Projects The Tale of Two 49's
Discussion in 'The Hokey Ass Message Board' started by Chopped50Ford, May 20, 2010.
  1. Finnrodder
    Finnrodder
    from Finland
    Are those early mustang fuel tanks that you guys have fitted to your shoeboxes or from later models?
  2. Johnny1290
    Johnny1290
    That's what I use a 65 tank off ebay. 16 gal but later years around 70 they're 20 gal. I wanted a smooth floor though, but I wish I had the 20 gal tank now.
    I scanned and posted a tech article on it, they're easy to put in plus if your trunk or spare tire well is rotted you kill 2 birds with 1 stone :)
  3. Finnrodder
    Finnrodder
    from Finland
    Okey,thanks.I have to think about it.
  4. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    More updates, the floor in Shoebox number 1 is completed. Fabbed up the floors we cut out, and welded them back into place correctly. The gas tank was provided with the car, so we mounted it in the middle with a double layer ring of 16 ga steel mounted around it for further strength and easy to use screw down brackets to hold it better in place.
    The 'hump' over the rear end has been boxed in with covers to gain access to air bag equipment underneath. Ease of repair is always the best in any build!
    Converting those hinges to inside the car? We made these brackets to simply weld in place and screw from the outside, to the decklid to accept 1951 Ford trunk hinges. Need some? :)
    Were currently getting the trunk to hinge in place, then installing a 292 Ford Y Block in the engine bay, allowing us to complete the floors/center hump/trans cover in the car!
  5. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    More Floors! Got the floors (completely fabbed) in Shoebox #2 completed with the install of a 1968 Ford Mustang tank. Its the best change you could do, especially if they are like this one which lays solid body/frame on the ground. Definitely happy with the results and so is the owner!
    New grill treatment in the works....Stay tuned!
  6. Luke__805
    Luke__805
    All the custom metalwork on the floor was coated in POR15 for protection
  7. Royalshifter
    Royalshifter
    Moderator
  8. lorodz
    lorodz
    nice and clean
  9. FleetlineDLux
    FleetlineDLux
    from Canada
  10. 1955 LEDSLED
    1955 LEDSLED
    from LONG BEACH
    Outstanding work...a true craftsman!!! Keep the post coming.
  11. Luke__805
    Luke__805
    Once again, props to chopped50ford for taking on my car as a project and all the amazing work he's done. The custom grille surround is almost complete, along with the floating grille. He's making a 51 trunklid/hinges work on my 49 for that smooth look without the external hinges. Most of the major aesthetic items are complete. Have a few smaller things I plan on having him do, but I'm excited as it gets closer to body/paint ( chopped50ford will also be handling the bodywork/paint/interior ) on my car
  12. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    We got the trunk on with 1951 Ford hinges
    Grill surround, hood and corners completed!
    Package Tray put back in place, made some missing brackets that were needed to fill the sides!
  13. panhead_pete
    panhead_pete
    Looking good mate!
  14. 50 Ford 1963
    50 Ford 1963
    Amazing work on both cars, if I ever get to the point of needing work done on my shoebox I know where to send it.
  15. Stefan T
    Stefan T
    from Sweden
    Nice looking shoeboxes
  16. Luke__805
    Luke__805
    Can't wait to pickup shoebox # 2 !! Definitely excited to start driving it again. I'm having Chopped50ford completely rewire it and install a new electric fan ( old fan burnt up when I was taking it down to him to start work on it) Just am gonna have it sprayed one solid color and put the floating grille in place so it looks decent till I can save some more cash and bring it back down for paint/interior.
