Model A sedan gas tank location
Discussion in 'The Hokey Ass Message Board' started by chataf, Sep 21, 2010.
  1. chataf
    chataf
    I have been trying to figure out how I want to install the gas tank in my sedan. Coupes are easy bc you can just put in the trunk. I don't want to run the 32 tank. I was just wondering if people wouldn't mind posting some pictures of their tanks and filler cap locations. Thank you.
  2. speed-kings
    speed-kings
    Are you going to run a back seat?
  3. I put an aluminum fuel cell behind the rear seat.
  4. chataf
    chataf
    no i dont think i am gunna run a back seat
  5. tony31a
    tony31a
    Whats wrong with where Ford put it? Thats where mine is.
  6. slddnmatt
    slddnmatt
    the 29 i have at the shop has a custom one that hides behind the back seat.
  7. crotex
    crotex
    from cuero, tx
    I put my gas tank, brake booster and master cylinder, and battery all where the backset would have been underneath the floor...
  8. HotRod33
    HotRod33
    You have the brake booster and master cylinder under the car where the back seat was.....? how long of a brake rod do you have running to it from the pedal....?
  9. Obersten
    Obersten
    from Norway
    Mine too.:)
  10. crotex
    crotex
    from cuero, tx
    Yeah, I didn't really have the room to mount the booster and master cylinder on the firewall or under the floor near the pedal. So I mounted it on the frame on the driver side right in front of the rear end.. I made a long brake pedal rod from all thread and slid a tight fitting piece of tubing over it with jam nuts for strength.. It worked well and fit well.
  11. bobs66440
    bobs66440
    from New York
    I don't have any pics, but on my '28 sedan I put in a 16 gal. Jaz fuel cell (poly in a steel can) where the back seat would be and built a sheetmetal box around it just to be extra safe. I was never totally comfortable with having the fuel riding in the car with me though...and no matter what I did I could never totally eliminate the fuel smell from inside the car.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I'd like to see your brake booster and rod set up
    what diameter of all -thread did you use and how long is it?
    There's a ton of threads on this subject, put it up in the search function box and sit back and read. there's a guy that has his tank mounted inside the frame rails and can cary 23 or so gallons. others with them mounted behind the seat, although im not a big fan of gas inside with you, there really isnt a bunch of places you can mount a tank on these small cars.
  13. barry wny
    barry wny
    Finished picture can barely see it right side in front of rear spring. I initially had a yard sale tank I cut the corner off of to start with, used a 5" piece of truck exhaust pipe for the driveshaft tunnel. Tank was too rotten, after a few attempts to patch much easier to make it from scratch. I built my own the same as this one using the side and top mounting points. A rubber cushioned bolt go's through the floor near the tunnel. Floor raised on p***. side to clear tank. If you have more body back there you would have to run a filler neck out the side somewhere. Maybe a flush fit fuel door with a remote popper? Also, the original gauge can be used in the top of the tank, if it was where you could see it. Maybe a door in the floor in front of the p***. seat? I just had to bend the float arm.
  14. Just Gary
    Just Gary
    X2
    Mine is a 17 gallon RCI tank, #2171. They go for ~$200 new, but I got mine off the HAMB cl***ified for less. The car is still under construction, but it'll be surrounded by an angle-iron framework and a sheetmetal firewall will separate it from the p***engers. It's 7" thick so there will be a small (but acceptable) loss of interior space.
    Other similar tanks include Tanks #U-9 (steel, 7.5" thick, 17 gal., $250) and Moeller #032718 (poly marine tank, 5.25" thick at top, 8.25" thick at the bottom, 18 gal, $196).
    BTW, I saved some pictures posted by fellow HAMBer SVO. I'm basically copying his arrangement, but the credit goes to him.
    Hope this helps.
  15. 29nash
    29nash
    from colorado
    I appreciat you showing that tank. $2 at a yard sale eh?
    It promotes the art of DIY. I can't wrap my brain around spending much for a gas tank.
    So many people purchase a high dollar tank that really don't fit where they put it. I have two; the steel and welding cost a bunch less than buying one, fit 'zactly where I want them................
  16. chataf
    chataf
    Id love to put mine in the dash, but someone has cut the tank part out and filled over the the filler hole in the cowl. It just a problem I've been running through my head and can't come up with a solution I like.
  17. huffer38
    huffer38
    from canada
    Where are u mounting your battery??
  18. jnkyrdratz
    jnkyrdratz
    from colorado
    heres mine behind the seat hold about 17 gallons send your email address for more pics
  19. Dirk35
    Dirk35
    I like the 32 type tank kit my Sedan has. No gas smell at all and looks like it belongs there.
    I seen you said you prefer not to put it there, but Im throwing it out there for ya anyway.
    John Heckman likes this.
  20. fiftyv8
    fiftyv8
    from CO & WA
    Are you running full fenders?
    If so your choices are 32 style which you say you dont want, then there are the saddle bag type which I dont like.
    Behind the back seat aint bad.
    The other way I did it was by using a custom made tank under the floor in front the diff and behind the ******.
    Holds 23 gallons, see pic's attached, also give good weigh distribution and low center of gravity.
    However if you are using anything other than a parallel 4 link that idea wont work either.
  21. 39 chevy kustom
    39 chevy kustom
    My A coupe will still have the fuel tank where henry intended it to be in an A model , never trusted the 32 style or in the trunk , just can't get the image of pintos blowing up , if hit in the rear, out of my mind.
  22. art.flame
    art.flame
    i,m running fenders ,i made two aluminum aprox 20 gallons
  23. gimpyshotrods
    gimpyshotrods
    Yeah, think safety third!
  24. tony31a
    tony31a
    Oh sorry maybe I should put it where my back seat goes and put the filler neck out the quarter window. Then I could put some huge z's in the frame oh and spiderwebs cant forget the spiderwebs.
  25. Same here.
