Barry Grant 3 duece demon issue
Discussion in 'The Hokey Ass Message Board' started by ruben solis, Sep 10, 2010.
  1. ruben solis
    ruben solis
    problem started with a bad gas tank , (rust) Car puted to a stop. Getting it home I removed and replaced the tank. Next was the carbs these are demonssvery little differene between a holley and a demon. Notied a lot of rust in the center carb cleaned all three out put them back together and it keeps fouling out the plugs so i changed out the needle and seats and its doing the same thing it starts but immediatly fouls out the plugs. Whats queer is by accident I squeezed the fuel line of the front carb with needle nose vise grips and it starts up and runns freat on center and rear carb but the moment i release the pliers it floods it and shuts it down. I have exausted my undderstanding anyone with ideas out there.
  2. Sounds like you've got a FourShooter!
    Better tear that front carb down and clean it out real good.
  3. larry_g
    larry_g
    You've isolated the problem to the front carb it sounds like. Did you do a needle and seat in it? I would suggest that you make sure the float height is set correctly, that you have a gasket on the seat base, and that the needle and seat are good and do not have a manufacturing flaw in them. Flooding is most often caused by to much fuel in the float chamber and the float/needle/seat are what controls that fuel level.
    lg
    no neat sig line
  4. Deuces
    Deuces
    Also make sure your not running no more than 5 psi fuel pressure to the carbs...
