sure to get the br*** strainer thing that fits inside the tank. It will save you from many a long walk home. Ask me how I know...
  7. The37Kid
    The37Kid
    You all forgot to mention the screws that attach it to the firewall. Use a screwdriver that is a good fit to the slot, give it a good wack with a hammer, P.B Blaster or other lube and they should come out. If you snap a few off Snyders lists new repo screws. Replacing the cowl lacing is another story, try to preserve it if it looks good to start with......You may need to take the windsheild out to make this a bit easier.
  8. buy the tool they offer at brattons to take out the old gas guage.. it actually worked to get mine out.. worth the 8 bux ...
