Metalworking 101: Fundamentals in Fabrication
Discussion in 'The Hokey Ass Message Board' started by sunvalley54, Sep 17, 2010.
  1. sunvalley54
    sunvalley54
    Alliance Vendor
    This was a good read I found and I thought I would share with you guys.
    By Eddie Paul
    Metal Selection, Gauge, Size and Composition
    Metallurgy is simply the science of metal and metal alloy. Everything from selection of the correct type of metal, composition, gauge (thickness) and size, to welding, treatments, and working techniques will be better understood with a fundamental knowledge of metallurgy.
    The two types of metal that you’ll be working with most frequently in automotive repair and customizing are steel (mild and, to a lesser degree, stainless), and aluminum. The difference between the various types of steel and aluminum involve the extra ingredients, or alloys, which essentially are other types of metal blended together with the base metal to enhance one or more aspects, such as strength, corrosion resistance, ductility or malleability. The weldability of metal can also be changed just by adding a percentage of one or more metals, so the first thing to remember is that a metal’s alloy content is an important factor to consider during the working stages of metal as well as for the structural integrity of its application.
    At Customs By Eddie Paul, we often use 3003-H14 aluminum alloy (refer to the alloy definitions below) for much of our fabrication. The 3003-H14 has superior strength characteristics over pure aluminum and is easily welded with either TIG (tungsten-inert-gas) or oxygen-acetylene gas , yet remains malleable for shaping and bending. By comparison, a 6061-T6 aluminum alloy would yield even more strength than the 3003-H14, but the 6061-T6 is also more brittle and if welded, may develop stress cracks at the weld.
    Following is a list of aluminum alloys defined by a four-digit numeric code to identify the alloy content. The first digit represents the main element of the alloy. The alphanumeric code that follows the four digits (i.e “H14” or “T6”) is the hardness and temper specification of an alloy. For example, a letter “F” in the temper code refers to fabricated, which is an aluminum that has not been treated for hardness. A letter “O” indicates annealed, or softened by a process of heating and cooling. A letter “H” indicates a strain-hardened alloy (hardened by cold-working), and a letter “T” means heat-treated. Generally speaking, the higher the number in the temper code, the harder and stronger the alloy.
    1**X (1000-series) is the designation for unalloyed (99 percent pure) aluminum. The 1000-series offers high corrosion resistance, excellent workability and welds easily; however, its low strength limits its use in certain applications. This is still a common alloy for use in automotive fabrication where strength is not an issue. Non-heat-treatable.
    2**X (2000-series) is an aluminum containing copper as its main alloy. 2000-series aluminum alloy provides a better strength-to-weight ratio than 1000-series and is also easy to work with. The trade-off, though, is that this alloy is not as ductile, meaning that bend radii must be fairly large and gradual, and joining pieces of 2000-series alloy must be accomplished by riveting or chemical bonding rather than. Heat-treatable.
    3**X (3000-series) indicates an aluminum with a main alloy of manganese. The addition of manganese yields a 20-percent increase in strength over 1000-series, yet it retains the working qualities of pure aluminum, and can be TIG or gas welded. For these reasons, 3000-series aluminum alloy is the most popular choice a**** automotive fabricators. Non-heat-treatable.
    4**X (4000-series) is an aluminum alloyed with silicon. Moderate strength.
    5**X (5000-series) is an aluminum alloyed with magnesium. Moderate-to-high strength. Non-heat-treatable.
    6**X (6000-series) such as 6061-T4 or 6061-T6 is commonly used in production due to its relatively low cost and excellent mechanical properties. Annealed 6000-series aluminum alloy (or 6000-series with an “O” temper code) also lends itself to forming. Heat-treatable.
    7**X (7000-series) is an aluminum alloyed with zinc. 7000-series offers the greatest strength, but is the least ductile. Heat-treatable.
    Fortunately, the selection of steel suitable for automotive fabrication is more abbreviated than that of aluminum and therefore less confusing. Steel is an alloy of iron, of which there are two types: carbon steel and alloy steel. While some high-end customizers make liberal use of stainless steel, which is an alloy steel, the level of skill required to work with it is likewise at the higher end of the scale. Stainless steel is a corrosion-resistant steel commonly alloyed with a high percentage of chromium and nickel. There are many appealing structural and cosmetic qualities ***ociated with the use of stainless steel, however, so you may want to consider advancing your skills once you have mastered the basics.
    There are some fabrication jobs that we do in my shop that require the strength and weight of steel along with the corrosion resistance of aluminum. For example, the 14-foot mechanical great white sharks that I build for the Cousteaus and The Discovery Channel specials were framed entirely out of stainless steel. With constant exposure to the harsh salt water, any part of the shark structure made of carbon steel would corrode and fail within a few short days. By the way, not all stainless steel is “stainless.” Like aluminum, there are several stainless alloys with varying degrees of corrosion resistance, strength, etc.
    For general automotive work, my use of stainless is usually limited to hardware items such as fasteners (bolts, nuts, washers, etc.). Occasionally, a job comes up where we fabricated portions of a frame or some brackets out of stainless. Stainless can be very easily machine-polished to a high chrome-like luster. But the cost factor for both material and labor usually keeps us working with carbon steel.
    Carbon steel, a combination of iron and carbon, is used in most of the techniques in this book. But to avoid any confusion down the line, there are a few other terms that I may use in reference to steel. One is mild steel. Mild steel is simply a carbon steel that contains a maximum of 0.20 percent carbon. Mild steel cannot be hardened or tempered, but it can be case-hardened. Hot-rolled steel is a carbon steel that is brought up to a white heat during its manufacture and then p***ed through a series of rolls to reduce the cross section, thereby increasing its length. It is then cooled, cut to length, or coiled. Cold-rolled steel is a carbon steel that is manufactured by a process technically refered to as cold reduction. The cold-reduction process reduces, as its name implies, the thickness of steel by rolling or drawing the material without preheating it. This cold method adds strength as well as produces stock that is smoother and more consistent.
    The process of hot-rolling produces a surface slag that, when compared side-by-side with cold-rolled steel, is quite obvious. The benefit to using hot-rolled is its lower cost. The more expensive cold-rolled steel is commonly used in precision sheet metal applications since it provides an excellent surface, material consistency and a more accurate thickness.
    The same basic code system that defines aluminum alloys similarly defines steel. But before we get into coding, let me say that I seldom have to refer to or order my steel by code as I do with aluminum. The main reason is that I’ve developed a rapport with the metal supplier that I get all of my metal from and I simply refer to my carbon steel orders as either hot-rolled or cold-rolled. When it comes time for you to locate a metal supplier and place an order, keep in mind that a good supplier will have a catalog of the metal that they stock that usually contains a lot of useful information pertaining to sizes, gauges and alloys. And a knowledgeable salesman will also take the time to help you with your order based on your specific requirements. Still, it’s always good to know what you’re ordering so the following code definitions are part of this portion of custom bodywork. This is not a complete list of codes; I’ve narrowed it down to the basics to avoid any confusion.
    1**X (1000-series): Basic open-hearth and acid Bessemer carbon steel that is non-sulfurized. 1020-series cold-rolled steel sheet metal is a common material for automotive fabrication.
    2**X (2000-series): Steel alloyed with the addition of nickel.
    3**X (3000-series): Steel alloyed with nickel and about 1.25 to 3.50 percent chromium.
    4**X (4000-series): Steel alloyed with molybdenum or nickel-chromium-molybdenum. You’ve probably heard the term “4130 chrome-moly” a few times. 4130 is a steel alloyed with chromium and molybdenum. Stress-relieved 4130 chrome-moly is used where structure strength is most critical. Annealed chrome-moly is used for fabricating structures that require forming and bending.
    The code series for steel continues up to 9**X (9000-series) with different alloys and percents of additional metals being added that will enhance different features and characteristics of the base carbon steel. As you get more involved in (as opposed to fabricating with bar stock or tubing), there are specific types of steel that you can use to enhance the working properties during the forming process.
    My steel preference for general all-around customizing are two alloys referred to as AK and SK steel sheet. This is the metal we use at the shop for most of our. I would suggest you purchase AK or SK. “A” indicating the addition of aluminum during the killing process indicated by the “K” for “Killed” or in the case of SK, the addition of silicon. The metal supplier for my shop, M&K Metal in Gardena, California, has both AK and SK steel sheet stock and will sell single and partial sheets at a time, whereas some metal suppliers will only sell these metals in mega-pound quan***ies.
    You will find this metal to be the best all-around alloy for metal fabrication of parts and panels. You will notice that if you work AK or SK steel it will not work-harden as quickly as regular cold-rolled steel does. This is a very big advantage for the fabrication of deeply contoured panels. If you cannot find the AK or SK near you at your local metal supply company, try calling any local customizer or stamping company. Many times they have already bought a few thousand pounds of it and may be willing to sell a few sheets to a fellow fabricator. I have, on many occasions, gotten together with someone else and placed a combined order; this will render a quan***y discount on most items.
    I use 18-gauge AK sheet metal for most of the customizing in our shop. As a rule of thumb, I try to match the gauge of sheet metal to that of the panels on the car that I’m working on. For a stand-alone project, 18-gauge is a little heavier than necessary, but this thickness does allow for deeper shapes to be formed into the metal. Although 20-gauge would be easier to cut and shape, 18-gauge sheet is perhaps the best for a beginning fabricator to start with.
    Gauge: The Thickness of Steel and Aluminum
    The gauge of sheet metal is a numeric reference that indicates thickness. It’s similar to the gauge scale for electrical wire in that a numerically higher gauge indicates a thinner material. This can sometimes be referred to as “the inverse law of logic as it pertains to sheet metal gauge.” Whether it’s sheet metal or electrical wire, this gauge system seems backwards to me, but we’re stuck with it.
    If you make a side-by-side comparison, the same gauge number of a sheet of steel (ferrous) and a sheet of aluminum (non-ferrous) is different in actual thickness; in other words, the two sheet materials with equal measurements in thousandths of an inch will have different gauge numbers. For example, 20-gauge steel is 0.0359-inch thick while 20-gauge aluminum is 0.0320-inch thick; not a big difference, but enough to be confusing to some of the engineers out there. So 20-gauge aluminum is closer to 21-gauge steel, which is 0.0329-inch thick. Don’t ask me why, I have no idea. But it will mess you up when you are trying to match a gauge in a repair or when adding new metal, so be sure to specify the thickness, the gauge and the material when ordering your metal. Most of the material we work with in my shop is between 18 and 22 gauge.
    Metal Shrinking: How To Shrink Metal and Why
    So what exactly is metal shrinking? Well, to a fabricator, it’s when you literally pull or press a section of metal together into itself. Doing this doesn’t actually make any metal go away, but it reshapes it and makes that particular section of metal a bit thicker. This is one way to shape the surrounding area. By simply shrinking one section and having the surrounding area bend toward the shrink.
    Now you’re probably wondering how do you shrink metal? There are a number of ways to do this. One of the basics is to use a pick hammer with a padded dolly. Then there’s the shrinking hammer and shrinking dolly, a shrinker, or an oxy-acetylene torch (hot-shrinking). In some ways a dent will shrink a surrounding panel by stretching it in a small area! Confused? Well imagine a rock hits the center of your and puts a hemispherical dent in the metal. That rock has stretched the door metal at the area of impact, but the surrounding area has been pulled toward the impact therefore shrinking the door skin in general. Now if you use a pick hammer (which is a small body hammer with one end pointed) and back the panel with a padded or-coated dolly (or a block of wood), as you pick the panel you are basically shrinking the metal inward toward the work area but with greater control than using a rock.
    The reason for using a block of instead of a steel dolly is that if you used metal for a backing then you will be stretching the metal, not shrinking it. Pounding metal between a hammer and a steel dolly tends to thin the metal and since metal has to go somewhere it expands outward into the surrounding metal. By using a soft block and a pick hammer, you allow the metal to form small peaks, thereby pulling the outer metal toward the small peaks.
    I know that I might be oversimplifying this process, but doing so will make it easier to understand the process of shrinking, and the more you understand the better you can work metal. Just remember that for every action there is a reaction, so moving metal in one spot will cause the metal to move somewhere else. The trick is to know where the reaction will be and in what direction the metal will react. Then, and only then, will you have become the master over metal.
    The process of shrinking metal with the use of a torch is well known and pretty standard — except for a new twist, which metal fabricator Ron Covell pointed out to me. He no longer recommends quenching, or accelerated cooling of the metal after shrinking it. The accepted method is (or was?) to find the area that needs to be shrunk, which would be a high spot in an otherwise smooth panel, then heat a small spot about the size of a silver dollar. Then, as it turns cherry red and raises to form a small bump, simply tap the bump down slightly until the spot is level with the surrounding metal. After which you would, but may not need to, dip a shop rag into a bucket of water and quench the spot. But what Ron told me, and I agree with him on this point, is that by quenching the spot, you will harden the metal at that spot. But if you do not use the quenching method and let the area cool off naturally, the metal can be worked later without having to anneal it again. On the other hand, Brian Hatano, the main fabricator in my shop, prefers to quench the metal and is able to attain the shape that he wants.
    Stretching metal is the opposite of shrinking and produces the most common mistake that body men make when working, or overworking, a panel. It is the hammer-on-dolly work that thins and stretches the sheet of steel that requires shrinking it into its proper shape.
    Remember, you can shrink metal a lot, it will only get thicker; but if you stretch it too much, it will then tear as it becomes too thin to have any tensile strength.
    Whether shrinking or stretching a sheet of metal, you’ll notice, if you’re observant, that the worked area actually hardens. Why does the metal get hard after shrinking or stretching? We call this “work hardening” and it’s the direct result of squeezing the molecules of metal so close together that the metal gets tougher and harder to work. If you run into this while working with metal, which I am sure you will, you can simply anneal the metal to soften it again.
    In writing this book I came across the dilemma of explaining to the reader the problem of knowing when to shrink and when to stretch metal. Let’s just say, for example, that you have an area in the front part of the hood that you just extended with a section of metal and, after welding it, wound up with metal that looks like the Pacific Ocean during a storm. You now have large sunken-in areas and you know you have to shrink or stretch them to pull them back to the original shape. Well which will it be: shrink or stretch?
    So to solve this dilemma I can break it down to a simple example and a rule to help you remember: If the panel is flat and it has a large “oil can” in the center indicating too much metal, you would shrink the center area, pulling the excess area together into itself and as a result “tightening the metal” and removing the oil can effect. On the other hand, if the area has a large compound curve and the oil can is in the center of this curve you would stretch the metal, forcing it to stay in one direction as opposed to canning in and out.
    So the simple rule would be: for flat panels shrink; for curved panels stretch.
    Now, what if a section of metal has a very slight curve or is almost flat? Then I would start by slightly shrinking and if it gets worse then resort to stretching. Shrinking will thicken the metal, which can be stretched later, but stretching the metal will decrease the thickness and make it harder to work with if you need to shrink it later. If in doubt, shrink it first. Or, as I like to say, “error on the side of thicker.”
    Metal Stretching
    Once again, for every action there is a reaction, and stretching metal in one spot will result in a buckling in another. To better understand the reaction concept I like to carry the example to the extreme with a whimsical example of a car that is hit in the front fender, now this car was absolutely perfect to start with in every dimension so that all the seams were 1/4-inch exactly. The average person would see a dent from the impact. But, the true scientist would notice that the small hit on the front fender closed the fender seam between the fender and the door a few thousandths of an inch and upon further measurement the rear door seam was slightly closed as well and no longer was exactly 0.2500000 inch, but 0.24999992 inch.
    This is just for example and no car is that exact, but the point is that a simple tap in the front fender will result in every other part of the car being affected. So as you stretch metal in one area you should notice that the surrounding area is affected. In most cases this is just what you want so your action will cause the “desired effect” somewhere else. Once you understand the action/reaction concept you will have mastered working with metal. Many times the area you need to work is not the area with the damage, but the result of the damaged area. Or it is near the damaged area and by working this area you will relieve the stress on the damaged area.
    There are stretching on the market—I know because we manufacture a good metal stretcher—and they do a fine job around the edge of a panel, but sometimes you will need to stretch the center of a panel and the end stretchers just don’t reach in far enough, so different methods are required. A**** the ways to stretch metal, the most basic method is the “hammer-on-dolly” technique. This method requires that you place the dolly directly under the point where the hammer will strike so that each hit of the hammer compresses, or stretches, the metal.
  2. ratman
    ratman
    Thanks thats good info:)
  3. dodored
    dodored
    from Concord NC
    Thanks for posting this.
  4. brady1929
    brady1929
    great info here
  5. red baron
    red baron
    from o'side
    subscribing to this one
  6. chickenshift
    chickenshift
    Great lil thread. Thanks for taking the time to post this.
  7. langy
    langy
    Very interesting.
  8. I have Eddie Pauls "Sheet Metal Fabrication" and "Custom Bodywork".
    Both excellent books.
  9. John_Kelly
    John_Kelly
    There is some really good stuff in there, but I disagree with the over-simplistic oil can repair stretch or shrink explanation. It does not make sense.
    Leaving the shrinking disc out of any metal-finishing tutorial is leaving out the best tool there is for the job. The pick hammer, and the shrinking dolly and hammer are tools that barely do the job and they damage the surface.
    Heating to red hot, although faster, is completely unnecessary and will limit the workability of the metal after multiple applications of the torch. Heating to a lower temperature and quenching can be done dozens of times in the same spot without changing the workability of the surface.
    You could actually shrink with a padded dolly and pick hammer as described if you were very careful to blunt the tip of the hammer and hit softly creating a bump that you would hammer with a regular hammer and dolly to shrink and smooth the area. Simply making bumps will gather up the surface (a fake shrink), but this type of shrinking does not actually shrink the metal unless the lumps are flattened out by just the right force during hammer and dolly work. This is akin to tuck shrinking where you are driving the metal in on itself to make it thicker.
    I would recommend 20 gage for beginners, not 18 gage. And cold rolled steel works just fine for just about any metal shaping job you are likely to come across.
    Sorry to pick nits on such a good article but beginners take things very literally and can get hung up by thinking personal preferences of a skilled operator are the law. They are sometimes just opinion, and should be experimented with to see how they work along with other ideas.
    John
  10. Toner283
    Toner283
  11. Da Tinman
    Da Tinman
    also the flat panel/shrink curved panel/ stretch thing isnt correct either. It really depends on what the damage is on which procedure your going to use.
    Some good info but mixed with some bad advice.
  12. Wheelie
    Wheelie
    from Dallas
    Good read, a nice refresher.
  13. pimpin paint
    pimpin paint
    from so cal
  14. John_Kelly
    John_Kelly
    So what's wrong with talking to your wife's cat? : ) Thanks for recommending my videos!
    It is hard to change ingrained ideas, both good and not so good, they really have worked for years, but there are often better ways to do things.
    John
  15. ricardo_rocha
    ricardo_rocha
    from Brazil
  16. bluemeanie
    bluemeanie
    interesting! Thanks for posting it
  17. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  18. f1 fred
    f1 fred
    from mn
    wow, great info thanks!
  19. KrisKustomPaint
    KrisKustomPaint
    Not quenching when torch shrinking makes life a lot easier. Although if you cool it with air or water after its cooler than about 500 degrees it wont harden and will allow you to check the curvature and work faster.
  20. Da Tinman
    Da Tinman
    no offense dude but why are you still using a torch to shrink?
    If you havent tried a shrinking disk yet, give it a shot. The torch will go back to being a cutting and welding tool.
  21. sr
    sr
    from Monterey
    thanks,.good info. I would like to hear about the shrinking discs and pros and cons. I had to put in a patch on a 56 Ford panel truck to fill in where windows were cut into the sides. Now I have to figure to shrink or stretch and which techniques to use. I will be following this thread to learn from you all. Thanks again.
  22. Da Tinman
    Da Tinman
    There are plenty of threads already covering this, so a search and learn a bit. Metalmeet and a few others also have detailed threads on how and what your going to need to do.
    Techniques vary according to how you put the patch in and where the welds are in relationship to the inner structure.
    Post up a couple pics from inside and out of what you've done and we would be glad to help you make it worse.... :D
  23. BOWTIE BROWN
    BOWTIE BROWN
  24. pimpin paint
    pimpin paint
    from so cal
  25. Da Tinman
    Da Tinman
    My disk is mounted on a 9" buffer, and I'm not afraid to lean on it. I've found that shrinking disk is much faster because I have a lot better control over how much shrink I get and need no post disc hammering. Before I got the shrink disk I would have to re stretch some areas after runnning the torch over it.
    I also have a smaller 4.5" disk mounted on hf grinder for smaller and tighter areas, I lean on that one too.
    You'd be suprised how fast things get hot with one.
  26. Hitchhiker
    Hitchhiker
    I think that's my issue right now.
  27. pimpin paint
    pimpin paint
    from so cal
    Hey Hitchhiker,
    At the end of the day, it's as Mr. Kelly pointed out, about opinion, opionion based on experience (sometimes bad)! Everyone has to work out that method that will produce the result they're after.
    The prac***ioner isn't the owner of the knowledge, he's/she's only the custodian thereof.
    " Picture all expert as mammals "
  28. Da Tinman
    Da Tinman
    nah,, everybody is wrong but me... LOL!!!!
  29. sr
    sr
    from Monterey
    I think I have the skills needed to make it worse on my own! I just had to jump into it knowing that there is a steep learning curve with this art form. I am not looking for perfection (well, I am really) ,but know I cannot attain it. I will not post pictures of my attempts because of my pride! I will post some photos of the next section I have to repair and ask for advice on this area before I start it. Hows that?
  30. sr
    sr
    from Monterey
    The rear lower panel area will be my next area to repair or destroy with different techniques. This was filled with bondo and shaped very well. You would not know it was injured unless you looked underneath. This is going to be my bonneville tow rig, so bondo and salt and water would make this area bad in no time.
    The photo of the side panel with the window cut out is before I did a patch. You can see how they stretched and banged the sheet metal all around it. Compound curves around and much damage. I trimmed out the hole into better metal and used sections from a 56 ford hood for the patch. Maybe I will get the nerve to send those photos. I will take photos of the before and after I do some stretching and shrinking of the patch.......maybe.
    You can see the before photos. Then I removed 300lbs of bondo! I have learned to never trust a seller UNLESS you have touched and felt the vehicle you are buying or trading. Ouch.
