holley 94 progressive linkage picture
Discussion in 'The Hokey Ass Message Board' started by r600, May 25, 2010.
  1. r600
    r600
    can anyone post a picture of what twin holley 94's look like with a progressive linkage fitted???????thanks adrian
  2. brady1929
    brady1929
  3. brady1929
    brady1929
    ****ster27 did my intake and carbs. i will try to get a better pic later.
  4. r600
    r600
    anyone else got a picture of 2x2 progressive holley 94 setup?????cheers adrian
  5. brady1929
    brady1929
    duh, i did not see the 2x2. sorry
  6. Rue13
    Rue13
    from Tacoma, WA
    I'm actually looking for the same thing. Anyone... ?
  7. Blue One
    Blue One
    from Alberta
    This is my 312 tri power done by ****ster27. Eliminate the front carb and linkage and you have your twin progressive linkage :)
    Not too hard to see.
  8. Dale Fairfax
    Dale Fairfax
    Why? 2 x 2 doesn't need or work well with progressive.
  9. Blue One
    Blue One
    from Alberta
    Why not?:rolleyes:
    If you think about it any regular 4 barrel carb is progressive. Whether its mechanical or vacuum secondaries, you run on the front 2 barrels then the rear two open PROGRESSIVELY by mechanical or vacuum operated means.
  10. V8 Bob
    V8 Bob
    I agree with Dale. Running progressive 94's on a 2X2 manifold is plain silly, with NO benifit, only added work, trouble and cost. :rolleyes: You will not see any milage improvement, if that's what you're after. Running progressive 2s on a 4 barrel manifold with an adaptor makes some sense, but a 4 brl would run better, 'cause it's bigger! Holley 94's only flow about 160-180 cfm, something many don't realize. Set them up "straight" and you'll like them much better.:)
  11. Dale Fairfax
    Dale Fairfax
    Compare the manifold of a typical 2 x 2 with a 4 BBL and you'll see they are not the same. Flathead 4 BBLs have a big plenum under the carb-it's exposed to either the primaries or all four throats. 2 x 2s don't have that common plenum-if you open them progressively you're screwing up the mixture/distribution from front to back.
  12. Blue One
    Blue One
    from Alberta
    That makes sense. Better than just saying it won't work.
  13. strombergs97
    strombergs97
    What is most important, is the plenum open so you can use progressive..
    Duane..
