Need help with overdrive solenoid
Discussion in 'The Hokey Ass Message Board' started by Revhead, Feb 6, 2005.
  1. Revhead
    Revhead
    from Dallas, TX
    My overdrive solenoid is shorted out internally, so I need to pull it off the trans. Oh yeah it's in a '49 ford with the BW R10 overdrive. I got the two bolts off, but the plunger(?) seems like it is still attached internally. Please don't tell me I have to rip off the O/D unit to get the solenoid off.
  2. nwpackrat
    nwpackrat
    from Spokane Wa
    I don't know about a Ford but on a Chevy you have to turn the selanoid a 1/4 turn and it will let go
  3. Revhead
    Revhead
    from Dallas, TX
    That may be the answer. they used this over drive in studebakers, chryslers, packards, and who knows what else, so it might be the same as a chevy unit. How hard is it to get it back in?
  4. du$ty
    du$ty
    i think if i remember right...you gotta make sure the manual lever is disengaged and you kinda turn and wiggle it out.when i had a 50 model overdrive in the t...when it went out i couldnt find one anywhere.
  5. willowbilly3
    willowbilly3
    from Sturgis
    I think the solenoid from any R-10 is the same, R-11 too. 6 volt or 12 is probably the only difference except for the rare offset ones for the convertible boxed frame.
    The book says to turn the solenoid clockwise 1/4 turn to remove it.
  6. willowbilly3
    willowbilly3
    from Sturgis
    OOPS, let's resize that so you can read all the different cars that used the same overdrive.
